Question about Frigidaire GLER104FSS Gallery Series 27 Electric Dryer, 5.7 Cu. Ft. Super Capacity Drum, 3 Auto Dry Cycles, Balanced Dry System, 60 Minute Timed Dry, Auto Dry Cycles, Drying Rack, Precision Dry Moisture Sensor, Timed Dry Cycles, Cool Down Setting, 4 Temperature
The drum light is out in a GLER104FSS
How to change the drum light
    Problem Solver:
  • 16 Answers
First, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Posted on Mar 30, 2014
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Dryer will not heat and i cant find how to get to the heating element. Need a diagram of how to get to heating element.
Start at your breakers. Turn FULLY off and back on again, and test. Be sure to verify that you have really good air flow outside of the building, restricted air flow will cause overheat interrupters to open heat circuit, they reset when cool.
Dec 23, 2010 | Frigidaire GLER104FSS Electric Dryer
Belt broke... we need to see how to put a new one on...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Sep 29, 2010 | Frigidaire GLER104FSS Electric Dryer
Dryer wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 18, 2010 | Frigidaire GLER104FSS Electric Dryer
How do i get the paper jam light off after i changed the drum?
Go back and check the drum and make sure that you did not bump something else out of alignment while installing it; you should not get a paper change light from changing the drum.
Oct 01, 2009 | Dell 1720dn Laser Printer
LIGHT IS STILL ON WHEN i CHANGED THE DRUM ON THE
clear the drum counter. life than down arow until it says drum counter clear than start 2 times
Mar 23, 2009 | Sharp FO-DC535 Fax
Printer Problems
Hi, it sounds like you need to change the drum. If you are using the High Yield TN660 toner is your printer, then the drum needs changing every 3-4 toners. If using the low yield TN6300 toner then your drum needs to be replaced every 6-7 toners. Hope this helps
Nov 20, 2008 | Brother HL 1440 Laser Printer
HL-2040 CHANGE TONER
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
Frigidaire GLER104FSS Gallery Series 27 Electric Dryer, 5.7 Cu. Ft. Super Capacity Drum, 3 Auto Dry Cycles, Balanced Dry System, 60 Minute Timed Dry, Auto Dry Cycles, Drying Rack, Precision Dry Moisture Sensor, Timed Dry Cycles, Cool Down Setting, 4 Temperature Logo
93 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
