Question about Fisher and Paykel Washing Machines
Aquasmart WL80T65CW1 no spray rinse all other functions working correctly
No spray rinse all other functions working correctly. Water supply and filters checked, the bowl fills normally.
  • 1294 Answers
SOURCE: Water Pressure Woes
There is a water level marked behind your machine; your outlet tube should not go below this level; the wall outlet drain should be high enough. Then your water will remain at the correct level in your machine. See that the valve in your wall to the inlet is completely open before you turn on the machine for your wash.
Your pump pumps waste water OVER the level marked on the rear of your machine. The water level marked is quite important for a successful wash.
Posted on Nov 25, 2007
  • 185 Answers
SOURCE: simpson esprit washing machine
put a new pressure switch in it
Posted on Mar 26, 2008
juliankov
  • 13 Answers
SOURCE: F & P GW712 - bowl spins, but won't fill.
Read your user manual - but I would suggest that you may not have setup the balance properly. Check the level of the machine and adjust to be as square as possible by adjusting the feet at the bottom. If the water isnt coming in on both hot and cold sounds like a common problem - perhaps the water level sensor is playing up or something else has been knocked during transportation of the machine when you moved house. Check your user manual for troubleshooting. Sounds dumb, but check that 'delay start' isnt selected also. check both hoses filters are not blocked.
Posted on May 04, 2008
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Posted on Nov 18, 2009
marka19
  • 1430 Answers
SOURCE: Hi I have a hotpoint
First check the screens in the end of the hose and inside the water inlet valve. If clear you need to remove the top and check to see if you have power to the water inlet valve, there will be a solenoid for hot and one for cold. Check for power on the cold solenoid when washer is put into a fill cycle. If you have power replace the water inlet valve. The whole valve must be replaced. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/washerwaterinlet.html
Posted on Sep 16, 2010
Fisher and paykel does Epsom salts work in the rinse water
Hi! Have you completed a "Clean Up" cycle? It should prompt you every 100 washes to do a clean up - it should be under the "Lifestyle" menu. When you do it, I suggest you use OXY soaker (1 whole Cup) instead of normal detergent and make sure it is all HOT water. It soaks for 4 hours, but is very good at cleaning the bowl and workings to stop brown marks on your clothes and towels
Oct 10, 2014 | Fisher and Paykel Aquasmart wl80t65c
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
Error code 136 on aquasmart wl80t65cw1
If your bowl turns freely bearings are not seized,
Your rotor position sensor must be faulty & not outputting the right signal to the motor controller.
Feb 11, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
I have a model WL80T65CW1 aquasmart washing machine. It stopped working and showing fault 49 on screen. I do not have a manual. Would you please tell me what fault 49 is?
In AquaSmart machines the pump over-currents and blows the water valves fuse, Motor controller board and pump needs replacing.
49. (00110001) Cold Valve or Cold Valve & Hot Valve Faulty
The Motor Control Module has measured a voltage from the valve diagnostic circuit that
indicates the cold valve or both the cold and hot valve is faulty. The most likely cause is
that the valve harness has not been connected correctly or the valve(s) is open circuit.
Primary Source: Wiring.
Action: Check the valve harnesses are correctly fastened to the valves and
the motor control module or the pins are not bent backwards.
Secondary Source: Water Valves.
Action: Measure the resistance of the cold and hot valve coils.
Tertiary Source: Motor Control module.
Action: Replace the Motor Control module.
Apr 30, 2012 | Fisher and Paykel Washing Machines
No water in washing/rinse cycle of dishwasher
It sounds as if the warter inlet valve (solinoid) isn't working and might have to be replaced. If everything else opeates fine, (unit pumps and sprays water that you added to it, pumps out and drains OK, then it is very likely the inlet valve has failed.
You can check for a blockage in the water inlet line, but unless you have a lot of sediment in your water or use a private well for your water supply, that would be a remote possibility, but worth taking a look at before buying replacement parts, etc.
You can remove the water supply hose/line and check for proper water flow and see if there is anything blocking the water from getting into the dishwasher. Many uints have a filter screen installed in them, so check that to see if it is blocked. Otherwise, look at the inlet valve and see if it is working correctly and go from there in replacing it.
One last thing, make sure the water supply line is actually providing water to the dishwasher, sometimes the water valves some installers use do get blocked, depending on how it was installed.
Jul 28, 2009 | Crosley Dryers
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
Sep 03, 2008 | Washing Machines
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
