Question about Frigidaire Refrigerators
FRT045gm wiring diagram for PTC
I need to put in my new PTC and can't find wiring diagram to make sure I get the wires back on correctly.
  • Mitch
    Mitch Apr 01, 2014
    I solved the problem and the fridge is running again. I watched viideo on Utube and was able to determine the correct placement for the wire
  • Mitch
    Mitch Apr 01, 2014
    Add a CommentThe hardest part of the repair was finding the new PTC relay,
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
hapndnvegas
  • 35 Answers
SOURCE: Wiring a double throw switch in a house
when working with eletricity always make sure to turn the power off !!!! and test for voltage b4 you start working on the wire
here is a diagram that seems easy to understand:
http://mccarthyplace.com/hobbies/electrical/three_way_switch/
if you need help on testing the wires to find out which one is which with a ohm meter just ask
Posted on Apr 03, 2008
SOURCE: Kenmore refrigerator PTC relay for compressor
This is for a Kenmore PTC relay that I just pulled from my fridge. It dosn't have an ice maker. Hope this helps.
Pin 1 = White
Pin 4 = Blue
Gold Pin = Red
Posted on Nov 05, 2008
Molson02536
  • 3854 Answers
SOURCE: installing chip and want to double check wiring. Need to find IAT/MAF sensor diagram for 2003 Ford Ranger
Save your money, the chip is a ohm resistor at Radio Shack for under $2.00. It splices in to you IAT wire harness located at the intake tube between the air filter housing and throttle body.
Problem with this system is, that you can not adjust anything and have to run a constant 91 octane just to make sure you do not have a Detonation. The ECM will catch the Detonation from the knock sensor and compensate for it by retarding the timing which in turn lose of HP till next start up.
If you like and don't mind the check engine light on once and awhile, you can do the same by just disconnecting the IAT wire harness which give the ECM a 0 resistance thinking it's -20 out side and turn the timing up and lengths the injector pules.
When i was running a Nitro in the Toy before i sold it, i had installed a 10K ohm Potentiometer which you can buy at radio shack for under $5.00 i believe, I just spliced it in to the IAC wire harness so if i wanted to play with the Nitro I'ld turn the resistor up making the engine think it's 185 degrees F and would ****** the timing so i would not hurt the engine. But if i wanted to get more timing i would just turn the knob to drop the resistance to get more time since the engine thinks it's -20 out side.
Hope this helps. Keep me posted if you need more info. Best thing is to do a dyno tune and you can change everything right down to the Shift points.
Posted on May 29, 2009
RockyNR1
  • 324 Answers
SOURCE: Kirby Generation 3 Pictorial or wiring diagram
Go HERE. This should be more than enough info.
Rocky
Posted on May 30, 2009
Need a wiring diagram for a Swann security camera model 642 3960 it has 9 wires what I cook the wire where the wires go do the wiring diagram
1) Turn the power off.
2) Remove the printer cover.
3) Remove the ink roller by turning it counterclockwise and
pulling it upward.
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place.
5) Put back the printer cover
Mar 06, 2015 | SWANN Home Security
Put on a new power cord wiring diagram
If you need a wiring diagram for this task you should not be doing the work. Please don't dis-assemble the fan, or try to work on it unless you already know what you are doing, you could easily use the wrong cord or not connect the (rather simple I admit) wires correctly.
Feb 07, 2015 | Dryers
I do not need the wiring diagram for a car. I have
if your just reconnecting the starter wires the terminals are different sizes and the wire eyelets are different sizes to match up with the terminals.
Sep 28, 2014 | Cars & Trucks
Trying to replace the start relay on my Roper refrigerator.
depending on the model and the part # of the ptc overload relay will tell you how to wire it back as was,on some ptc O/L's there are spaces on the component where you just plug it on piggyback to this ptc,if not then all you do is wire the capacitor in parallel to the 2 power pins on the compressor,the cap doesn't actually start or run the units compressor,its there to help suppress the arcs on the relay when it starts,the compressor will operate without this capacitor
May 07, 2012 | Roper Refrigerators
Hello, I have a 85' buick regal and I'm having
This is a tough one with out being able to see the wiring. i will enclose a wiring diagram for the complete lighting system.
You will need to locate the correct wirng and make sure its going to the correct light. Most times a bad ground wire will make the light do funny things like your car is doing. With the diagram i enclose locate the ground wire to the rear lights and make sure ground is good, even if you must cut old ground out and run a new ground to a good metal ground.
Mar 18, 2012 | 1985 Buick Regal
How do I get the wires out of the old 3 speed ceiling fan switch so I can replace it with a new one?
Usually, there is no way to remove the wires from the switch. Turn off the circuit breaker that powers the circuit going to your fan. Then, match up the new switch with the old one to make sure you have the correct one, with the correct amount of wires. Mark the placement of of these wires with masking tape or draw yourself a diagram. Next, you need to cut the wires as close to the old switch as possible, and strip back about 1/2" of the insulation on these wires. Now connect those wires to the leads (wires) coming from the new switch with small wire nuts or crimp fasteners. When connecting the cut wires to the new switch leads, follow the same pattern as the old switch (refer to your masking tape labels or your diagram). Now you can secure the switch to the fan casing with it's locknut, and carefully tuck the wiring back inside. Re-secure the casing to the fan.
Aug 01, 2011 | Speed Ceiling Fan 3-speed Switch By...
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Relay board for thermostat/condenser fan/n compressor need to mak
I have a copy of the wiring diagram for this unit. If you would list your email address, I will email the diagram for you. This will give you everything you will need to insure that the unit is wired correctly.
Mar 20, 2009 | Intertherm P3RA-036K Air Conditioner
Oct 19, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
