I have a Mitsubishi HD 1080 medallion that will not stay on the green light will come on but goes off immediately sometimes the TV will stay on for days but most the time it refuses to turn back on although I have no idea what diagnostic tests and digits mean I did read to hit the end button menu button and it blinks twice then blamed four times can someone please help me figure out what needs repaired or replaced
  • 3 Answers
SOURCE: Mitsubishi HD TV 1080 blinking green light
sounds like it has a bad DM assy, or a bad 9v reg ic.
the dm can be repaired, there are 4 capacitors on it that need to be replaced.
Posted on Dec 13, 2007
  • 1030 Answers
SOURCE: Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Posted on Jan 08, 2008
SOURCE: Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
Posted on Mar 22, 2009
SOURCE: mitsubishi hd 1080 medallion
i have a green screen on my mitsubishi medallion hdtv 1080
Posted on May 04, 2009
SD Tech
  • 14553 Answers
SOURCE: mitsubishi vs-60705 grenn power button goes on
It is an error code for short protection---the most common cause for this is one or both of the pico fuses that protect the convergence IC's are bad--set will detect no voltage and instantly shut off.
I do this here for free so if this has been helpful give me a vote here. if you have questions or need help:
etower.766@netzero.net
Posted on Aug 22, 2009
I have a Mitsubishi medallion 1080 Hd tv that as I'm watching it It turns off and no matter what I do it just stays on for like five seconds than turns off agsin
This just recently happened to my Samsung DLP. It's a pretty easy fix. You need to replace the lamp. Check your manual for the particulars of that model.
Mar 02, 2015 | Mitsubishi Televison & Video
Mitsubishi medallion hd 1080
I would try the reset button in the front. Unplug the set push the reset and plug it back in.
Mar 27, 2014 | Televison & Video
My Mitsubishi Medallion 1080 won't turn on
Are you sure its the right remote? Verify TV mode on remote if equiped with mode switch. Drain the remote by removing batteries.
Jun 27, 2009 | Televison & Video
Can't loate bool;et for Mitsubishi HD 1080 Series Medallion
it is usually in the Audio settings,sometimes by the CC settings, if you go to the TV and enter th menu from the set, go thru one at a time until you find the spot to turn it off, it is under options or Menu on the remote also, there maybe an SAP Option on the remote itself, but you may have to press another key first like a "Function: Key.
I hope this helps some, if so please give me a good (fixya) rating. Thanks and have a Blessed Day
Apr 08, 2009 | Televison & Video
Green light flashing
This is most commonly caused by the Formatter not booting up. The cure is to replace 4 capacitors on the Formatter board 1000 mfd @ 16vdc. The Formatter is the large stand up shielded board on the left as you look in from the back of the set. The capacitors will be domed on top if bad.
Dec 11, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi 1080 HD Medallion
If the LED doesnt light. Check the fuses. the fuse many be blown. Unplug the set before you check the fuse.
Jun 14, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi hd 1080 medallion
May 30, 2008 | Televison & Video
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
