Question about Electrical Supplies
Only works when one switch is up and the other one down
The lights will not turn one when they are either both in the up position or down. Only when one is up and the other one is down
    New Friend:
  • 79 Answers
Are you sure you have the correct switches?,like in the bathroom you would have an on/off type of switch,as to for a living room you'd have a switch that turns on the lights when coming in,then a switch at the other end that'd turn the light off. These kind of switches require special wire connections;look it up on-line or ask someone at a lighting store,I'm sure they'd help/draw you how to connect.
Posted on Mar 30, 2014
  • alberto anicolas Mar 30, 2014
My turn signals sometimes will quit working then I have to hit the hazard lights button leave it on and then turn my turn signals on then they work what causes this to happen
When the turn signals quit working pull up , down , front to back an back to front on the turn signal switch handle . Do they work when doing this ? Pontiac had bad switch . The power for the turn signals goes through the flasher / hazard module . Could be the switch or the module.
The HAZARD LPS fuse in the left hand instrument panel (LH IP) junction block supplies battery positive voltage to the flasher module, which is part of the hazard switch assembly. The TURN LPS fuse in the LH IP junction block supplies ignition positive voltage to the flasher module. The turn signal lamps may only be activated with the ignition switch in the ON position. When the turn signal switch is placed in either the left or right position, current flow is from the flasher module's output to the turn signal switch assembly. The flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators.
Mar 12, 2016 | 2001 Pontiac Grand Am GT
Fix light chek air suspenssion
Have you disconnected the battery to reset the computer? That would be my first step. If that doesn't work, go to an auto supply (Auto Zone) and have them check for codes. Ask them to clear the codes.
Mar 09, 2016 | 1992 Lincoln Town Car
Just changed my oil,can I reset the maintenance/engine light at home
Yes you can reset at home:
1. To reset MAINT reminder light after engine oil replacement, turn ignition switch to OFF position with odometer showing ODOMETER READING. Turn ignition switch to ON position while holding down trip meter RESET button.
2. Hold trip meter RESET button down for at least 5 seconds until odometer indicates "000000" and MAINT reminder light goes out.
Sep 12, 2015 | Toyota Tacoma Cars & Trucks
Speedo not working when lights are on
you probably have your instrument panel dimmer turned off or all the way down. When the lights are off it assumes it's daytime and your instrument lights are turned all the way up. When you turn your lights on the instrument lights dim to the setting on the dimmer. Some dimmers when you turn them all the way down, click to an off position, or when all the way down look like they're off.
Mar 28, 2014 | 2002 Triumph Daytona 955i
Interior lights dont come on when door is opened
check for a dome light on and off switch by the headlight switch or check to see if the dash light dimmer is not turned down the whole way. if those are good then check to see if the door switch by the hinge is not stuck
Jul 04, 2012 | 2002 Mitsubishi Montero Sport
Signal lights dont work and want to know where the fog light switch is at
With the switch in sidelight or dip
position, pull the switch to its first
position to turn on the front fog lights.
Pushing the switch in or turning it to OFF
or AUTO will turn off the front fog lights (this is for the front)
With the switch in any position except
OFF or AUTO, pull the switch to its
second position to turn on the rear fog
lights. This will also turn on the front fog
lights unless main beam is selected.
or AUTO will turn off the rear fog lights (this is for the rear)
Exterior lighting
Exterior lighting switch
A. OFF.
B. Side (parking) lights.
C. Headlights.
D. Auto.
E. Front fog lights.
F. Rear fog lights.
It is the round knob nest to the steering colume
Aug 18, 2011 | 2003 Jaguar X-Type
Hi: I have a 1998 Chevy Blazer 4.3 The brake lights and turn signals don't work.... HELP
Sounds like you have a bad multiple function turn signal switch. A couple things to try With your foot pressing on the brake pedal, Press the four way flasher button up and down, press and hold it down, pull up on it, or wiggle it. If the brake lights come on during any one of those replace the switch. With the key in the run position pull, push, the turn signal lever slightly. If the turn signal or brake lights start to work replace the switch. Let me know if none of those work, they usually do, and I'll get you some more in depth diagnostic info.
Jun 17, 2011 | 1998 Chevrolet Blazer
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
