Question about MetroVac ADM-4SF Metro Professional Full-Size Home Canister Vacuum Cleaner
Inserted hose in wrong end and can't remove housing to release hose
Depressed buttons on hose and inserted into vent end accidentally. While there are screws holding on the bell housing, they don't screw out allowing the housing to be removed to release the hose.
I have a blocked hose but cannot get hose off to clear it. tried using flathead screwdriver etc to no avail
i do not know how you managed to block it but...
if block is in the throat on the suction side - just use hook made from coat hanger wire, bend it sufficiently as will be about half diameter of the hose/throat, bend about 1/3 diameter of the pipe, this is that if you tug too strongly - you will not pierce the wall of the hose.
if blockage already slipped down the hose, then of course remove it and physically remove the obstruction. at the top, there is depending on the country of origin, two or three slots, you need to press you flat bed screwdriver into this slot and wiggle it towards the hose as to release latch on the hose, at this same time pull hose slightly off, rotate the mount and now insert screwdriver to release catch on other side as well, this will release hose from it's mount.
do this same on other end of the hose and you will have hose which can be easy cleaned with even broomstick handle or better still with electrical cable snake.
to mount it back - just insert that way as latches will catch on respective holes in mount.
to check if you cleaned it correctly - put a marble through the hose, if marble rattles through happily without any obstruction - you cleaned it!
hope this little info will help you, do not forget to vote...
Feb 05, 2015 | Cirrus Vacuums
How to replace the cord in dyson's dc07
Things You Will Need
  • Dyson DC07 power cord
  • T15 Torx-bit screwdriver
  • Small can
  • Camera or cell phone with camera
  • Flat-head screwdriver, 3/4-inch or smaller
  • Needle-nose pliers
Tips
  • Do detach the black wire that goes to the motor as it does not require removal.
Warnings
  • Do not work on the power cord when it is plugged in.
  • Do not force the plastic-covered connectors from the switch or you could break the male ends. Pull them off firmly but gently to avoid breaking the terminals.
  • Do not apply too much force to the plastic arms that hold the housing in place. The plastic arms are fragile and may break easily.
References
1 - Unwrap the power cord from the Dyson DC07. Detach the handle of the vacuum cleaner by pressing the release button. Pull the handle from the hose. Slide the hose down the wand and push the button at the bottom to release the hose from the machine.
2 - Press the button at the top of the dust bin handle to remove the canister bin assembly from the Dyson DC07.
3 - Lay the machine on with its back with the power switch facing upward. Locate the Torx screw directly beneath the switch actuator. Remove the Torx screw, turning it counterclockwise. Place the screw into a small can so you do not lose it.
4 - Remove the switch box housing held in place by the Torx screw just removed. Carefully pry upward on the two plastic arms that clip the housing in place. Take a picture with your cellphone or camera of the open housing to make it easier to reinstall the wires where they belong in the channels and spaces provided.
5 - Center the needle-nose pliers on the female connectors from the power cord attached to the switch. Apply equal force to pull them from the male ends of the switch. Also detach the two wires that connect together within the housing, identified by the clear plastic connector between them. Depending on your machine\'s manufacture date, the wires might have different colors. For example, they may be white and brown, all white or one could be blue. Disconnect a total of four wires -- two from the switch and the two connected together. Leave the other wires alone.
6 - Trace the electrical cord on the machine until you reach its protective cover where it enters the Dyson DC07. Lift up the cord protector to remove it from the vacuum. The cord protector has slotted sides that fit within the plastic. Slide the cord protector from the power cord.
7 - Remove the plastic covers that protect the female ends on the power-cord wires that connect to the switch. The new power cord does not come with these. Insert the tip of the flat-head screwdriver through the top of the plastic connector with two internal ridges. Lift upward and away to pull the wire free from the connector. Repeat for the other wire. Push the female end into the plastic connector until it snaps into place. Repeat for the other power-cord wire.
8 - Thread the new power cord through the cord protector. If you have trouble pushing the wires through, reach in with the needle-nose pliers to pull both wires through the rubber protector.
9 - Reconnect the two separated wires back together by inserting the male end into the female end of the other wire. Reconnect the two wires from the power cord to the switch. Reinstall the switch housing on the machine. Align the wires in the channels provided to keep them from being pinched or pulled out when you reassemble the housing. Look at the photo you took earlier as a guide, if necessary. Insert the wire that goes to the motor in this channel and the white wires connected together to the left of the switch in the area provided.
10 - Put on the switch housing cover and secure it with the screw you removed earlier. Reassemble the vacuum in the reverse order you dismantled it.
Aug 27, 2014 | Dyson DC-O7 Bagless Upright Cyclonic...
No suction when using wand on electrolux precision upright
There is a ball valve between the wand hose and the base hose. It can get stuck in the "base" mode, which won't then redirect suction to the wand hose. There is a spring under the cup that the open end of the hose rests in. When you release the wand from the holster with the one-touch quick release, that spring pushes the cup up and turns the ball valve to the wand setting.
