How can I reset the tuner to factory - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,634 Answers
To make a factory reset, you have to enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 30, 2014
Curtis 24" 1080p LCD HDTV LCD2425A will not tune in to any Channels
Tuner fault. Check and replace it. Do a reset to this TV, and then check, before doing anything. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 20, 2016 | Curtis Televison & Video
Sanyo PD58D34 TV Every 20 seconds shows "Program change by cable co" then changes my chan to 24. Not a cable problem. Nothing loose or bulging inside. Do I need a new tuner? Which part is tuner?
Do a reset [Factory reset] tho this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 14, 2016 | Sanyo Televison & Video
Hi i did rest factory after changing the tuner type, after a while just a samsung log comes and goes. i;m terribly devastated any solution please
There was no need to make a factory reset after replacing the tuner, provided the replaced one is with its original part number. As far as you did a factory reset, all data might have reset to its original factory settings. The only thing to do is to update its firmware. You haven't provided the brand name and model number to your TV here. So I cant give you more details. Just check this, and see whether it help you.
Jan 08, 2013 | Televison & Video
ASKING ME TO RESET CD TUNER
hi,
do the following for resetting the system.
p { margin-bottom: 0.21cm; }
The RESET button is located on the rear of the unit. Press this button with a pointed object if the radio fails to function properly. The clock settings and stations you have preset, etc., will revert to the factory preset.
Feb 04, 2011 | Sony XDRF1HD HD Radio Tuner
The info states this TV has an HDTV tuner (ATSC), however I am unable to tune any digital channels which are broadcast via our cable provider (not offered on whole number channels, rather decimel points...
You need to reset you tv to factory mode, by pressing tv off---mute 182 power---go to options and look for *reset to factory* them wait until the process is done.
Dec 19, 2010 | Samsung HL-S4266W 42" HDTV
When turning on TV, sound is often absent.
Unplug,replug the tv about an hour later,let the tv reset itself.Tries goto tv menu,go to AUDIO,go down to reset the audio setting,back to factory setting.Goto menu to PICTURE,go down to reset,to resetting the Tuner board back to factory setting.The sound,should be there,now all the time.Not,than the Tuner board have problems.That the board,where the broscasting signal cable plug into it.That the Tuner board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 23, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
Jun 28, 2010 | Olevia LT42HVi 42 in. LCD Television
When using hdmi outlet,,,the picture comes in for 1 second then screen turns all green
That HDMI port hub it properly shorted,tries used another HMI ports hub?Tries to reset the tv back to factory setting,by unplug,replug it an hour later,go to the tv menu go to PICTURE,go down to reset.So the Tuner board reset itself back to the factory setting,all the HDMI ports hubs,should work now or that HDMI port hub is shorted,or the Tuner board it dead.
Jun 11, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
The TV turns off and then on automatically
Tries to reset the tv back to the factory setting.Unplug the tv and the cable box too,replug it back about an hour later.Let the cable box reboot and upgrade it softwares.Go into the tv Menu.Go to the PICTURE setting.Go down to the reset,to reset the Tuner board,this will reset the the Tuner board,back to the factory setting.This should solved ur tv problems,not than,the Tuner board is defective,must be replaced.
Jun 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Both hdmi inputs dont get a signal?
Unplug,replug the tv back about an hour later.Than go to the tv menu go to PICTURE go down to reset.The Tuner board should reset back to the factory setting,all ur HDMI ports hubs should function now,not than ur Tuner board is defective must be change.Tries websites Like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement,
May 19, 2010 | Akai LCT3785TA 37 in. LCD HDTV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
