Whirpool ed2shaxmt10 ice maker wont get water
Wont get water
    Master:
  • Washing Mach... Master
  • 676 Answers
Check the fill tube that goes to the ice maker , it is where the water goes into the ice maker it may have a ice clog in it, this is due to a leaking water valve solenoid, you would have to replace the water valve to stop it from happening again but the ice clog need to be removed. If you want to attempt this your self contact me and I will tell you how I do it everyday.
Posted on Mar 30, 2014
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker Has Stopped Making Ice
Hi: I didn't see the simple first solution to try in your list. The ice maker is thermally protected. It won't make ice until the freezer is at 0degrees F. Set your freezer lower in temperature. It may seem cold to you but it has to be at 0degreesF. Frozen at 32 degrees wont cut it. Please don't open the door every 5 minutes to see if it's made ice, as it will raise the temperature. It appears in your question that you listen for the ice to drop. That's the right way. Give it a day to drop in temp. before resetting the temp. This is a free try before you have to call a technician. I hope this helps, Jeff
Jun 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice and water don't work
This could be several reasons, water valve on back not working, thermostat in ice tray not working, heating element below ice maker not working, we just need to start with the dual water valve on back first. The side that feeds the ice maker needs the solenoid checked. I am ready to help you solve this, Let me know, Thanks, Sea Breeze
Apr 16, 2009 | Refrigerators
WHIRPOOL ED2
Not enough model to get the wire diagram. It sounds like a diode is out in the water valve harness. If it is using the triple valve on that unit.
May 08, 2008 | Whirlpool ED2FHEXN Side by Side...
Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Mar 30, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
