Sanyo hdtv with rca flat antenna with only 1 channel found
Only 1 channel found
    Genius:
  • 1,039 Answers
Did you do channel scan? Set to antenna?
Posted on May 13, 2014
  • 520 Answers
SOURCE: connecting antenna cable and cable from cable company
Use an A-B switch.
Posted on Jun 26, 2008
freetek
  • 5568 Answers
SOURCE: sanyo HDTV 42"
'Clear' can mean different things-
The 'front end' of TV sets can differ greatly in the sensitivity of its tuner.  If you have 'snow,' then the new set is inferior to your previous one and you may need to buy an external broadband amplifier to boost the signal before it goes to the TV. The quality of antenna inputs has declined since there are fewer owners (by percentage) who depend on 'over the air' reception. Cable companies and satellite receivers supply a lot more signal than can your antenna so the input sensitivity is not as critical as it once was.
The demo sets one sees at retailers are fed a lot of signal and have for that reason a better picture than you might find after getting a set home.
Posted on Oct 31, 2008
SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Posted on Jan 24, 2009
  • 5101 Answers
SOURCE: can't get all digital channels
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Posted on Feb 07, 2009
  • 58 Answers
SOURCE: I have an rca flat antenna. June 12 I rescanned
you probably need a digital converter box
Posted on Jun 15, 2009
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Can i use a digital converter on my Sanyo DP 42849
Sounds like you need a stronger antenna or to adjust your antenna. It's pointless to put a digital converter box on your tv as it already has the capabilities of reading digits signals built in.
Jul 25, 2016 | Sanyo DP42849 42 in. HDTV
The model # is: L42FHD37. I need to know how to set up an amplified indoor HDTV antenna. RCA multi directional serial # ANT1450BFW.
Attach the antenna to the antenna/TV input on the back of the TV. If you have a flat twin lead wire on your antenna, you'll need a co-ax converter. (Best buy, etc.) Power on the TV (and the amplified antenna) and use the Input button on the remote to select the TV input. Next use the menu button to select channels and then engage the auto-search option to memorize all of the available channels in your area.
Feb 29, 2016 | RCA Lg 42ls5700 42" 1080p Flat Panel...
My rca indoor antenna will not pick any channels up on my hd flat screen tv
Signal not strong enough in your area for this indoor ant...Does it work with an outdoor ant?
Nov 29, 2013 | Televison & Video
I cannot get regular tv to come in and my antenna is hooked up properly
Here is a few suggestions:
1) Make sure the tv's vide mode is in "TV" or "ANT" or "Antenna" some times even referred as "Off Air"
2) In the TV's settings make sure a "Channel Scan" has been performed to tell the TV which channels are available in your area. If this is not done you won't be able to select any channels. Also make sure that the antenna is of the right impedance (i.e. 52ohms) check your manual and see what your TV accepts.
3) Make sure that you are using coxial cable connection and not RCA or HDMI connections as these connections are not designed for an over the air antenna.
Mar 02, 2011 | Sanyo 42 in. LCD TV
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
Jun 13, 2010 | Sanyo DP32648 32 in. LCD TV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
New dp 19648 sanyo hdtv no signal detected
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Dec 24, 2008 | Sanyo DS27820 27" TV
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
