Question about Kenmore Dishwashers
Replacing the control panel on my kenmore 665 dishwasher
I got the old control panel off but I am having problems getting the new one to snap into place. It is off by about 1/3" so the screwholes won't line up.
  • 85 Answers
Double check the part #...match the two together. If everything is the same other then holes see if you can hook up to work...if it does make new holes.
Posted on Mar 31, 2014
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
eagle338
  • 4889 Answers
SOURCE: kenmore dishwasher touchpads
Yes you can surely do it yourself..its just unplugging a few wires remove the old one and just install the new one..
I couldn't find the model number you have specified, but you can give these guys a call and specify ask for a new touchpad for kenmore 16372. They will ship it out for you.. I advise you call their toll free number that you can find on their site so that you can get it done real quick.. http://www.laundryparts.com/sunshop/index.php?action=category&id=bestsellers
Posted on Mar 14, 2008
reg501
  • 413 Answers
SOURCE: I have a kenmore 665 dishwasher where the spary arms do not spin.
  • First, check water level. Start machine, wait until the machine begins main wash. Open the door, the water level should be just below the heater element. If too low replace inlet valve.
  • If you can't hear the wash motor running or is just humming, the motor may be bad.
  • To check if the food chopper is blocked or broken;
  1. Remove lower spray arm by holding the arm and rotating the spray arm retainer.
  2. In the back of the tub, unclip or remove the screw from the upper spray arm supply tube.
  3. Rotate the lower spray arm support to the right while disconnecting the supply tube from it.
  4. Remove the four torx screws from the sump cover, remove assembly.
  5. There may be a primary filter in the left side of the sump, if so, remove the torx screw and the filter.
  6. On the right side there is the chopper assembly cover. Remove the torx screw and cover to expose the chopper.
Hope everything goes well for you,
Regards
Richard
Posted on Feb 03, 2009
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
  • 530 Answers
SOURCE: kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Posted on Jun 02, 2009
Kenmore DW model #665 16023403 will not turn on. There is power to the DW but the panel does not light up. Checked circuit breaker. Door tightly shut and latches. Just 3 yrs old. Would love to fix myself....
The electronic control panel should be replaced and cost about $240. It is easy to remove and replaced --- pull and plug like a standard elect plug, only its flat.
This definitely works.
Sep 04, 2012 | KitchenAid 24 in. KUDP01IL - Multiple...
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Kenmore 665 no lights on panel water in bottom
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher 665 Lock on light
You may have a stuck button as this will cause flashing of lights, try pushing button and see if it returns if not strike lightly above it with plastic spoon etc.
If this does not work u can buy the control panel from Sears for 190.00 but first go to searspartsdirect.com then type your model no. In required space click on shop parts on appropriate model, then go to troubleshooting then to won't start, then go down to how to replace control panel.
According to instructions you will only need torx screwdriver and less than 30 minutes to replace.
Jul 13, 2017 | Kenmore 16602 / 16604 / 16609 Built-in...
Where is the thermal fuse for Kenmore 665 11073342 dishwasher?
The thermal fuse is located in the front control panel where the circuit board is. You need to remove 4 screws(depending on the type of dishwasher you have) and you will see it. Make sure you change everything not just the fuse but the new wires also.
Hope this fixes your problem
Feb 02, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
May 20, 2008 | Dishwashers
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
May 07, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
