Snapon solus eesc310 shows only incorrect frozen data on 2003 honda crv reads trans & abs ok
Bad data
  • 333 Answers
SOURCE: Replace Timing Chain for 2003 Honda CRV?
Rule of thumb this is a timeing belt and it should be changed every 75,000 mile as a general practice. I hope this helps, dont forget to rate my answer, thanks
Posted on Feb 20, 2009
  • 39 Answers
SOURCE: 2003 Honda CRV Bad Vibration between 35 and 50 mph
check the trans mount.
Posted on Oct 24, 2009
peterrance19
  • 399 Answers
SOURCE: 205 honda crv, vsa, abs, and triangle lights are
check your warrentry y could be covered
Posted on Nov 13, 2009
SOURCE: both abs and traction control light stays on also
had my 2000 chev impala 3.8 liter ,traction control llight and abs light both go on the reset it and go right back on .so i replaced both sides of the bearing hub assembly this is connected the senser,so far so good.replaced it dec 21 2009 about 3 hours ago. because the assembly came appart when took off.
Posted on Dec 23, 2009
  • 10865 Answers
SOURCE: the ABS light stays on whilst driving on a Honda CRV
Hello. This indicates that you have a bad sensor or a problem with the antilock braking system [ABS]. If your brakes no longer pump themselves when you make a quick stop you know that the antilock braking system is not working. If they still pump, the problem is more likely in sensor to the ABS system. Joe
please rate my answer as very helpful. Thank you.
Posted on Apr 20, 2010
Testimonial: "great answer and much appreciated cheers"
Wonder if i can program keys with this on 06 honda
I`d advise you to take it to the Dealer, as Its not an easy fix...
May 03, 2016 | Honda Cars & Trucks
07 crv honda resetting abs light
If you clear the light,you clear all data needed
to find the problem & make the required repairs
If you made the repairs, the light will go off, when
you drive about a miles or two, at 22 mph or more,
when the abs system runs a self check
Aug 16, 2014 | Cars & Trucks
2003 Honda Odyssey Code P0420 and related TCS Codes 31-2 / 61-1. Also recieved a note from dealer saying "This is AHM Position regarding P0740." They want to replace the transmission and a computer for...
PO420 is a bad exhaust converter,that tells you the motor
has not run well in years & ruined it
You don't go to a dealer to start with
Now the $6000.00 trans price should tell
you that is your last time to any dealer for
service,common sense
Go to a trans shop if you got trans issues
The other Codes you Google & read up
OBD PO740 etc
Aug 01, 2013 | 2003 Honda Odyssey
How to reset abs light on crv 2003
The ABS system means the Antilock Brake System. If the ABS lights on the dashboard permanently the ABS system is faulty. You must access the ABS Electronic Control Unit (ECU) memory to pull out all DTC (Diagnostic Trouble Codes), using diagnostic equipment connected to the data link connector of the car. Then you will be full informed about bad pieces (e.g.: front right wheel abs sensor interrupted, ...). After bad pieces replacement you will be able to erase all faults memored by ABS ECU, in other words reset the ABS system and turn off the warning lamp on dashboard.
Oct 23, 2011 | 2002 Honda CR-V
Hi! My 07 CRV has ABS system. Because in MN
Grinding noise from your brakes means you need to inspect the brakes and change the brake pads. the wise thing to do. Good Luck
Feb 08, 2010 | 2007 Honda CR-V
Both abs and traction control light stays on also spedo not working have checked all related fuses all ok have tried to scan with both snapon solus and launch x431 niether will communicate with abs ecu but...
Oct 30, 2009 | 1997 Acura CL
I BUY A SOLUS PRO AND I DONT NO HOW TO USE IT AND ALSO WANT YOU TO SHOW ME ALL THE PARTS I NEED TO USE THE MACHINE
Hi!
Here is the users manual for you:
http://www1.snapon.com/display/DocMgmtDisplayFile.aspx?fileid=4667
You will find all the parts and everything else there is about your Solurs Pro
Good luck to you
Please take a moment and rate my help for you
Nic
Feb 25, 2009 | DeLorme Solus Pro 2.0 Full Version for PC
Hi, i want buy a ship (short money) code reader from ebay that reads Mitsubishi colt 1.6 glx 1997, and possivel more japonese cars, any idea? They all say that reads but i hve one (Vag405) and dont read...
Hi...
I'm a Mechanic.
And I Have Solus from Snapon. on My shop.
But I have Tried a lot Of OBDII code reader.
For me On my own OPINION. I say one of the better is AUTOXRAY.
With this Scanner you can Read Codes, Live Data. Freeze Frame, Pending codes,
And Clear the CODES.
This Kind of Scanners support, MB, BMW, AUDI VW, , All the Imports, from 1996 up to date.
Domestic From 1982 up to date. GM, FORD, Chrysler , Saturn.
Ok.. I hope this help on your question.
Thank you for use fixya.
Sep 18, 2008 | Mitsubishi Colt Cars & Trucks
27 people viewed this question
jasbo
jasbo
