Question about GE WPGT9360EPL Top Load Washer
Pulsator cap broke off and sock got under the pulsator. We removed the screw but are unable to lift up the pulsator and remove it. We can see the sock through the round holes in the pulsator, but th
Followed directions on GE WPGT9360 service manual for removing "infusor" after cap broke off (Removed infusor screw) but can not pull infuser up and out. It won't budge.
Bob Gemmell
  • 209 Answers
SOURCE: Need to remove top cover of GE WPXQ3090T2WW top load washer
There should be 2 screws holding it on at the rear. Looking from the rear these will be at each top corner. Once these are removed push the lid from the front of the machine towards the rear and it will pop off.
Posted on Sep 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Problem with GE Door Handle
You can find helpful exploded view diagrams and by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
  • 833 Answers
SOURCE: Loose refrigerator door handle
weavie, this is one of those ugly little problems. Get hold of a small screwdriver, a pointy knife blade or similar and stick it into the gap, however small, between the cap and the handle. You may be able to find a small indent or similar near the bottom side of the cap. Gently pry up. It will yield. Be patient.
Posted on Dec 21, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: ge microwave - uninstall from mounting plate
If you don't have the installation instructions, you can get them here.
They're very helpful when installing OR uninstalling.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge Eterna Model Em0300 HBB01 under neath light
Please unplug the oven first!
This is pretty common and can be a pain. It's tacked in place with hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) then use needle nose pliers. Be careful if heating so you don't burn anything.
You may be able to put the tips of needle nose pliers inside the broken bulb's socket, gently but firmly force the pliers jaws apart and then rotate the pliers to loosen it.
Another cool trick is to put a big glob of hot glue on the end of a stick or dowel, then shove it into the broken base and let it cool about 5 minutes, then turn the stick.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
Once you get new bulbs in it, please let me know if you the lights are still not working. This is usually a problem on the control board that can be easily repaired.
Posted on Sep 16, 2008
How to remove agitator
That is a very old GE model. There may be a screw under the agitator cap which needs to be pried off. Even with the screw removed the agitator usually rusts or bonds to the transmission top. GE had a special pulling tool that was a metal ring that fit over the agitator with 3 set screws in it that you had to screw into the outer plastic of the agitator. A gear puller was then needed to pull the agitator off. Don't know if its worth it considering the age of the machine.
Apr 14, 2016 | GE WBSR3140DW Top Load Washer
Moen 4700 lever broke off, how do i reinstall it
some have to. be pryed up with a pry bar (small) then just putnew handle in place replace screw and the red/blue cap
Jan 05, 2015 | Moen Plumbing
The infusor on my GE PTWN8050MWW Washer is detached. It is spinning loosely and floats up when the tub is filled. How do I fix it?
If the screw holding the infusor to the shank is not broken, more than likely the shaft broke. That is what happened to mine. The part is like 339 bucks and you need to tear it apart to install it. Sorry.
Jan 12, 2013 | GE PTWN8050MWW Washer
Diffuser will not remove it appears stuck at the top? Red buttons go in OK but it will not pull out
I have the same problem. I unscrewed the bottom part of the infusor and the whole infusor assembly fell at the bottom once I switched it on. Everything is stuck now. Please help!
Dec 02, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Can't remove infuser to clean it
Turning off the power with the button is not enough. Instead, to remove the infuser: unplug the machine, wait a few seconds, plug it in again and turn the machine on. Even though you are technically turning it on, the machine will sense it was not turned off in an ok way, so it will "properly" shut off (and unlock the infuser).
May 06, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk not frothing, internal door not positioned
Make sure that the milk container lid is thoroughly clean and that running hot water flows through the openings freely. Make sure you're using 2% milk. Make sure it's cold 2% milk.
The front door problem may be two loose screws in the back plane that holds the infuser unit. Turn off machine; remove the infuser unit and thoroughly clean. Behind the now removed infuser unit you will see two hex head socket screws; use a hex screwdriver to make sure these haven't come loose. If so, tightened them, but don't overdo it. Now reinsert the infuser and see if the door latching problem has disappeared.
Apr 28, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Door panel removal 1995 GMC Jimmy
There are two screws under a cover at the bottom of your inside door handle and on your door latch. Other then that snap all the fasteners free from the door before you pull the panel, oh and have some silicon to re attach the plastic vapor to the door. Good luck
Mar 21, 2009 | 1995 GMC Jimmy
Can't remove end caps from Whirlpool Model GST9679PG1 top loader
take the two screws out.one on each side.then stand in front of machine and pull caps forward and up and your face of the machine will be up.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
JVM1750SMSS CHARCOAL FILTER INSTALL
I just installed a JVM 1540 with the same grille. I removed the two top phillips screws before mounting the oven as I cannot access these screw heads once the oven is installed. It took me about 20 minutes of fiddling with the grille to figure out (no thanks to the manual) that the grille needs to slide to the left to release so you can change the light bulb/charcoal filter.
Nov 06, 2007 | GE JVM1750SMSS Microwave Oven
GE WPGT9360EPL Top Load Washer Logo
181 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
