Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Cannot instal updated software
I get file from belkin I open router interface to firmware update. I get file from library and hit update it starts to update then tells me I have wrong version but I have checked and rechecked to make sure it was rite version. version 3100 is version 3 isn't it? KEV
  • Belkin Master
  • 3,320 Answers
The naming convention for version updates is 3.00 for ver 3 and 3.10 for ver 3.1
You are updating to 3.1 not 3.0
Posted on Mar 30, 2014
  • 104 Answers
SOURCE: After update the firmware my belkin G stop working.
You may possibly be able to restore your router to factory default settings, by pressing the reset button on the back of the router.
You normally need to press for at least 10 seconds to get back to factory defaults (check your manual).
Sorry, there is no guarantee this will work, but it is worth a try. If it does, you will lose all customised settings (eg password, network key). :(
Posted on Nov 30, 2008
  • 104 Answers
SOURCE: firmware update for belkin f5d7230-4 6000uk
Hi...the UK firmware for the F5D7230uk4 is on this page if this is correct for your model. There is also a guide to firmware upgrades here - the usual advice is to use a wired connection, backup current config if you can, make absolutely sure you have the right version etc...
Good luck with this
Posted on Dec 31, 2008
  • 4044 Answers
SOURCE: How do i update the firmware on my belkin router?
On my router I have to log into the router while it is connected to the internet and select update Firmware. From there it does everything on it's own. If it ask for user ID and Password you can try User ID: admin Password:administrator if you don't have that information. If that doesn't work the only other method would be to activate the reset to reset the router to factory and then update and reprogram your settings.
Posted on Sep 11, 2009
inovagent
  • 111 Answers
SOURCE: belkin router stops at randon points through large
This is not a great router. It might work for various smaller tasks but if you want to do heavy duty downloads with it it's not going to cut the mustard. This is not an uncommon problem with home level routers. I would recommend going on newegg and reading reviews before you buy a new one. broadbandreports is also a good forum for reviews. Good luck.
Posted on Nov 06, 2009
Tom Marvolo
  • 708 Answers
SOURCE: when i ask if there is a firmware update
Download the Firmware from www.belkin.com/support And Update it Manually
Posted on Jan 07, 2010
My router disconnects every 3 min! i have to restart it to go again
Go to www.belkin.com/support
if your model no is
f7d8302 OR 4302 ->then click on this link -> http://cache-www.belkin.com/support/dl/F7D8302_WW_1.00.27.bin
F7D8301 OR 4301 then click on this link -> http://cache-www.belkin.com/support/dl/F7D8301_WW_1.00.28.bin
Updating your Routers Firmware
The following steps will show you how to update your routers firmware using its web interface. You do not need to be connected to the Internet as this interface is built into the router itself.
Setup Steps
  1. Locate and download the firmware file from the Belkin support site. (Type in your part number in the search box in the top right and look for "Firmware" in the title)
  2. Save the file to a location on your computer where you can get to it easily, such as your desktop.
  3. Connect the computer to one of the four LAN ports on the router.
  4. Open a web browser on the computer.
  5. In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
  6. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  7. Click on "Firmware Update" toward the bottom of the left-hand menu.
  8. Click the Browse button toward the middle of the screen to search for the file you saved previously.
    Note: The firmware version in the images below is depicted as an example. Your file name will vary depending on your model and version.
  9. Select the firmware file by left-clicking on it and then click the Open button in the lower right corner of the window. This will take you back into the router's interface.
  10. Click the Update button.
  11. A prompt asking, "Are you sure you want to continue with upgrading?" will appear. Click OK.
  12. A second prompt will open telling you the router will not respond during the upgrade and warning you not to remove the power supply to the router. Click OK once more.
  13. Congratulations. The firmware has been updated successfully.
  14. ONCE YOU INSTALL IT UNDER ->UTILITES ->COLICK ON RESTORE FACTORY DEFAULTS IS MUST... THIS WIL FIX ALL YOUR FREQUENT DISCONNECTION FR SURE I TRIED IT WORKED
Jan 24, 2011 | Belkin Play N600 Wireless Dual Band Router...
Tip
To get rid of multiple issues with belkin routers
To resolve the issue with Belkin routers:The routers that are released recently by Belkin Inc., are Basic / Connect N150, Surf / Surf N300, Share / Share N300, Share Max / Share N Max300, Play / Play N600, Play Max / Play N600 HD
  • These routers comes with a software CD.
  • Belkin router monitor is the software that gets installed in the computer when you run the setup CD in your computer.
  • This software is really an unwanted one that takes around 30 minutes to get installed in your computer.
  • In addition to that, this software displays unwanted popup messages.
  • 90% users are not aware that they can use the routers without installing any software in their computers.
Inorder to make your router properly, these steps has to be followed...
  • The belkin router monitor software has to be uninstalled from your computer.
  • Firmware of the router has to be updated to the latest version available from the belkin support site.
  • Self healing feature of the router has to be disabled.
  • Wifi protected setup (WPS) has to be disabled.
To uninstall the belkin software:
  • For Xp computers, Goto control panel > Add or remove programs > select belkin setup and router monitor and remove it.
