Replacing fuel pump on 2000 E 150 van ,found an additional plug on top of the tank that was broken. What is this plg for ? it is about 2 inches long and has an electrical 3 wire plug.
It has a ford part number f88e / 9co52 /AA /oA2817
    Genius:
  • 1,114 Answers
The plug is for a fuel tank pressure sensor unit.
Fuel tank pressure sensor F150online Forums
Posted on Mar 30, 2014
Hiccups and Backfires, Idles rough - additional details
Hi Donald, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Dec 29, 2012 | 2001 Harley Davidson FLHR - FLHRCI Road...
Tip
2007 Jeep Grand Cherokee Fuel Pump Removal Procedure
<b>INSTALLATION</b> <b>CAUTION: Whenever the fuel pump module is serviced, the rubber seal (gasket) must be replaced. </b><br /><a><br /><br /> 1. Using a new seal (gasket), position fuel pump module into opening in fuel tank. <br />2. Position lockring (5) over top of fuel pump module. <br />3. Rotate module until embossed alignment arrow points to center alignment mark. This step must be performed to prevent float from contacting side of fuel tank. Also be sure fuel fitting on top of pump module is pointed to drivers side of vehicle. <br />4. Install Lockring Remover/Installer 9340 (3) to lockring. <br />5. Install 1/2 inch drive breaker (1) into Lockring Remover/Installer 9340 (3). <br />6. Tighten lockring (clockwise) until all seven notches have engaged. <br />7. Install fuel tank.<img src="ledsled378_2.jpg" /></a>
on Jan 08, 2011 | Jeep Grand Cherokee Cars & Trucks
Fuel pump recplacement
you'll have to drop your fuel tank most likely. best to buy a chilton or a haynes manual for that unless your pretty mechanically inclined. usually there are fuel lines, at least one wire plug, and at least 2 straps that have to be undone before lowering it completely.
Jan 26, 2012 | 2000 Chevrolet Express Cargo
Can I replace a fuel pump in a 2002 toyota sienna? do I need to take it to an expert
Wade, you can do it. just buy a manual for your vehicle. it will give you detailed instructions. Plus you can use it later for other problems that arise. you will have to drop the fuel tank. A novice can do it in about4 or 5 hours on the ground.
Nov 29, 2010 | 2002 Toyota Sienna
Can you replace the fuel pump without pulling the fuel tank
Unfortunately not. I have had some people install a aftermarket high pressure pump inline that has worked however i do not recommend this.
The job is actually not to back, remove most of the gas from the tank, remove the straps ( might need to replace them) and remove the tank partially to expose the fuel line connections. Remove the fuel lines and power connector then remove the tank. Remove the locking ring on top the tank, remove the pump and fuel level sender. Install new pump and re install.
Jul 31, 2010 | 1993 GMC Safari
Where is the fuel filter located on 2005 dodge caravan
It should be found next to the gas tank on the right side, under the sliding door of the passenger side of the van. The fuel filter is cylindrical and about five inches
May 21, 2010 | 2005 Dodge Caravan
How to replace fuel pump on a 2002 ford E-150 van in my driveway.
With a jack under the gas tank...unbolt the gas tank and lower the tank 8 to 10 inches until you can reach the small bolts ( in a 6 inch circle ) that fasten the fuel pump to the top of gas tank. You might need to remove hoses to tank to lower. Disconnect electrical lines to fuel pump and remove.
Sep 05, 2009 | 2003 Ford E150
Where is the fuel filter on a 1996 plymouth voyger?
FUEL FILTER IS LOCATED ON TOP OF FUEL TANK..YOU MUST DROP FUEL TANK SLIGHTLY TO REMOVE LINES FROM FUEL PUMP UNIT..1 BOLT HOLDS IT TO TANK..2 CONNECTIONS AT TANK..1 AT LINE ON FRAME IN FRONT OF TANK
Aug 31, 2009 | 1996 Plymouth Voyager
Engine turns but not starting fuel pump is working 1993 chevy G20. it is getting fuel. it tries to start then just turns over
hmmm. if your sure that it is getting fuel than the starter itslef might be going out...
Mar 30, 2009 | 1993 Chevrolet G20
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
