Question about Skil 5400-01 7-1/4-in Skilsaw
Where do you wire power cord on skil circular saw 5400 to switch
Switch has 4 terminals, does power cord wires go up and on left or right side or side to side
  • millerguy54
    millerguy54 Mar 31, 2014
    Well the switch can only be installed one way. when holding the switch, the part number is on right and another set of numbers is on left. When checking for continuity i get it from the top and bottom circuits on the left, is that where the power cord plugs into?
  • 1,162 Answers
Very easy to tell the short wires go to the cord side. The longer ones go to the motor. The wire will be same color as the cord wires. They will come from the back of the switch as it sets in saw.
Posted on Mar 30, 2014
Testimonial: "This answer doesn't help"
  • cwradio73 Mar 31, 2014
    i have one of these tools the switch sets in the saw different than as you would hold it. I checked again and wires coming from the cord go on the top the wires coming from the bottom go to the motor. unless you have a different design which I doubt, you are looking at switch wrong. sorry but even the diagram that came with switch shows it as I have tried to report.
  • 302 Answers
SOURCE: I have a very old Skil circular saw Model #586.
measure from the center of the shaft to the inside of the guard, double that distance. subtract about 3/4 of an inch and this will be real close to the blade diameter that you need
Posted on Aug 17, 2009
rowdy45176
  • 2176 Answers
SOURCE: Skil 574 circular saw casing gets very hot quite
first off I can't find that model number on a couple site that I use, and second the replacement of the bearings would require disassembly of the gearcase and removal of the armature and also the use of a bearing puller and then a press to put them back on. If you are handy it should not be a big problem, Could you recheck the model number and let me know and I will try and find you a breakdown for this tool before you attempt anything.
Posted on Oct 10, 2009
Testimonial: "Thanks - not a two minute job then. It is a Skill 574 71/4" circular saw and must be over 20 years old now."
  • 885 Answers
SOURCE: We have Skil 7 1/4 circ saw model 5400-01 how do
There is a lever on the back of the top blade guard, if you pull up on it you can adjust the foot up or down to control how deep the blade will cut.
Posted on Oct 16, 2010
  • 142 Answers
SOURCE: I need a switch for a Skil Model 516 Circular saw.
Contact Eurton electric. They stock many switches that have been discontinued by the manuffaturer.310-948-4477 or 1-800-423-4789
Posted on Dec 16, 2011
  • 142 Answers
SOURCE: Skil HD77 that blows breaker
Check the cor first. The switch might have been wired wrong. The old style switch which is an Eaton seithc is wired differen t than the Marquart switch supplied now. An ohme meter will tell you which way the switch contacts work. Another common problem is the field leads will come loose from the rest of the winding and hit the fan on the armature. This can usually be repaired and taped back down so it no longer hits the fan.
My circular saw is not working
Check brushes...
Dewalt Craftsman 2 Pack Carbon Brush Holder for Saws 147097 09 2pk
or sometimes the switch fails...
Craftsman 7621301 Circular Saw Switch
if you luck out, it may just be a broken wire, right at the switch, or right where it enters the saw? Pulling the, or directly on the cord vs. just the plug puts a lot of strain on the wires.
But if it is one of the parts above, very easy repair.
Apr 13, 2015 | Craftsman 7 1/4" 12 Amp Skill Saw
I have to replace the power switch on my Delta Shopmaster 10" radial arm saw. I have the switch, which is a Delta 438010170206S Rocker Switch has (4) terminals. I need to know which wire goes where????
How many wires do you have? The switch is probably a 2 pole, On-Off. If you have 2 wires, connect them to two terminals on one side of the switch (use an ohm-meter to find which terminals make-break). If there are 4 wires, connect the black and white power cord wires to different sides of the switch. Then connect the two motor wires to the two remaining terminals. DO NOT CONNECT THE BLACK AND WHITE POWER WIRES TO THE MAKE-BREAK TERMINALS OF THE SWITCH. This creates a short in the power cord and will trip a breaker.
Oct 29, 2013 | Delta 10" Shopmaster Radial Arm Saw 1-1/2...
I need a switch for my black & decker 7 1/4 worm drive saw model 7395 type 1
That tool was discontinued in 1980 and parts are obsolete. You may be able to use a Skil 77 worm drive switch as many of the circular saw switches were configured the same. The switches are usually marked with a 1 and 2 on the back so make sure the wires are put on correctly as some will have the 1 on one side (top and bottom terminals) while others are on the top or bottom (next to each other).
Aug 05, 2012 | Black & Decker 7 - 1/4" Heavy Duty...
Skil HD77 that blows breaker no matter which plug in I use. This saw was bought on e-bay and does not appear to have abused except for new plug on very short cord. I checked end of plug and it appeaers to...
there is a direct short somewhere, recheck the plug end for correct wiring and if OK then it is in the cord or the motor itself, I would think the cord or plug first.
Sep 01, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
No power when i squeeze the trigger on the hd77
Troubleshoot the problem. It could only be a few things: 1) defective trigger/switch, in which case you can replace it by getting the part from a specialty tool store; 2) the cord itself, either where it plugs into the saw or at the plug end there may be a loose wire; 3) you've accidentally cut or nicked the cord--easily done--and there is a severed wire.
Jul 31, 2011 | Skil Circular Saw 7 14" HD77 Worm Drive
Saw runs while tilted to left but stops when tilted to right while trigger held in on position. Does this sound like a bad switch or bad brushes?
I am thinking a broken wire in the cord. what you can do and be careful is hold saw and while running "wiggle" the cord especially up at the cord protector end, It might also be a loose wire in the tool, but before disassembling UNPLUG tool.
Nov 20, 2010 | Bosch 1656 8 1/4" Circular Saw W/ 60 Bevel
I changed the switch and brushes. Still nothing. cord is new. help if u can>
is the commutator (part the brushes push against) all gouged up? What about wire after switch? Also sometimes the plug itself does not make good contact. Pull the switch and move the plug around in the outlet while you have the switch pulled (Watch out it may turn on) Make sure that there is power at the outlet, and try a different outlet.Check all your connections. My guess is the cord.
Nov 18, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
We have Skil 7 1/4 circ saw model 5400-01 how do you adjust blade depth?
Oct 16, 2010 | Skil Xdrive 7 14" Circular Saw Ships Fast
I'm trying to replace the power cord on my circular skilsaw. How do you get the wires from the old cord to release from the trigger switch?
using a paper clip straighten one end and insert next to wire and push down and while doing so lift the wire out.
Aug 21, 2010 | Skil Saws
I sawed the power cord in half...! It was a skil saw brand But obviously I am 'unskilled'... The saw cost about $65. Can this be repaired or should I get a new saw...?
Yes it can be repaird. No offense, but can you do it? Take handle appart, may have torx screws, and remove old cord. You can buy a new exact replacement cord or a generic cordset to replace. Check wire size on your old cord.
Jul 25, 2010 | Bosch 7 - 1/4" Skilsaw Circular Saw
Skil 5400-01 7-1/4-in Skilsaw Logo
107 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
