Question about Tview D65TSG 6.2" In-Dash Navigation
Cd won't play when I insert CD the load button comes on then after about 1 minute it goes off.
Cd will not play the load button stays on 1 minute then it goes off then the screen goes back to radio
My Ford Explorer 6 disc cd has 1 cd stuck in it and it won't eject, play or let me load other cd's. How do I get the cd out?
take the radio out and take it apart and move the sensor out of the way and take the CD out you might have to replace the CD sensor
Feb 24, 2012 | Ford Cars & Trucks
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
Jul 27, 2011 | 2003 Chevrolet Tracker
ITS cd tray is revolving when we press insert button . tray moves inward and it do't select any cd .and tray comes out again. main problem is it do't select any cd
You have a slack loading belt under the tray.The loading action is not being completed because of it.
The Cd lifting mechanism requires more torque than the tray rotating action. If you put your ears close to the tray you will hear a belt slipping sound after the loading tray goes in . If you push the disc motor assembly with your hand from underneath the action sometimes get completed and the cd will start playing. Any way you cannot be doing this all the time, the belt needs changing. Its a set of two belts, one very small for the tray rotation and a thicker/bigger one for loading mechanism.
Mar 11, 2011 | Aiwa Audio Players & Recorders
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Won' record
Check your wire they could be damage
Apr 04, 2007 | LG ADR-620N CD Player
Tview D65TSG 6.2" In-Dash Navigation Logo
19 people viewed this question
Top Tview Car Audio & Video Experts
xxxxxx xxx
Are you a Tview Car Audio and Video Expert? Answer questions, earn points and help others
