Question about LG 52LB9DF LCD TV
What is the mounting pattern for a lg 52lb9df-AD
Will a 400*800 be the correct size? thanks
  • 67 Answers
I googled your model and it took me to a link that provides an owners manual to find the exact bolt pattern of the mount.
http://www.lg.com/au/support-product/lg-52LB9DF
Posted on Apr 18, 2014
2 Suggested Answers
  • 8909 Answers
SOURCE: need driver for lg model 52lb9df-ad no sound on 73
If you were to log on to the lg.com web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
The information is normally free of charge.
I hope this helps.
Posted on Jan 18, 2011
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
When I try to print it displays on the small screen bypass letter add paper. How to solve thanks
see what size your printable area select the correct paper size, in page set up select paper size to A4, and your copier Cassatt to A4 size
Mar 17, 2011 | Panasonic DP-8020E Black and White Copier
I have a 2006 scion x/a 5 speed with front tires 225/40 and back tires 215/35. Is this safe? I just bought this car thanks Bruce
NO. they need to be all the correct and same size. I would think the ABS light would be on. The correct size will be on the drivers door jamb, along with the correct pressure. Should be 185-60-15 unles theres a custom wheel installed. But they need to be all the same size tire.
Dec 20, 2010 | Scion xA Cars & Trucks
Hello I have a Char-Broil grill model# 463268706. It is set-up right now for natural gas. But I need to convert it back to propane gas. Does anybody have or know what is the thread size on the orifice?...
You not only have to have the correct thread size, you also have to have the correct orifice size. The size of the orifice varies from grill to grill which is why "universal kits" don't work on all grills. You will have to contact the manufacturer and get the correct orifice size, or get the orifices from the manufacturer. If you need help, let me know.
Jul 12, 2010 | Char-Broil Grilling
INCORRECT PAPER SIZE TRAY: LTR
Hi mate ,
Prior to your issue that cassette size incorrect.
1)chk your device casette ,any size selector ?put it to the correct size.
2)It actually located at the cassette itself.
3)or u can chk at the add func key>custom setting>input correct size>register the size
Good luck mate ,pls feedback to me if there is any query ,i need to know u using wat model.Cos i can give u more detail solution.
PLs rate me !!!!!!Thanks
Oct 16, 2009 | Canon Office Equipment & Supplies
Hi I have a Konica Minolta 2490MF and when I try to print a document/s it will print the first page only then comes up with an error 'incorrect paper size (1LT)' the paper size is correct (A4) and the...
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4 Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Jun 22, 2009 | Konica Minolta magicolor 2490MF Laser...
Hp lj 4700 with error 41.3 unexpected paper size
Take the paper off and place the correct paper size.
If the setting is in A4 paper size please place the A4 size paper.
Thanks
Thiru
Jun 17, 2009 | Office Equipment & Supplies
HPS Copy Machine; paper size settings not adjusting correctly, malfunction, misfeed in copier, repeat, repeat, repeat
there are user mode settings and also some have settings on the actual trays the little windw that shows the paper size on the tray open tray ther is a slot that a cut out plate with the paper sizes make sure the correct size is showing thru the window if not reach in and pull out the cut out and put back in with the correct size displaying thru the window 81/2 x 11 and R if your copying the long way hope this helps
Apr 28, 2009 | Toshiba Estudio 200L Copier
Tire sizes
Open the front drivers door... or the passenger side front door... there should be a sticker there indicating correct tire sizes as well as pressures.
Robert
Please take a moment to rate this solution thanks
Jan 24, 2009 | 1999 Mercury Cougar
8mb Lumix camera....but 3mb pictures
a jpeg when compressed (unopened) would be about 3-4mb from an 8mp camera. This can vary a little. Once opened and uncompressed (ie - in Photoshop or another program that will show its uncompressed file size) the file would be about 21-25mb. If you are not getting good photos printed at 4x6 etc. It could be for a number of reasons. A: you may be printing the thumbnails and not the actual full res photos. - see if there are duplicate photos in the folder - 1 set high res, 1 set low res. B: in low light or by changing the ISO manually to a higher sensitivity (higher number like 400,800 1600), quality can be greatly reduced. C: by zooming in too far. There is a maximum that the glass can magnify and after that the camera enlarges the veiw of the pixels which is the same as you trying to blow up a tiny little area of a photo. --In combination, low light and zooming in will provide very unpleasing results. The more you zoom, the more shaky the photo will be and the less light can enter the lens A higher shutter speed and ISO are needed as less light is available. Try moving in rather than zooming in when in low light. Also use a flash. In general, dont use or disable the digital zoom for better results. A tripod will help too for non moving subjects. Take these lessons to the bank even if you think I haven't addressed your problem.
Sep 15, 2007 | Panasonic Lumix DMC-FZ30 Digital Camera
LG 52LB9DF LCD TV Logo
Computer Repairing
Computer Repairing
