Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell e137fp monitor flashing green...
I woke up this morning and turned on my computer. A couple minutes into my session my monitor just started flashing on and off... is there anything I can do to fix it or is it just a dead monitor. Tried looking up the problem on Dell's site... nothing there(surprising >.>)
  • 71 Answers
Below you will find my recommendations for troubleshooting this issue:
1. Reseat the power cord and verify a good power source.
To reseat the power cord, follow the steps below:
1.1 Power down the system.
1.2 Unplug the power cord.
1.3 Wait approximately one minute.
1.4 Reseat the power cord.
1.5 Verify that the power cord is plugged directly into a known good power outlet.
2. Verify that the monitor is receiving power from a known good outlet and bypass any power strips.
To test the power outlet, perform the following steps:
2.1 Unplug the monitor power cable from the power outlet.
2.2 Plug in a different device, and verify that the device is operational.
2.3 If there is no power try another outlet. Remove any power strips and try plugging directly into the main power outlet.
3. Verify the monitor is powered on and the power button is engaged.
Ensure that the monitor is powered on and that the power button is fully engaged. To do so, check the power LED on the front of the monitor; it should be lit.
NOTE: There are two types of power switches:
A mechanical switch characterized by a long travel. You have to push it further and you will hear an audible click.
An electrical switch that has a short travel and almost no click.
A lit monitor LED can be any of the following:
* Green
* Blinking green
* Yellow
* Blinking yellow
* A combination, such as alternating green and yellow
Any of these states indicate the monitor is receiving power and that you should proceed.
4. Swap power cables.
To try a known good power cable on the monitor, follow the instructions below:
4.1 Turn off a working monitor.
4.2 Unplug the cable from the back of the working monitor, and unplug the cable from the wall.
4.3 Unplug the cable from the monitor in question.
4.4 Plug in the cable that came from the working monitor.
5. Run the monitor self test.
To run the monitor self test, perform the following steps:
5.1 Power off both the computer and the monitor.
5.2 Unplug the video cable from the computer or video card.
5.3 Reseat the power cord to the monitor, ensuring it is plugged into a known-good outlet.
5.4 Power on the monitor.
NOTE: The monitor self test will move around on some monitor models. If the monitor self test moves, allow it to move to the affected areas of the monitor to check for the problem described.
If the Self test failed, it's possible that the monitor is faulty. Contact dell to check if it's still under warranty so they can replace it.
Posted on Jun 19, 2009
White screen
test your computer with another monitor, if same issue occurs, problem is on video card/cables of your computer, if it runs good on another monitor, old monitor has problem.
Mar 22, 2014 | eMachines 15 inch Monitor
White screen showing on monitor
Sounds like you have a bad monitor.
Try unplugging the monitor for several minutes and re-connect.
Also, you may want to re-seat your video card on PC.
If you have another monitor to check your video with, it would help.
Hope this helps.
Monitor light flashes green and screen is blank
Best thing to do, hook up another known working monitor to the computer and this will verify that the computer is working properly.
If you get video on the known working monitor when you turn on the computer then you know the computer has a problem.
Aug 27, 2009 | Computers & Internet
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
Hanns g JC199D will not turn on, comp is on, try to turn monitor
no signal indicates a couple things... i suspect your computer isn't even booting up. reboot the computer while tapping the F8 key.... you should see writing on the screen... boot to safe mode. after it sucessfully boots up... reboot again... should be fine.
Robert
also is that an add on video card ?
Dec 18, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Plug Dell e173fpb monitor in power light blinks green and small buzz noise
Based on what you have stated your Dell monitor is dead. Seek support/replacement under warranty. If you purchase this with a credit card you have a double warranty through your credit card. You'll have to suffer through Dell's phone support to allow them to troubleshoot your dead monitor but be patient and a new or newer model will be on its way to you soon.
Hope this helped you and fixed your dilemma.
Worldvet
May 21, 2008 | Dell E173FP 17" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Flashing Lights
means you need to get it check out by a technician
Sep 28, 2007 | LG Studioworks 700S 17" CRT Monitor
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Dell E173FP 17" LCD Flat Panel Monitor Logo
888 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
