Question about Radio Communications
Radioshack pro 75
No squelch
  • 1,162 Answers
Have you tried using tuner cleaner on the control pot? if its not a digital type. if it is digital type go to the menu and set the squelch there.
Posted on Mar 30, 2014
I have a Midland 75-785 hand held, It was working fine then I went to use it and the squelch control is not working ( I get lots of static) radio still works. Sends and receives, but when I turn the...
what time of day are we talking here? usually skip is so heavy from 0800 until 1600 that no radio has a chance of transmitting or receiving.If you turn the squelch the other way what does it do?
Jun 22, 2011 | Midland 75-785 Handheld CB Radio
Last night was working fine - as it was on I noticed that the scanner was just stuck on one channel - I hit scan ( I have several channels programmed) It wouldnt scan. Then when I turned the squelch...
Hopefully Resetting or Initializing the scanner will clear the problem and get it working again for you. Instructions for these procedures are on page 38 and 39 of the scanner operating manual. If you don't have the manual, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B.
Listening in since the 60's
May 24, 2011 | Radio Shack Pro-82 Scanner
Radioshack pro 2067 will not recieve anything
Make sure its your local weather channel, turn squelch to minimum, get your local frequency at www.RadioReference.com ...hope this was helpful...
May 26, 2010 | Radio Shack Pro-2051 Base Scanner
The squelch will not turn down?
Sounds like your squelch pot is either shot or disconnected. If you're electronics handy, you can troubleshoot it yourself and replace the pot if necessary. You can also send the scanner to Uniden for repair. Follow the link below for troubleshooting help or to contact Uniden regarding repair.
BillB
http://support.radioshack.com/support_electronics/doc68/68646.htm
Jan 19, 2010 | Uniden BC340CRS Base Scanner
Trying to program it
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you have your freq list, power the scanner ON,and:
1. Press PGM. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the keys to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel. Press DELAY if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends.
4. To program the next channel in sequence, press PGM and
repeat Steps 2 and 3.
Operation
• To listen to a weak or distant station, turn SQUELCH counterclockwise. If reception is poor, turn SQUELCH clockwise to cut out weak transmissions.
• If SQUELCH is adjusted so you always hear a hissing sound, the scanner will not scan or search properly.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
BillB
Jan 09, 2010 | Radio Shack Pro-2018 Scanner
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
Squelch is open all the time
Often the potentometer (squelch control) becomes worn or dirty, this can be sometimes cured by spraying a WD40 or similar oil and then rapidly moving the control down and up. Do not use oil that is conductive.
Sep 11, 2007 | Radio Shack Pro-2096 Base Scanner
Radio Communications Logo
46 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
