Question about SkyScan 86742 Digital Atomic Wall Clock
I have a skyscan atomic clock that went haywire after dst I can't set the clock date or temp. What can I do buy a new one?
It has 4 buttons set, +,alm, and snz
  • 2,509 Answers
Remove battery for a minute, reinsert battery and allow clock to settle (15 min) now try.
Posted on Apr 28, 2014
3 Suggested Answers
SOURCE: cannot properly reset skyscan atomic clock
press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time.
thanking you.
Posted on Nov 19, 2008
SOURCE: Manual Information/Owner Guide
In order to toggle display of Temperature, Seconds, Day of Week, and Month, hold + and press Set once. Release and repeat to move through the various display configurations.
Posted on Apr 07, 2009
Clock did not change after dst. Also day is wrong and temp is showing vin Celsius not Fahrenheit
Make sure you put in the right location and timezone in the settings. There is also a checkbox for automatic daylight savings time.
Mar 29, 2014 | SkyScan 31981 Atomic Desktop Clock
Cannot get my atomic clock to reset to proper time
Make sure that it has fresh batteries, set it for the correct time zone, set the DST switch to ON (unless your time zone does not use DST), then place the clock on a solid surface, outside if possible, so that the face of the clock is pointed roughly towards Fort Collins, Colorado. It should reset in a couple of hours - or less.
Aug 07, 2010 | SkyScan 86709 Atomic Wall Clock
Have a sky scan atomic clock model 86715. it does not adjust when we have the time change. What can I do to correct the time.
If this model has a DST switch on the back, make sure that it's turned ON. If there's no DST switch you can force a manual change by changing the time zone setting, but you'll need to do that twice a year. Also note that if the clock is more than two years old, turning the DST switch ON will make the clock conform to the old DST changeover dates.
Bill B
Apr 03, 2010 | SkyScan 86709 Atomic Wall Clock
Skyscan atomic wall clock 87315. Changed battery
Press and hold the set key until time zone appears, then + or - to your zone.
Jan 31, 2010 | SkyScan Audio Players & Recorders
We replaced the batteries on our SIO SCAN temp transmitter but it still will not register the outside temperature--what do I do?
Take the batteries out of the clock AND the temp transmitter. Wait about a minute, then replace the clock batteries. Wait another minute, then replace the transmitter batteries. Once the clock synchronizes with the satellite, you will need to set the time zone and whether you want DST on or off.
Dec 08, 2009 | SkyScan 86709 Atomic Wall Clock
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
SkyScan 87801 how to reset time
Keep pushing the set button until dst shows on the date window then see the clock window it will read on or off press the + button for on or off.
Sep 15, 2008 | SkyScan 86709 Atomic Wall Clock
I have a87900 model skyscan,can;t get it reset after replacing batteries
Just did this after problem resetting after changing batteries, press setover and again til it displays est, then press+until your time zone is displayed, it will also display dst, press +till on/or off depending on your location, then US will appear, clock will then set itself. Good luck, how frustrating.
Dec 17, 2007 | SkyScan 86742 Digital Atomic Wall Clock
Atomic clock
There is a setting on the clock to turn on "DST"- daylight savings time feature. You have to push the set button on the back of the clock repeatedly until you see "DST" blinking. You should also see "OFF" blinking at that point indicating that the feature if turned off. If you now push "+" button on the back of the clock once it should show "ON" blinking instead of "OFF". Hope this helps.
FixerUpper
Nov 04, 2007 | SkyScan 86709 Atomic Wall Clock
SkyScan 86742 Digital Atomic Wall Clock Logo
227 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a SkyScan Home Expert? Answer questions, earn points and help others
