Question about Maytag MZD2766GES Side by Side Refrigerator
Not freezing or cooling and compressor clicking on and off
Woke up this morning to puddle of water on the floor in front of freezer. Freezer and fridge cool inside but not cold. Took off back panel and panel inside freezer. Coils not frozen but discovered defrost sensor/thermostat that clips to top of coils was loose. Reattached. Plugged back in. Fan in freezer and fan to cool compressor are both running constantly and compressor is warm and vibrating -- but sounds like it's clicking on and off every few minutes (there's a clicking noise and humming drops to lower tone and then about a minute later there's another clicking noise and humming goes up). Ideas on what else to check or should I just leave it alone overnight and see if it cools now that defrost sensor is reattached?
  • 23 Answers
From your description it sounds like the start components (start relay, overload and capacitor) are having problems. The clicking you hear is probably the overload kicking out to protect the compressor. It is quite possible that the compressor simply has gotten too hot and after sitting a while will restart when plugged back in. The start components are not generally considered 'user serviceable' parts. When the compressor has cooled to pretty much room temp, plug it in and be listening for those clicks. If you hear them, unplug it because it could eventually damage the compressor. Those components give the compressor an extra jolt to get the compressor running then they drop out of the circuit. If the compressor doesn't start, it creates heat until the overload drops out.
Posted on Mar 29, 2014
  • 2 more comments
  • Victoria Cook
    Victoria Cook Mar 29, 2014
    Thanks. I've unplugged it and will let the compressor cool down as you suggest and then see what happens when I plug it back in.
  • Victoria Cook
    Victoria Cook Mar 30, 2014
    Plugged it back in and still heard the clicks with no significant cooling happening. I've unplugged it for now. Any other suggestions on figuring out which part needs replacement appreciated.
  • Tim Bennett Mar 30, 2014
    I would start with the run capacitor, it is the most common part to fail. Here is a link for you if it pastes correctly. http://www.partselect.com/ModelSections....
    If the capacitor doesn't take care of it then you will need the relay, overload kit. There are two kits based on the serial number of your unit, and I don't know how to tell the difference.
  • 884 Answers
Sounds like the compressor has failed. Rarely a new relay and capacitor will do the trick but more normally it's the compressor itself. Decide whether it is worth spending money on to get repaired, or buy a new one
Posted on May 14, 2014
aborcass
  • 2651 Answers
SOURCE: Freezer not freezing
thats your overload relay , trying ti start your compressor, you can try to replace the overload/relay.part number 12002784. however if the unit is under 5 years oldyou should have compressor coverage through the manufacture,and the overload relay comes withthe new compressor
Posted on Nov 18, 2008
SOURCE: Maytag fridge made some clicking noises and then stopped cooling
For what it is worth. I had this problem twice and both times the compressor ad to be replaced. Ton this day it sounds like a pin pong game whenever it runs. No it is not the fans or the ice maker.
Posted on Feb 13, 2008
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
  • 363 Answers
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Posted on Jul 28, 2009
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
Freezer freezes up. we have made sure that it is not overloaded. when it thaws large puddle of water on floor
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Amana ABB1927DE Bottom Freezer...
Went of vacation and just returned to a puddle of
your ptc relay and contactor on the compressor body is defective,unplug the unit,remove the spring wire or clip that holds it onto the compressor and install a new one,also if it has a run capacitor replace this also
Mar 18, 2010 | Freezers
Woke to water all over floor. Condenser too hot to
is it clean? compressor out on over load. call for service.
Jun 20, 2009 | Freezers
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Aug 08, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Freezer stopped freezing...Frigidaire Side by side PLHS267ZAB6
Oh dear. I think you need to find helpful neighbours to keep things frozen while ths is sorted out.
If the compressor is still running, there can be 2 causes for this.
#1 The compressor is not pumping, but vibrating (making more of a buzzing sound than normal).
This is a realatively quick fix needing just a component replacement.
#2 The refrigerant gas has escaped, so there is nothing to pump.
This is usually impossible to repair on domestic models due to construction methods.
If the compresor is just running normally, then this is what's happened I'm afraid.
Hopefully this information will assist you to take the right action.
A rating of Fixya is usually given for accurate concise information, with helpful and thanks given to partial solutions.
Thank you for using Fixya!
Jul 03, 2008 | Refrigerators
Refrigerator consisently buzzing...freezer defrosted overnight
Not enough information to correctly offer , a diagnosis but, a buzzing sound could mean the compressor is attempting to start but can't. or it is running without freon. You will need a diagnosis from a certified technician for this issue.
Oct 18, 2017 | Refrigerators
Maytag MZD2766GES Side by Side Refrigerator Logo
203 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
