Question about Garden
Honda gcv 190
My Honda GCV190 on a Simpson pressure washer turns over and begins to catch (5-10 revs), but quickly dies. I suspected a carburetor or fuel line problem, drained and cleaned the carburetor and jet, put in new stabilized fuel - and still can't get it to run. Spark plug looks OK (light tan), but could it be the problem? Kent
  • dkentstewart Apr 01, 2014
    Finally found a repairman in Lahaina, and the inner plastic seal between the engine block and carb was cracked, allowing air in, and the main jet was not fully clean. Working now!
    Top Expert:
  • Garden Master
  • 12,962 Answers
If it begins to catch then you definitely have ignition. Try replacing the plug with same type. If same result, the main jet in carburetor is clogged or the needle valve is stuck and not allowing fuel to enter into motor.
Posted on Mar 31, 2014
Testimonial: "Thank you, richie - I am about to replace the spark plug, having already removed and cleaned the needle valve as well as the main jet. Have fuel flow to the carb, but it just seems to hold for 2 seconds at start and then die. The float floats, and moves freely. More after I put in the new plug."
5 Suggested Answers
SOURCE: my honda gcv 160 pressure
Try this website at http://forums2.gardenweb.com/forums/load/lmower/msg0312290415003.html
Posted on Mar 12, 2011
  • 57 Answers
SOURCE: We have a Honda GCV 190 gas pressure washer. It
check that the fuel tap is on
Posted on Dec 19, 2010
SOURCE: Honda GCV160 5.5 on a pressure washer runs only intermittently
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
Posted on Jul 31, 2009
  • 26 Answers
SOURCE: I have a Honda 5.5 HP. GCV 160 pressure washer
You need to clean the carburetor. The bowl on the bottom of carbutetor has a bolt that holds it on. Remove this bolt and slowly remove the bowl. Be sure to have someone hold the float because if you remove the bowl without supporting the float will drop and the needle valve will fall out. Then you will have to remove the entire carburetor to put back together. Once you get the bolt out you will have to clean the holes in the bolt this is actually the high speed jet. Run a wire through holes and clean with carburetor cleaner. Hope this helps, let me know how you make out.
Posted on Jul 26, 2011
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Feb 21, 2015 | Simpson MSV3025-S Megashot 3000 PSI Honda...
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
I need a Honda GCV 190 operation manual that is on a Ryobi 3100 psi power washer
Please click on the link for the operators manual for your engine a Honds GCV190
Hope this helps
Brad
http://cdn.powerequipment.honda.com/engines/pdf/manuals/00X31Z8B0240.pdf
Jul 29, 2014 | Garden
I put 2 cycle gas in my 4 cycle Honda gcv190 pressure washer
did you pull the spark plug out and clean it ? if you did , did you also put the starter cord and turn the motor over without the plug installed to get rid of the 2-cycle oil out of the cylinder ? if not do so.
Jul 19, 2013 | Honda GCV190-N5AP 187cc GCV190 Series OHC...
My Honda GC160 engine on my pressure washer is next to impossible to pull start. I have checked and added oil to make sure it is full. Still no luck getting it to pull.
honda pressure washer ohv was running great died like someone turned of the switch ! has spark, oil full, sparkplug looks good any ideas please.
Mar 31, 2010 | Karcher 2500 PSI Pressure Washer
Garden Logo
382 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
