Question about HP Pavilion 753n (P9852AR#ABA) PC Desktop
How do you remove the processor cooling block.
I need to replace my power supply in this machine, and to do so I have to move the monsterour cooling block on the processor. I can't for the life of me figure out how to get this thing unlatched. It looks like you would simply press down and away on the metal tabs, but it won't budge. Any ideas?
    Sergeant:
  • 240 Answers
This is a very old machine, close to 10 yrs (approximately). I cannot find a picture of it with the access panel removed so I have to go on gut here.
First, the latchings of the CPU heatsink & fan will vary from year to year and even between models. Some computers have the CPU physically riveted to the motherboard and it cannot be removed. If you break the seal between the bottom of the heatsink and the CPU (immediately below it) you will have to clean both sides to remove the thermal grease, re-apply fresh grease and remount it when done. If you have never done this, do you homework first because you can blow the processor if done incorrectly. At best the unit will not power up. Next, I have worked on a lot of these old units that come across my bench and never saw one yet that necessitated the removal of the heatsink to remove the power supply and I have worked on a lot of them. But without a picture it's difficult to give exact advice.
The latches all work on basically the same principle: the heatsink mounts on a frame almost touching the CPU; there is usually a cross bracket running across the top, and down to the latches on either side. Usually a screwdriver is used to press down on one side and the "hook" disengages from the frame thus freeing the heatsink and fan assembly. Now you must be careful. Over years the thermal conduction grease dried and hardens, "gluing" the heatsink to the processor; if you just rip it off it may tear the CPU off the mounting frame and damage it. So you have to "work" with it, a slight, gentle "rotation" pressure side to side with a gently pull, and sometimes that doesn't even do it. Then a safety razor blade worked underneath may loosen it enough for removal. It gets dicey. Again, without pictures I am flying blind.
I suggest that you may want to go to www.suggest-a-fix.com for more in-depth help, that (free) forum is more suited to this kind of thing than here. I hang out there and can help you further. Wish you the best in your project!
Posted on Mar 30, 2014
Testimonial: "Thanks, Rich. Yes, it's an old machine, but I need XP to run a scanner that will scan large transparencies. There isn't a Win 7 update because it, too, is old with no affordable replacement. This CPU doesn't have a fan as part of the assembly. I'll check out the other forum. Maybe I can post a picture."
2 Suggested Answers
sparky1500
  • 1066 Answers
SOURCE: well i have a compaq
you can use these processors:
AMD Athlon 64 (3000+ - 4000+)
AMD Athlon 64 FX (51 - 60)
AMD Athlon 64 X2 (3600+ - 4800+)
Some AMD Opteron 1xx series
Some Sempron 3x00+ (Step E3,
any standard wopeer supply will do, and you will need a more powerfyul power supply for a mre powerful graphics card.
you can get any pci-e card. an nvidia 9800gt used to be the 2nd best graphics, but its now the minimum card for gaming. I wqould reccomend a 9800, or at least an nvidia gtx260. the higher the numper, per series, and the 4xx and 5xx series are btter than the 2xx. be sure to check the graphics card for reccomended power supply rating.
for the ram, you need pc3200 DDR ram(DDR-400) or higher DDR ram, not compatible with ddr2 or ddr3.
Posted on Mar 18, 2011
Computer overheating
Check the machine for dust, and us canned air to move it out. Make sure that your fans spin upon powering on your machine. Fan controllers can be downloaded to help boost fan speed and cool the machine. Make sure you're not placing the laptop on anything preventing airflow, like carpet or blankets.
Nov 10, 2012 | Dell Computers & Internet
AMD Athlon 64 X2 Cooling System Failure: My computer suddenly turned OFF as if it was unplugged. i opened the cpu casing and cleaned the inside hoping it will solve the problem, but when i plugged the...
Hello
Sounds like you need a new cooling fan.You may be able to save yours with some electrical contact cleaner spray.
Remove fan and spray.
The cpu will heat up quick and shut down everything to protect itself.Im sure once you get a new fan you will be up and running again.
You may consider reapplying new conductive paste to the processor while you have the case open.
Aug 09, 2011 | AMD Athlon 64 X2, 2 GHz 4600+...
