Question about Banner Plumbing
BANNER SHOWER TUB DIVERTER VALVE
BANNER 640 SERIES 3 HANDLE TUB-SHOWER DIVERTER VALVE HAS A CAST STEM OR EXTENSION W/ A PLASTIC BONNET AND LONG SCREW THROUGH THE ASSEMBLY & HANDLE. tHE STEM IS WEAK AND KEEPS BREAKING. NOW I CAN'T FIND REP[LACEMENT PARTS?
  • 2692 Answers
SOURCE: How to remove the corroded valve seat housing in my tub faucet
Some seats ae rremovable and some or not Some take a hex(allen) wrench and some take a square (seat removal tool)  Most of us use a seat grinder. (another tool to dress up the seat (Remove material) past the seat damage. You will find any of these tools at any hardware store that sells plumbing parts. If the seats have a square or hex hole remove and replace rather that grind(dress)the seat. All right hand threads meaning turn counter clock wise to remove. Take old seat to the American Standard plmbing supply outlet and then will match it up. Good fix-in to ya.
Posted on Feb 08, 2009
  • 360 Answers
SOURCE: Moen Castleby T6988 Roman Tub Faucet
with screw removed (the missing one), handle should lift straight up. may need to rock the handle while lifting.
Posted on Feb 12, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
  • 297 Answers
SOURCE: Tub shower diverter stem on tub spout broke and
you must replace the whole stem.you can get it at homedepot. first take the cover off over the stem. this should screw off or is held on with a allen key.then unscrew stem from valve body.make sure water is off to tub,just in case.
Posted on Jul 15, 2009
agent91
  • 2100 Answers
SOURCE: replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
Posted on Feb 28, 2010
How to adjust Banner M580 Series faucet to provide a better hot/cold balance?
Could be a defective mixing valve or blockage in the cold water input line to the valve
Jul 26, 2016 | Banner Faucets Pro Series M580 Single...
Middle valves not sending the water to shower head
the diverter screw has come loose in the diverter stem. It is the center knob that turns on
the shower. If it is american standard, they were noted for this. You may want to shut off
water to the shower itself at the shutoffs but USUALLY not necessary as long as you dont
bump the hot/cold knobs while removing the diverter stem.
Remove the cover and or screw from the handle and remove it.
then remove the decorative escutcheon cover and tube by unscrewing
it counterclockwise.
(There may be a small set screw on the underside of the cover to loosen)
The stem unscrews counter clockwise as well and may take a small pipe wrench to loosen
Sometimes the screw becomes lodged in behind the seat and requires patience and a
pick to extract it (a short burst of water may eject it into the tub). Sometimes part of
the stem body becomes lodged in the manifold but can be removed with an internal pipe
wrench set (home depot carries them for about 12 dollars).
Feb 27, 2011 | Plumbing
Delta shower faucet loses pressure when turned all the way on (hot water). What could cause this? When it first happened yesterday, a few tiny pieces of black plastic/rubber fell out of the bathtub...
Turn off the water to the home. You need tthe stem beneath the handle. Remove the handle after locating the set screw, remove the cylindrical beauty cover, and unthread the retaining nut to access the valve stem. Take it to a plumbing supply house or home store to make certain of the match.
Oct 06, 2010 | Delta & Single Handle Shower Faucet
How to remove diverter cartridge in shower 1 handle
Follow these steps.
  1. Remove Set Screw in handle and remove handle.
  2. Remove the 2 screws from the handle housing and remove the housing and escutcheon from escutcheon adapter plate.
  3. Remove valve stem screw and valve stem coupling.
  4. Remove the escutcheon adapter screws and escutcheon adapter.
  5. Using a pair of pliers pull the cartridge retaining clip out of the valve.
  6. Grasp the cartridge by the stem and pull out.
I hope this is helpful to you, please rate if this answer was of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Moen & One Handle Tub & Shower Faucet
Replaced shower valve. still drips from tub spout
Feb 28, 2010 | Kohler K-9511-BN MasterShower Shower Arm &...
Tub shower diverter stem on tub spout broke and need to have instructions for how to replace the ROD Diverter seal o ring in the spout.
Jun 27, 2009 | Price Pfister Ashfield Single Control...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Plumbing Logo
112 people viewed this question
Top Banner Plumbing Experts
Mike
Tom Chichester
Andrew Bugbee
Are you a Banner Plumbing Expert? Answer questions, earn points and help others
