Question about Dell 926 All-In-One InkJet Printer
What mode does 926 Printer must be in to print?
Does the printer need to be in copy, scan, fax, photo or maintenance mode to print?
  • Eric P. Allen Mar 30, 2014
    If I recall, mine printed when the display was in the COPY mode.
    Genius:
  • 1,114 Answers
For printing from the computer, I beleive it is 'copy' mode.
Posted on Mar 30, 2014
damanpreet_c
  • 69 Answers
SOURCE: Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Posted on Nov 07, 2008
manojro
  • 495 Answers
SOURCE: Dell Photo 926 Power cable
You can get it from site below:
http://accessories.euro.dell.com/sna/productdetail.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&sku=450-11224
Posted on Jan 08, 2009
SOURCE: Dell 962 Printer won't scan
my scan light will not work
Posted on Jan 18, 2009
Vivektj
  • 55 Answers
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Posted on Mar 02, 2009
  • 164 Answers
SOURCE: scan document as pdf on a Photo 926
open adobe acrobat..not reader, has no ability to create pdf's, and go to file, create pdf, from scanner
Don't forget to rank the advice!
http://www.aa1consulting.com
Posted on Jul 27, 2009
Unable to print 32 printer brother mfc 9490cw
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
Sep 15, 2011 | Brother MFC 6490CW InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
Apr 28, 2009 | Dell 962 Photo All-In-One InkJet Printer
Default printer factory settings Lexmark X8350
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Change default ptr setting for lexmark x8350
4. Press "Select."
7. Press "Select."
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Printer not printing!
You need to reset the Purge Counter.
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log
information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter.
The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jul 16, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-210 printer says unable to change or unable to clean there is nothing caught in printer and trurned it on and off several times
For Brother MFC210C Printer Fax Copy Scan
This is on this website somewhere. I used it and it certainly did fix my printer! This is what I did:
"1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights will flash when in maintenance mode).( The user can establish the internal Machine Error Code as follows: pull the main power cable out of the machine (power off). While holding down the Menu/Set key, re-insert the main power cable into the machine (power on). The internal Machine Error Code Access will be displayed.") Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
Carry on printing !!"
Jul 05, 2008 | HP Deskjet D4260 Printer
Printer want print
OK Try this
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
107 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