Have a precision 530 with a flashing amber power button and just the B diagnostic light in yellow. When I hold the power button to make it turn off, I get only a yellow A light. I've reseated everything...
Hi.
This is probably due to the power supply being bad and could possibly need replacing.
Remove the power cord from the back and all the devices like the hard drives and optical drives and then try removing the power supplies block connectors from the motherboard. This is the white or yellow 20/24 pin connector that comes from the power supply. There should also be a 4 pin block connector that is somewhere near the processor.
Remove these for a couple of minutes and them plug them back in again, see if the machine boots up. If it does the reconnect all the deives one by one.
Hope this helps, regards.
Jan 25, 2011 | Computers & Internet
Computer shuts down on its own
Most likely when a computer shuts down on its own it is because the computer processor or power supply is either overheating or is under powered.
Feel with your hand around the computer case and back of the power supply (has circular fan usually/ on off switch/ and a plug goes into it)
If it is very hot you will have found your answer.
Did you just install or upgrade a processor? If so you may need to check to make sure that there is thermal compound (artic silver, etc) between the processor and heat sync. This can cause overheating and sudden shut downs. If not move on
Is your computer in a small enclosed area? Try moving it to an area with more area for ventallation and cooling.
Do you have adequate cooling/fans? are they working? if not check power cables and may need to replace the fans or install more. You can buy and install case fans pretty easily
DUST. Are the fans and imputs dirty? Keeping them clean will keep the computer running cooler and help lower temperature and avoid shut downs. If your fans/imputs are dirty remove dust by using a can of compressed air, a vacuum made specifically for pc/electronics. or you may wipe them down with rubbing alcohol and a dust free cloth.
This should help Anthony
Jan 18, 2011 | Dell Inspiron 530 Desktop Computer
Have a e machine fan runs but connect monitor to another computer it works. smell a burning smell when turn on pc. Got it to come up once by unplug power hold on button 45 seconds plug in and turn on came...
The smell is the Power Supply.
Typical example of a Power Supply not installed in a desktop computer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4435072&CatId=106
[ NOTE*
This is not an example of a direct replacement Power Supply for your computer. I would need to know the Model Number of your eMachines to give exact information ]
Bad Power Supply. Weak voltage power rail. (Or rails. There are three main voltage power rails for a Power Supply used in an eMachines desktop computer)
Enough power to light LED lights, and apparently spin fans, but Not enough to turn the Processor on.
Watts = Voltage times Amperage.
One measurement used for measuring the maximum available power output, of a desktop Power Supply, (SMPS. Switched-Mode Power Supply), is to state the Maximum Wattage available.
Typical maximum Wattage available for a typical eMachines Power Supply, usually averages from 150 to 300Watts.
1) ALL of the LED lights on at one time, will use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
(Note* Intel Pentium II processors use less than 51 Watts)
Solution is to replace the Power Supply.
This isn't as hard as it 'sounds', if you have never performed this procedure before.
I know you can do it.
1) http://www.fonerbooks.com/r_power.htm
2) http://www.videojug.com/film/how-to-install-or-change-my-computers-power-supply
3) http://computer.howstuffworks.com/power-supply.htm
If you need guidance in replacing the Power Supply in a step by step for your eMachines, please post in a Comment. (Believe upper right of your page)
Should you also desire recommendations to compare for a Power Supply, I would be happy to provide them.
Regards,
joecoolvette
Dec 01, 2010 | E-Machines eMachines Desktop PC
Switching on but only stays on for a couple of seconds before going blank. If switched off and on it will come on but only stay on for 2/3 second,
Most of the time, owners never clean out the inside of their desktop computer, nor have it done.
Hardware components inside the computer, need a steady supply of air rushing over them, to keep their temperature down. The main hardware component that requires this, is the Processor. If the processor becomes too hot, it is turned off. (BIOS program turns it off)
Without the processor running, there is no computer.
The processor has a Heatsink, and Fan, (Sitting on top of the heatsink), to draw away the heat given off by the processor.
The heatsink is a finned piece of metal, attached to a metal base.
As heat is given off from the processor, it is drawn into the base of the heatsink, and radiated out by the fins.