  1. Unplug the vacuum.
  2. Using the one-touch quick release, remove the wand from the holster.
  3. Verify that the wand "cup" is indeed in the higher position. Do this by pushing on the bottom of the cup with your finger. It should easily depress.
  4. Remove the wand hose from the main unit using the quick disconnect feature. Put your fingers into the hole and feel to the right. You will feel the closed valve, verifying that it is stuck in "base" mode.
  5. Using a screw driver, insert the tip at the TOP of this valve and gently pry it downward. This shouldn't take much force.
  6. Reassemble the hose wand using the quick connect feature and reholster the wand.
  7. Plug in the unit and verify that the base unit has suction.
  8. Remove the wand from the holster and verify IT has suction.
Jul 27, 2013 | Electrolux EL8807A Precision BrushRoll...
How to remove electrolux guardian hepa filter
Open gadget compartment, remove all gadgets or attachments and the hepa filter will be below the vented frame...look next to the end with the hose and you'll see two spring clips (part of the vented frame) and squeeze them to allow the vented frame to release and move upward. This will expose the filter. Reinstall in reverse.
Mar 14, 2013 | Electrolux Guardian Bagged Canister Vacuum
Spot bot leaking when using manual hose
This is an old post but I thought it might help anyone having this problem now to post the solution.
The internal water pump feeds two water delivery hoses on the Bissell Spot Bot. One goes to the spout located in the center of the rotating brushes.
The other feeds the spout located on the underside of the brush at the end of the hose.
There is a water shut off valve that is actuated when you pull the plastic tube at the end of the hose out of the plastic tube it is fitted into during storage.
When you pull the end of the hose out of this plastic fitting a button inside is no longer depressed and a valve shuts of the water flow to the rotating brushes. If this valve is clogged with gunk it will not release when the hose end is pulled out and water will still come out of the rotating brushes even in manual mode.
This is a mechanical fault not an electronic fault.
To resolve the issue you can mix a solution of vinegar and hot water and fill the water tank with it.
Put the rotating brushes over the sink. Remove the hose and fit the scrub brush to the end.
Start the machine in manual mode. The sink will catch the water coming from the rotating brushes area.
Now point the hose end at the sink to catch the water and pull the water release trigger. While holding the trigger press and release the black button inside the tube that holds the hose end during storage. This moves the internal workings of the valve.
Do this till all the water is gone.
At some point during this procedure you will notice that when you release the black button the water will stop coming from the rotating brushes.
You problem is now solved.
If this does not work after two tanks of hot water and vinegar then the valve would need to be removed and soaked in a solution or replaced.
This is a much more complex procedure that requires disassembly.
Maybe a youtube video is in order.
If your lucky the procedure above will solve the problem.
Nov 05, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
I have a Eurkeka Boss vacuum and having problems with suction with the hose attachment. Have checked the normal things. ???? Any suggestions?
Since you've checked all the normal things, I presume you mean making sure the hose is unblocked. Now, have you checked the hose for the suction vent/adjustor? There is usually a vent with a movable cover that moves away from the vent and back over the vent. If the vent is open, the suction decreases. If the vent is covered, the suction improves. Many times I accidentally move the cover so that the vent is open and then I wonder what is wrong with the vacuum!
Hope this helps. If it does, please rate my suggestion! Thanks.
Jun 02, 2011 | Vacuums
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
How do I get the hose off to clean furniture?
Just above the power button is the purple, ribbed section that pushes in for releasing the hose. You press in and lift to release the entire hose assembly. You then pull the hose down to separate it from the handle. Push in purple button at end of hose section to separate the two sections. Now just flip over the wand and attach to opening at top of handle by sliding into the round, vented purple cap until you hear a click. That's it! Now you can use as is or connect your attachments if you have them. Hope this helped!
Dec 06, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I can't get the bottom of the canister to open in order to empty the disrecarded material.
Remove the cannister from the vacuum. The bottom lid should release if you depress the red button at the top of the cannister, if this does not release the bottom lid, you will have to depress the red button while pulling the lid open. Either the release mechanism need repair or there is something jamming the bottom lid.
Let me know if you have any other questions. Thanks.
Nov 04, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell 1950F Wet Pick Up Vacuum Cleaner
I have the the same problem.. Took machine entirely apart. Inspected the actuator lever, rod, plunger, hose, bar (entire water feed components). Took the tank apart and determined there was a possibility that the curved hose(inside of tank at suction side) could have sucked itself onto the bottom of tank. Modified to prevent this from happening again. Put the machine back together and voila! It worked for a few minutes only if I kept the trigger depressed. I believe the machine was designed for part gravity water feed and part vacuum water feed. Whatever the case, not working too well. Although, I did notice it works better when the clean water tank is full. After inspecting and testing I determined that there is too much vacuum energy being lost to the underside of the brush housing hence not creating enough suction for on demand water supply.
Aug 26, 2007 | Bissell 1960-3 QuickSteamer Plus Upright...
MetroVac ADM-4SF Metro Professional Full-Size Home Canister Vacuum Cleaner Logo
13 people viewed this question
Top MetroVac Vacuums Experts
Are you a MetroVac Vacuum Expert? Answer questions, earn points and help others
