Question about Apple Air Computers & Internet
Rumbling noise The left side of my macbook makes a constant buzzing noise, it stopped twice when I left it for a few hours and restarted when I moved it and when I launched an application.
    Champion:
  • 220 Answers
The fan may need to be replaced. try first to use a compressed air can to see if this fixes the problem or replace the fans
Posted on Mar 31, 2014
Brakes make a whistle noise when applied and sometimes a low grown or grinding when coming to a slow stop or start.
A grinding or rumbling noise can also be symptoms of a wheel bearing or constant velocity joint in a driveshaft. A worn wheel bearing can also cause a 'whistling' sound (as can a worn CV joint).
A grinding noise with brakes is either worn pads causing metal to metal contact on the brake disk/rotor, or the brake backing plate catching on a spinning rotor ... or a loose/missing anti squeal brake shim (they stop the pads from rattling and vibrating).
However, as you say a mechanic has looked at the brakes and can't find anything wrong .. I think I would begin to suspect a wheel bearing or constant velocity joint on the driveshaft (front wheel drive cars).
May 05, 2016 | 2007 Honda Accord Sedan
Danfoss 103 timer is making a constant buzzing noise!!...everything's works fine but I want to stop this buzzing noise. Any actions I should take or advice would be much appreciated. Thanks.
How much wattage is going through the timer and what is its rated load max? try unplugging whatever is plugged into it and see if it stops but if you exceeded the max load might be damage to the internals which can cause that buzz.
Feb 05, 2013 | Hardware & Accessories
Rumble after hitting a small bump in the road
need a little more detail here.
Rumble from front? rear? left or right side?
And shake in the steering wheel?
How big a bump and how fast were you going?
Was the rumble instant after the bump?
Is it constantly making the noise or now and again?
Jan 06, 2013 | 2004 Hyundai Tiburon
My A3 S line auto box is making a gravelly noise more so in 4 & 6 today I selected reverse and the car wouldnt move
Have you local garage change the oil in your gearbox and the filter if it has one as some do, some don't? Be sure to use Audi oil as its the right stuff to get the box working again as long as the damage hasn't already been done due to being low or overheated. I had the same problem on an A6. :)
Jul 06, 2012 | Transmission & Drivetrain for Audi 4000
I replaced my right front drive shaft or axle a week ago because there was a constant clicking noise coming from the front left side, after replacing the clicking stopped for a day and now its clicking...
the hub assembly is most likely bad its the bearing inside thats moving making the clicking noise it moves out and touches the rotor making the brake pad move and click
Jan 20, 2011 | 1991 Mazda 323
Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Jun 15, 2009 | Frigidaire FRS26H5AS Side by Side...
Constant buzzing noise
it sounds like your fan may be hitting on something
Jan 04, 2009 | Dacor Epicure EF42BNDB Side by Side...
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
Computers & Internet Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