If the fins become clogged with dust, dirt, hair, and other foreign material, the cooling capacity of the cooling system, drops tremendously.
If the fan blades, center hub, and outside cage of the fan, become clogged with foreign material, the cooling capacity drops termendously.
This in turn, allows the processor to heat up beyond it's thermal operating range, and the processor is turned off. This is a Fail Safe option that is built-in, to keep the processor from burning up.
This is also why it is imperative to keep the heatsink, and fan clean.
Solution for this is to remove power to the computer, (Unplug the computer from surge protector), open the computer case, and use a can of compressed air for computers
There is a Thermal Paste compound in-between the Heatsink, and the Processor. This could have dried up.
The bottom of a Heatsink, and the top pf a Processor have rough surfaces. This cannot be seen readily by the Human eye, but can under magnification.
When the two surfaces, (Heatsink bottom, and Processor top), are mated together, there are Air pockets in-between them, or Voids.
The Thermal Paste fills these voids, and allows better heat transference.
Solution for this is to remove the old thermal compound, and apply fresh thermal compound, (Paste)
The rest of the inside of the computer, needs to be kept clean also. Dust and dirt, are 'magnets' for static electricity. Static will fry out delicate computer hardware components. (Can of compressed air for computers)
Also the Power Supply. The Power Supply has it's own fan to keep it cool, and this fan's blades, center hub, and outside cage, need to be clean. The inside of the Power Supply should be clean also. There are heatsinks inside a personal computer power supply.
The Dell Dimension 2400 has been around for quite a while, in computer rated time. Came out in 2004.
If this is the original power supply, the power supply could be bad.
Electroytic Capacitors may have gone bad. Rectifier bridge, and also IC's.
Solution is to replace the power supply.
Oct 15, 2009 | Dell Dimension 2400 PC Desktop
Video went out-mb looked like 5 or 6 bulging capacitors. replaced with used same mb, used processor. did not start up with 500watt power supply. do i need to replace with emach power supply? emachC6423
Probably not providing the block connectors are the same.
Make sure you have your memory seated properly and also clear the CMOS if you have the option. If you don't remove the power supply to the motherboard and take out the CMOS battery for an hour.
While you are waiting take a close look at the caps that you replaced to make sure the are the right way round, use the other motherboard as a guide.
Good luck.
Sep 28, 2009 | E-Machines eMachines Desktop PC
Dell Optiplex GX270 sounds like a jet taking off. What is wrong and what do I need to do to fix it?
You have to find out where the noise is coming from. It could be;
1) a fan on your motherboard if it has one
2) the fan on your heatsink that keeps your cpu cool
3) the fan on your power supply unit
4) a cd or dvd rom drive
5) one of your hard drives
6) one or more of your case fans.
7) a fan on your video card if you have one.
You don't want to open your power supply, so if this is the cause of the noise you can replace the whole PSU. Other than that, any other component listed above can be replaced by going to newegg.com for parts.
Good luck,
Hank
Sep 14, 2009 | Dell Heatsink and Fan Optiplex GX270 K4598...
I cannot get my w3611 machine to turn on, what can I check?
Replace the power supply. 70 to 80 percent of the computers that come to my shop are dirty inside, and the power supply has failed because of this.
Even if you get a green power light, your power supply isn't supplying enough power to turn the processor on.
All the lights use less than 1 Watt.
Harddrive just sitting there spinning, uses about 3 to 5 Watts.
When it's time for the processor to turn on, the power supply can't handle it. Not enough power! Processors use 55 to 125 Watts, depending on the processor!
Jul 02, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
How to replace the power supply on a powermac G5
I would be very cautious doing this, if you are not an Apple tech. You can damage the connector for the G5 Processors, and render the machine un-usable.
You have to remove the RAM and Processor, then remove the two power connectors that connect from the power supply to the logic board. On the bottom, underside of the chassis, there are four screws. Remove them, then you can tilt the power supply out of the bottom of the unit.
Replacement, is just the reverse.
Apr 17, 2009 | Apple Power Mac G5
HP Pavilion 753n (P9852AR#ABA) PC Desktop Logo
57 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
