Question about Hobart HL600 Legacy Stand Mixer
What is errror code erh
Mixer will not start...erh flasing...what is this?
  • Mark Seneca
    Mark Seneca Feb 04, 2016
    Does not work on a Hobart HL 400 tried it.what it mean?
  • 1,162 Answers
The manual I just read says to unplug the unit from wall an allow to set for a couple of minutes. This will reset it. An code should go away. If not contact service for repair. Their web page has a service manual you can down load. Maybe repair yourself if possible. I would do the reset first.
Posted on Mar 30, 2014
My mixer wouldn't start right away it start at the 3rd speed I'm afraid some day it would start at please help!
How old is your mixer? What type of mixer portable or does it stand by itself?
Jun 07, 2017 | Food Mixers
I have an electronic West Bend mixer, I lost the beaters to it. How can I get some more?
Hi,Please have your manufacturing date codes near you and these codes can be found on the bottom of the Mixer head or near the attachment pin on the mixer.
Go to these sites and check for your particular beater
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=2326&secid=87&linkon=subcategory&linkid=163
http://abtecparts.com/westbend_hand_mixers.htm
Sep 13, 2011 | Food Mixers
Pushing the start button, a code of 6_9d appears. What is the issue and how can I fix this?
It's telling you that the bowl guard is open. If the bowl guard is in place and closed then you could have a bad bowl guard switch.
Check www.hobartservice.com for your local Hobart office.
Aug 21, 2011 | Hobart HL600 Legacy Stand Mixer
Hobart Legacy mixer error code oc3 will not run.
Hobart mixer, HL300, stops and flashes as oc3, wounded what is broken?
Dec 08, 2010 | Hobart HL600 Legacy Stand Mixer
My Hobart mixer is hard to start. I have to keep
take off the side cover where gear shifter is, you probably have the original arrow hart contactor in there ,that part is obsolete but you can get a kit from hobart to upgrade the control circuit
Nov 29, 2009 | Hobart H600 Stand Mixer
Keep getting error code 23 when trying to start mixer
i will try to help, always include ml# with problem description on any hobart pc. of equip. which is located on the info. plate. there are 2 v.f.d.for this mixer ,sr drive being 1st generation, and gen. elec drive 2nd generation, on the sr drive err23 indicates a motor stall condition there are 6 most likely causes for this err. 1st, batch size too large,ck. capacity chart. 2nd,encoder malfunction. 3rd,motor malfunction. 4th,drive malfuction. 5th,1 con coil malfunction. 6th,2 cr malfunction. if this does not help, repost problem and i will ck. to see if i can be of anymore help, please dont forget to vote for me thanks, monomoy
Oct 05, 2009 | Hobart HL600 Legacy Stand Mixer
Pastry Chef said mixer will not start.
Depending on what you were mixing for 1/2 hour, you could have overheated & burned out the motor.
Mar 21, 2009 | Spar SP-60PZ Commercial Planetary Stand...
575 watt 6qt stand mixer. start out on low speed
Hi. If your mixer is still under warranty, call Kitchenaid, they are usually very good at replacing mixers under warranty.
If you're out of warranty, you'll need to order a new speed control board. Use the following link to download the parts catalog for your mixer.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212278.pdf
You can remove and replace this board yourself. Use the drawings to assist you with the project.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 16, 2009 | KitchenAid KP26M1X Stand Mixer
Univex mixers
Im not bias on my opinion,but from the repairs i do on mixers hobart mixers are far superior than other manufactures.Hobart is over 100 yr old company that started with mixers and their service dept. is good.unlike any mixer out on the market they mirror off of hobart.
Nov 29, 2007 | Univex 250 Watts SRM12 Stand Mixer
Hobart hl600 mixer
I know what these codes are: code 19 is that phase c is over current fault and code 23 is a motor stall fault.I would start by making sure you 3 phase wiring going into the mixer is there.I service these mixers as im a service tech for hobart.these units are very detailed and i can walk you thru some things to check but if you have an electrical problem you most likley will have to call a hobart service tech because we have special equipment to diagnose the fault.let me know it may be something simple as these mixers are usally maintenance free.
Nov 14, 2007 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
187 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
