Question about Honeywell Handheld Ceiling Fan Remote 40013
Dimmer isn't working nor the home shield light setting
Just installed our new Hunter Regalia fan. Everything is working on the remote except the dimmer and the home shield light setting. I have it set on incandescent bulb setting as they have candelabra bulbs. Why isn't it working?
    Master:
  • 996 Answers
The fault is in main light assembly,light regulating circuit board near relay,should be repaired byprofessional
Posted on Dec 23, 2014
    Genius:
  • 1,114 Answers
I would double check the wiring of the fan. Is the remote an add-on that was purchased separately, and did it include a receiver unit which is installed in the fan housing? If so, I would double check the wiring of the receiver unit.
Posted on Mar 30, 2014
Hunterfan com
If you have a remote then you can't use the dimmer switch on the wall. Put in an on/off switch.
Sep 20, 2013 | Hunter 52" Ceiling Fan With Light And...
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
Need installation instructions for a Hunter Regalia ceiling fan, model 28642, item 183013, as the fan came without any. Am ready to install now!
Robin - Here's a link to the Owners Manual for the Model Number Hunter Ceiling Fan, you listed.
You may download and print it for future reference.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/45065.pdf
Please don't forget to leave me a rating for helping you. Thanks!
Apr 14, 2011 | Hunter Heating & Cooling
Why won't my remote for my light on the Hunter fan work? The light also will not come on when I pull the chain.
I usually discuss this exact problem with customers that have a DIY ceiling fan. First; If you just installed this fan you noticed that there are several switches on the fan and on the remote, there is also the switch that originally controlled the ceiling light fixture (If it is a dimmer switch, it MUST be replaced with a single pull switch). All of these can be set wrong. Make sure the circuit breaker is not "tripped."
To start easy; assure that the wall switch is on, (leave all the "pull chains" alone, for now) Check to see that the remote has fresh batteries. press the light switch (on the remote, if it is a dimmer type set it to high, press it several times. If this does not work leave all the switches where they are and pull the light chain once, and again try the remote for the lights only. Hopefully that worked. Now do the same for the fan, press the remote once (on any speed) If that does not work pull the fan chain once try the remote again pressing the same switch, that should work. Now that you have it working remove all the pull chains, so it won't get "confused" again. Good luck!
Feb 09, 2011 | Hunter 27185 Remote Control
Just installed a hunter 27227 remote for use with my Hampton Bay fan. The fan was electronically reversable via a F/R switch on the old remote. Everything is working great except that the thing is running...
I recently had Hampton Bay fans installed with the Hunter remote and the electrician showed me that there is a small switch on the fan and you turn it either up or down depending on whether it's hotter months or cooler months because it changes the direction of the airflow to cool down a space or help spread heat. That may be what your issue is-- it's probably set to help spread heat rather than cool things down. I hope this helps!
Apr 19, 2010 | Hunter 27185 Remote Control
Need instruction page for the Hunter light/fan remote control
There is a battery in the hand held remote and another battery in the receiver which gets tucked into the ceiling mount cover. Remove the ceiling cover and you will see the battery there, usually a 12 volt battery.
The upp/down slide is a dimmer.
In the event that changing the batteries doesn't solve your problems, Hunter makes replacement remote sets, available at Home Depot, lowes, etc and usually around twenty dollars.
May 31, 2009 | Hunter Ceiling Fan Remote Transmitter...
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
Honeywell Handheld Ceiling Fan Remote 40013 Logo
131 people viewed this question
Top Honeywell Televison & Video Experts
Ron Durham
Tom Chichester
Are you a Honeywell Televison and Video Expert? Answer questions, earn points and help others
