Question about Marantz SR5001
Where to plug in a turntable on SR5001
What is best input jack
  • 79 Answers
Have you checked the "aux." plug in? but first check the amplifier unit for info.
Posted on Mar 30, 2014
How to record from vinal to cd
Amplifiers that you can plug turntables into have a special input for turntables. You can't just plug them into the same input that you would plug a CD player into or some other "AUX" source. Turntables have a different impedance. You will have to have to have one of those amplifiers and then use the "line out" connectors on the back of the amplifier to connect to your computer using the MIC jack on your computer. If you can record your voice on a CD using a microphone, then this should work.
Feb 02, 2015 | Bush RPA 1 Turntable
Kenwood kax-38 owners manual
Keep in mind that the phono jacks are typically tuned to a much lower input voltage than CD jacks, because old turntables put out a much lower voltage. If you are using turntables manufactured pretty much anytime after the 80's, their output voltage will be higher than the phono (which is short for phonograph, which gives you an idea of the timeline of this connector) input voltage allows, so you'll get distortion. This is not indicative of a defect in the amp or the turntables, it's just a sign of the times - there are very few devices in existence today that you could possibly hook to a phono input without getting distortion.
If you need to use the CD inputs for something else, I would buy an input selector from Amazon that will let you plug multiple components into one set of inputs, then you just select which component you want to use at any given time. There are models of these allowing anywhere from 2 to 10 different components hooked up to the same input, so pricing varies dramatically of course, but a standard 2- or 3-component input switcher should only cost about ten bucks.
Dec 03, 2013 | Car Audio & Video
I have a turntable...an Music Hall MMf5 that I bought for my husband. i dont know how to connect it up to speakers so that we can actually use it...can someone help???
If it has RCA jacks (white and red jacks) coming from the unit it needs to be connected to the inputs of a stereo amplifier of receiver to produce sound. Most AM/FM receivers have inputs for phono in back. Just plug the cords into the inputs for phono and put your selection knob on your stereo to the phono setting.
Dec 01, 2010 | Music Hall MMF-5 Turntable
Can I hook a turntable to a Teac AG-D8900. Where do I input?
only if the unit has a PHONO input never plug a turntable into any other jack as teh voltage is different.
I have seen an adapter so that you can plug a turntable into an ordinary input I believe Radio Shack but that was along time ago try ebay
Jan 08, 2010 | Teac AG-D8900 Receiver
Sound coming from speakers is very low.Turntable connected to a Sony home theater system has no jack for turntable. I have it plugged into the sat/tv/cd jack.
if there is no phono input on your home theatre amp, plug the turntable into the auxillary sockets and not the sat/tv/cd input as it wont work properly in that socket. if after putting the turntable into the auxillary socket it is still too quiet then you should purchase a specially made small pre-amp booster amplifier designed for turntables to inprove the signal to noise ratio from a reputable hi-fi shop/dealer. good luck
Sep 14, 2009 | Kenwood KD-291RC Turntable
Very low sound comming out pioneer pl300
Hi Jack.
Just confirm that it is plugged into a PHONO input (designed for turntables) Cannot use AUX/TAPE etc type inputs. If not, you will need an RIAA preamp from local electronics/Audio store. If that is OK, then try replace stylus first and the cartridge (may be just easier to do both same time). No volume control in turntables and it can only be 3 things (generally) Input, stylus, cartridge
Best of luck
Jul 24, 2009 | Audio Players & Recorders
I have Pioneer Amplifier with Phono Inputs. Also I have an Akai stereo Equalizer. I want to connect my Turntable to the pioneer amplifier through Akai stereo Equalizer to have a better sound quality. Is it...
hook the turntable "directly" up to the "phono" inputs. if it sounds normal this way, and not loud and distorted, then you have to plug the turntable up that way, directly to the reciever's phono input.
you can hook the eq up through the "tape in/out" jacks.
take the tape record out jacks, and hook them up to the input of the eq, and take the tape play input jacks and hook them up to the output of the eq. then, to use toe eq, select whatever input you want eq'ed, while also selecting "tape monitor"
Mar 07, 2009 | Kenwood Audio Players & Recorders
Converter of audio cassettes to CDs
Get a computer with an audio input or soundcard. Like a Mac with garageband and a soundcard. connect both with a male 1/8" to male 1/8" cable. Press play on the tape deck, record on the computer. Once done, edit and trim the beginning and end. Import to itunes. Create a playlist. Burn to cd. Simple.
Aug 28, 2008 | Audio Players & Recorders
I am trying to hook a turntable to RXV363 amplifier. The RXV363 does not have RCA jack inputs labeled for a turntable. I tried using the DVD and DVR Input. I think the problem is there is no an adequate...
You need a phono pre amp to plug onto the phono leads of your turn table then into any input on the amp.A Turntable has a much lower output than cd or any other device so needs to be boosted,when you pluged it in I bet the sound was awfull.Buy the best phono stage you can .
hope this helps.
CABLE GUY.
Jun 28, 2008 | Yamaha Audio Players & Recorders
Audio Connection For GT-USB Turntable
The red/white plugs on the cable are called "RCA jacks", you'll need to get an adapter which will convert the rca jacks into one stereo pin jack to plug into the input jack of your computer
Apr 02, 2008 | Audio Players & Recorders
Marantz SR5001 Logo
56 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
