2005 Honda Odyssey Logo
B
Blas Jarrin Posted on Mar 30, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 honda odessey radioi code
I need the radio code for my 2005 honda odyssey
danoyachtcap
Level 3:
Top Expert:
  • Honda Master 2,907 Answers
  • Posted on Apr 30, 2015
danoyachtcap
Honda Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275778
Points
52081
Try this:
You can get help at honda.com concerning the radio code.
hope this helps.
Dave Setnik
Level 1:
Scholar:
New Friend:
  • Contributor 65 Answers
  • Posted on Apr 01, 2014
Dave Setnik
Contributor
Level 1:
Scholar:
New Friend:
Answers
65
Questions
Helped
15022
Points
83
You need the serial # and reference # off the sticker on the radio. Call or visit Honda with VIN and ser #'s and they will provide the unlock code for you. It's the only way to get it, if you lost the original audio card that came with the vehicle new. Look in the glove box, or door jambs for the extra ID sticker that should have been installed at PDI when the vehicle was new. Occasionally techs put the wrong one there that actually has the unlock code on it. If not, it's easy number gathering without needing to remove the radio.
5 Related Answers
Anonymous
  • 1665 Answers
  • Posted on Jun 30, 2008
SOURCE: CD Player / Radio Error Code
see a relative link
http://www.hondacarforum.com/honda-3/22348-2000-honda-civic-radio-error-code-problem.html
Anonymous
  • Posted on Mar 28, 2009
SOURCE: I need radio code for honda odyssey 2004
my code was on the inside of the glove compartment
Anonymous
  • 448 Answers
  • Posted on Nov 13, 2009
SOURCE: I have a 2003 Honda Odyssey my radio says code
If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code number into the unit or it will not work. This code and the audio unit’s serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner’s manual for the specific procedure (the following usually will work: Turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.)
. Some older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. Once you have the audio unit serial number, you can call Auto Customer Service at (800) 999-1009 or have the dealer look up the radio code.
Hope this gets you started on getting it playing.
Anonymous
  • Posted on Feb 12, 2010
SOURCE: Honda Odyssey -DVD stuck in "Loading" after dead battery replaced
I have identical issue, took it to the dealer and they "offered" to remove the unit and send it for repair..... not very helpfull.
Anonymous
  • 155 Answers
  • Posted on May 22, 2010
SOURCE: how to change plugs on honda odyssey 2005
you will need
8mm
10mm
5/8 spark plug socket
3/8 ratchet
3/8 extension (it could be 4in and longer)
and spark plugs factory plugs are pregap iridium
spark plug torque is 13.0 lb.ft
coil torque 8.7 lbf.ft
spark plug part # NGK 1zfr5k-11
# DENSO pkj16dr-m11
and spark plug anti seize on spark plug thread
what you need to do is remove the plastic cover 8mm socket or 10mm sockets
now remove the spark plug covers and remove the spark plug coils too 10mm head bolt you will need a 5/8 spark plug socket and a 3/8 ratchet and a 3/8's extension too
you need OEM spark plugs they work the best
hope this will help
2004 Honda Odyssey. Need brake code for Honda Odyssey please.
Question edited for clarity and spelling of odessey > Odyssey.
P1456 is a nice one :>)
https://www.google.com/search?q=04+honda+odyssey+brake+code
I JUST BOUGHT A USED 2002 HONDA ODESSEY VAN AND RADIO IS ASKING FOR A CODE CAN U HELP ME WITH THAT CODE?
You'll need to take the vehicle to a Honda dealer and ask the service department to help you. Most likely you'll need your ID and a copy of the vehicle registration. They do this to protect you from radio theft. When they give you the code, be sure to write it down somewhere safe.
1helpful
2004 honda odessey radio code
Need to reenter the radio code, it's normally located in the glove box or behind the radio itself, once found you should have about 3 tries to enter the code, if more attempts are needed, disconnect the neg battery cable for 5 minutes and retry.
NEED A UNLOCK CODE FOR 2002 HONDA ODESSEY VAN SERIAL# ON RADIO 11202666 REF:CK-JH8162Z
the only way to radio code is to get radio s/n serial no# on the radio itself beacuse every car has its own unique code ive tried myself and this is how i know if you can try calling your dealer or any honda dealer and give them your s/n but some of them charge for this info,try and look through your manuals and make sure its not in the book
1helpful
Radio code for 2004 honda odessey
Try pressing the preset buttons numbers 1 and 6 and the same time and then turn the radio on. You will get two sets of 4 digit numbers(radio unit serial numbers). With those numbers, call the dealership and they should give you the radio code.
I have a 2005 Honda Odyssey I need the radio code
CALL YOUR LOCAL HONDA DEALER WITH VIN AND PROOF OF OWNERSHIP
1helpful
2answers
I BOUGHT A HONDA ODESSEY AND THE RADIO SAYS CODE
I went to my honda dealer and while the car was off the service rep pushed 2 buttons and the serial # displayed on the radio. He then looked up the serial # on the computer and gave me my code. Took 5 mins and he charged me nothing. I think the 2 buttons he pushed were the 1 and 6
1helpful
Ebay radio needs radio code honda 2001 odessey
Hello telemachus,
Here is a website you can try. Thank you for choosing fixya.com. Please let me know if i can be of any further assistance.
http://www.radiocodes.com
Thank you again,
carsandcomps
Guru, fixya.com
Oregon
27helpful
2answers
Engine code P0505 for 2002 honda odyssey
p0505 is directly related to the idle air control valve (sometimes called the rotary valve) i cant count how many of these i have replaced on hondas. It is located directly under the throttle body so it can be difficult to replace. I would recommend you having a professional replace this due to the difficulty of the valve removal
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
