Question about Johnson Promident Pending Kool Torque Handpiece 55000 RPM W/ Foot Control complete
Replace the front bearing in a Kool-Torque handpiece
Front bearing has failed
Need torque specs for front wheel bearing on 2004 dodge 3500 dually
The hub bearing retaining bolts are 150 ft. lbs the center axle nut primary torque 135 ft.lbs rotate 5-10 times increasing torque by 50 ft.lbs until final torque of 265 ft.lbs is reached
Mar 23, 2014 | 2004 Dodge Ram 3500 Truck
Torque settings on cranck sharf bearings
Torque settings for V-6 engine.
Main bearing cap bolts torque:
Torque: 27 N·m (275 kgf·cm, 20 ft·lbf)
Mark the front of the main bearing cap bolt with paint.
Re tighten the main bearing cap bolts by 90 degrees.
Check that the crankshaft turns smoothly.
Connecting rod cap bolts torque:
Torque: 24.5 N·m (250 kgf·cm, 18 ft·lbf)
Feb 11, 2014 | Toyota Land Cruiser Cars & Trucks
Replace front wheel bearing hub torque
front wheel bearing hub nut torque - 2007 Buick Lucerne CXS Sedan is 118 Ft. pounds
Jan 28, 2014 | 2007 Buick Lucerne CXS Sedan
Front left spindle removal/installation on a 1998 ford explorer 4X2
is it independent suspension up front cv axles or halfshafts is how you tell i cant remeber on the 98 without looking it up but the best way is to get the chiltons so you have your torque spets to reinstall its not to dificult to do eather way but are you trying to replace the stearing nuckle or the wheel bearings? it eather has cv axles that go through a sealed one piece wheal bearings or it has a splined axle with u joints that go through a bearing hub on the rotertif thats the case the spindle has 6 nuts take them off you can get the special tool a sliding hammer to take it off i just use a dead blow if all else fails wont damage it make sure you check the inner neadle bearing for play. grease bolt back up torque down pack your bearings put in the new bearing seal. now you torqu the berings down with the nut to seat the bearings go back 1/4 of a tern you want 8 to 10 thousanhts of preload you can use a dial indicator to check yourself,set the locking washer and set the locking nut to torque remember when you do that your going to loose some of your preload about 1 to 2 thousenths
Jul 22, 2012 | Ford Explorer Cars & Trucks
Left front hub replacement 2WD.
2WD pickups don't have hubs. They have rotors with bearings. Once you have the brake assembly supported, remove nut from spindle. Be sure not to strip the threads on the spindle. Remove the front set of bearings and pull the rotor off. Remove the rear set of bearings. Be sure to pack greases into new bearings prior to installation. Insert new rear bearing into rotor and replace onto spindle. Insert new front bearing and washer and re-install nut. Tighten to recommended torque specs, grease fittings and replace brake assembly.
May 15, 2010 | 2005 Chevrolet Colorado
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
Can I replace wheel bearings on my 2 wheel drive 2001 BLAZER
In addition to the great answer above, it is extreamly improtant to torque the front hub nut to the proper torque. If you under or over torque the nut which puts pressure on the bearing, you will be changing it again in a very short time. Refer to a shop manual, or go to the local auto parts store and look at a chiltons manual for reference torque value.
May 25, 2009 | 2001 Chevrolet Blazer
Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
Apr 24, 2009 | 2003 Chevrolet Silverado 1500
Johnson Promident Pending Kool Torque Handpiece 55000 RPM W/ Foot Control complete Logo
491 people viewed this question
Top Johnson Promident Science & Laboratory Experts
William McMath
ray gallant
Are you a Johnson Promident Science and Laboratory Expert? Answer questions, earn points and help others