  • For vista & win7, Goto control panel > Uninstall a program > select belkin setup and router monitor and remove it.
To update the firmware for your router:Goto http://www.belkin.com/support/
  • Select your router and download the firmware for your router. The file with a .bin extension will be downloaded to your computer.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router http://192.168.2.1
  • Belkin router setup utility will be displayed.
  • Login to the page. (password: leave it blank and click submit)
You will have the status screen.
In the status screen, you will have the very first box in the centre of the screen says "version info", under that you will have firmware version.
Just note down the firmware version there. If the firmware version in router is lesser than the one downloaded from support site, then the firmware has to be updated.
On the far left side below the Utilities you will have "firmware update", you need to click that.
Now on the right hand side you will have "browse".
Click on browse and locate the downloaded .bin file from your computer and click update.
Click ok for all the warnings.
You may see a count down now.
Once its done you will be brought back to the status screen.
Login to the router again with a blank password and click on restore factory defaults below the utilities and click ok for all the warnings.
Now the firmware of your router must have updated with the latest version.
To disable Selfheal:
On the far left side below the Utilities you will have "self heal", you need to click that.disable the self heal and apply changes.
To disable WPS:On the far left side below the Wireless you will have "wifi protected setup", you need to click that.wifi protected setup will be enabled by default, disable it and apply changes.
Click here to learn more about wps...
on Dec 20, 2010 | Belkin Basic Wireless Router
My routing stops working so often and I have to reset it
Your router might need a firmware update. Log on to www.belkin.com/support and enter your product details with the version number(ex. v1 v2 or v3) and download the latest firmware. Once that is done log on to your router interface on your wired computer and type http://192.168.2.1 on the browser. You will now enter the interface. Towards the left side click on firmware update and browse the file u downloaded and update it. After the update power down your modem and router for 2 minutes and power it back up.Everything would be working fine.
(PS: The router interface has a login password. By default it will be empty so just hit enter unless you have changed it.)
Hope this helped.
Jan 21, 2011 | Belkin (F5D7230-4) Router (587009)
Hi Thanks for taking the time to help if you can. My problem seems to be that I dont know what software to use to download the firmware update program for the router could you give me your suggestions...
You never need to use any software... just connect any one of your computer to the router using an ethernet cable and type http://192.168.2.1 in the internet explorer... It will open the belkin router interface...
On the far left hand side below the "Utilities" you will have an option called "firmware update"...if you look inside that option you will have an option to browse.... click on browse and locate the latest firmware file and update it... Thats it you are done...
The latest firmware has to be downloaded from belkkin support site...
Download the appropriate version of firmware from this link...
http://en-us-support.belkin.com/app/answers/detail/a_id/299
click here for instructions with screenshot...
http://en-us-support.belkin.com/app/answers/detail/a_id/497
Jan 12, 2011 | Belkin (F5D7230-4) Router (587009)
My Belkin router loses strength when I go from the 2nd floor where it is located down to the 1st floor of my houses and sometimes loses connection. What can I do?
Hi i would be glad to assist to jus folow the steps
Click the below links to go to download the firmware
http://www.belkin.com/support/article/?lid=en&pid=f5d5231-4&aid=5128&scid=220
once you download the firmware i have given you the instructions to update in your router
Upgrading the router's firmware
The following steps show you how to update your routers firmware using its web interface. You do not need to be connected to the Internet as this interface is built into the router itself.
Setup Steps
  1. Download the firmware from the above link
14.once firmware updated on the left under Utilites ->Restore factory Defaults this would give you a Good Connection
Thank you
Jan 08, 2011 | Belkin (F5D5231-4) Router
My wireless capabilities through my Belkin 54 router is not working. I am trying to connect my Kindle through my wireless network, but can not. Any suggestions?
Setup Steps
Jan 08, 2011 | Gateway Belkin 54g Wireless DSL/Cable...
Missing latest firmware update file .bin
Connect the computer to one of the four gray ports on the back of the router.
Oct 15, 2010 | Belkin (F5D7231-4) Wireless Router
My belkin play router works fine on my xbox, yet when I try to use my computer I get a "this webpage cannot be displayed" error, but when I reboot the play router it stops for a few hours
Hi lets we tried to Upgrade your firmware version.
Setup Steps
Please don't forget to rate techbelkin.
Sep 09, 2010 | Belkin Wireless Play Router (F7D4302)
Belkin (F5D7231-4) Wireless Router can't update
It is very easy to fix belkin problems.
First check the cable ,turn on or off the device for 40 sec .
Check the settings in admin page of your device.
Click on this link :-
How To Update Belkin Wireless Router Firmware Fixingblog com
Thank You
Feb 23, 2009 | Belkin (F5D7231-4) Wireless Router
How to upgrade firmware from 6.1x to 7.4x, and where to find it?
log in to belin website "www.belkin.com/uk/support and download the firmware under software and firmware section.
once u download it lof in to your router unterface by connecting the rtr to ur comp.
open the internet explorer and typr 192.168.2.1 and on the router interface u have firmware update clikc and browse te file u download and click update that r bye............
Dec 16, 2008 | Lucent Pipeline 130 Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
50 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
