Question about Vehicle Parts & Accessories
How to remove headliner in 93 escort wagon
I need to know how to remove the headliner in a 93 escort wagon
    Genius:
  • 1,114 Answers
Everything attached to headliner comes off; center light, sun visor brackets, side handles if any, etc. Moldings around perimeter where liner sits comes off. liner should be able to be removed.
Posted on Mar 30, 2014
  • Hollis McInturff Mar 30, 2014
    Thanks for the help. Never replaced a headliner before, does the molding across top of doors snap off. Thanks
  • Joel Friedenberg Mar 30, 2014
    Yes in most cases it does snap off, but again, inspect the molding for any screws on handles, etc. It's just the top portion of the molding where the headliner sits that needs to pulled away so the headliner can drop down. You'll get the feel for it once you start moving the molding. It may help to take a hair dryer and swipe the molding in sections to make more flexible. Just get it warm not hot, beacuse if the molding gets too hot, it may deform. Good Luck with your project!!!!
93 sts upper dashpad removal
remove the vents with a flat head screw driver. use a 7mm socket to remove 1 bolt each vent . now thair are 3 screwes in the defrost vent remove them. remove the trim that covers the matal wher the windshild is thay just pop off it goes from the dash pad to the headliner u should know what im talking about. now be carfule and remove the sensor where the defrost cover is . and thats it
Jan 20, 2010 | 1994 Cadillac Seville
The fabric of the headliner is falling down due to the underlying foam backing dry rotting. How do you remove the headliner of the 1999 Ford Escort, and is there a place that sells a replacement?
This is definitely not a job to attempt yourself. Headliners are typically hard to fit for the inexperienced amateur and you may well end up with a mess on your hands.
If you wish to keep the car I suggest your best option is to seek out a reputable auto upholstery trimmer and get him to fit a new headliner for you.
Nov 19, 2009 | 1999 Ford Escort
Stalls when idling!
sounds like the idle is set a little to low or bad fuel filter
Jun 02, 2009 | 1993 Ford Escort 4 Door
Can't get starter off is there more then 2 bplts?
did you remember to take the power wire off there are only 2 bolts and the wires
Apr 26, 2009 | Ford Escort Cars & Trucks
I jsut bought this 93 ford escort lx station wagon
If this is a manual transmission the clutch has burned out, it may need to be replaced, if you do not do your own mechanic work I would suggest that you take it to a good local repair shop and have them check it out. If this is an automatic I would still suggest the same, but the actual problem could be more complex. Hope this helps, let me know.
Apr 13, 2009 | 1993 Ford Escort 4 Door
How to remove inner tie rods on a 95 Tracer/Escort wagon
You need a special tool that slides over the inner tie rod after removing the outer ones.make sure you count the turns to remove the outer tie rods so the alignment will be close. You will need to have it aligned after the repair.
Jan 29, 2009 | 1994 Ford Escort
Lights go off when i turn on the high beam
Pull your lever back if the high beams work that way you need a new high/low beam switch, if they do not you need to replace headlight bulbs.
Jan 17, 2009 | 1993 Ford Escort 4 Door
I need to replace my power roof on my escort cabriolet
you need to remove the headliner, once you do that you will see it is basicly just screwed in...
no matter if it is US or foreign make....
Oct 20, 2008 | 1997 Ford Escort
93 Ford Escort Wagon 13" wheels
hi there there probley is no diffrence but make sure they dont rub or scrape if they do u can go lower profile tyres but it may also put you speed o out a lilltle bit
Jun 30, 2008 | 1993 Ford Escort 4 Door
Vehicle Parts & Accessories Logo
88 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
