Question about Uniden BCD396T Handheld Scanner
Bcd396t rom error
Was doing update an got that now cut it on says rom error
Xbox code 416b-0000-3080-0504-8007-0070
If you have personally, or had someone else, modify the firmware on your console's DVD-ROM drive to play burnt games, you will need to restore the drive to its stock firmware and then finish the update through that. You can then reflash the DVD-ROM as desired to play any new games you wish.
If you have not modified your Xbox 360's DVD-ROM drive, then it is likely that your console either has a DVD-ROM that is failing, or it is simply having trouble putting the DVD-ROM into flash-ready mode to accept the update. To attempt to fix this error, eject the DVD-ROM tray and then pull the power cord out of the console, thus preventing it from automatically injecting the tray. Next, push the tray in about half way, with about a finger's width of room between the console's shell, and the apex of the curve in the hollow center of the DVD-ROM tray. Then, plug in the console and power it up while holding the tray in that position to prevent the console from injecting it automatically. Expect resistance, but it will eventually give up trying to move the tray. From there, you can release the tray and allow it to update as usual. Do not inject the tray by hand, let the console reset the tray on its own after it finishes updating. That should fix your problem if that was the specific problem causing the error. Either way, good luck, and I hope your error is resolved.
Apr 17, 2014 | Microsoft Xbox 360 Console
Pll broken
If the PLL is dead, it's almost not worth saving. Even if you get a replacement PLL and change it, the radio will not work right without an alignment. To align the radio you will need the factory alignment guide, watt meter, volt meter and an oscilloscope and a basic knowledge of electronics.
Oct 20, 2010 | Uniden BCD396T 6000-Channels Handheld CB...
I have bought the uniden 369t scanner an i have static problems
check your squelch settings and make sure priority settings are in the off positions also be sure weather priority settings are off
Mar 07, 2009 | Uniden BCD396T Handheld Scanner
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
I brought this product a year ago and lost instruction and now i have tried to use it and cant pick anything up what do i do?
Hi - You can download the manual from the link underlined in blue below:
BCD396T
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Aug 02, 2008 | Uniden BCD396T Handheld Scanner
Uniden BCD396T Manual
This may help you:
http://myweb.cableone.net/marksscanners/330/330test.html
de KC2HMZ
Jul 16, 2008 | Uniden BCD396T Handheld Scanner
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Not Loading Up
You may be in need for a ROM update/reinstall. It is pretty easy to do that. You can either go at HP's web site and download a ROM update for your specific model. Make shure you select your operating sistem rigt. Or you can browse the internet for a specific ROM update for your model. I recomand the HP site, and if you have problems regarding the ROM update process, or the ROM and OS version you need, please reply here and I'll guide you throught. Good luck.
Jan 18, 2007 | HP iPAQ H4150 Pocket PC
ROM Version
you should install the ROM v1.10 update, and then install the 8/3/2005 XIP BIOS update recently posted at: ftp://ftp.compaq.com/pub/softpaq/sp30501-31000/sp30939.exe Apparently, this BIOS update is supposed to correct the region in ROM v1.10 where the hi-capacity battery read error is found, without incrementing the ROM version. It's explained in the BIOS update "Read Me" file, here: ftp://ftp.compaq.com/pub/softpaq/sp30501-31000/sp30939.txt
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
ROM update
1.Try connecting the unit to the AC Supply. 2.Try Doing the ROM update when the unit is connected to the Cradle.(this is recommended) 3.not Via Bluetooth.
Sep 11, 2005 | HP iPAQ H1940 Pocket PC
Uniden BCD396T Handheld Scanner Logo
44 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
