Have a gmp 125-5 furnace and light blinks 5 times
  • 1,162 Answers
Here what i found , five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Posted on Mar 30, 2014
TheMobilian
  • 8220 Answers
SOURCE: I have a Goodman GMP 125-5 furnace. It had a 3
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Posted on Oct 28, 2011
james3751
  • 614 Answers
SOURCE: goodman gmp 125-4 gas trouble code
Rewire to schematic specs and check po;larity of transformer. Rus
Posted on Nov 04, 2009
  • 232 Answers
SOURCE: I have a goodman GMP 125-5 furnace. I have
sounds like the primary limit typically behind the gas valve its larger then the others, rectangle in shape with 2 wires going to it. be careful if your bypassing limit this can create a very hazardous condition
Posted on Nov 06, 2009
  • 6 Answers
SOURCE: My Goodman GMP 125-4 furnace
if this is an error code and you mean that the light blinks 4 times then it is the limit circuit. This could mean either the high limit or a roll out switch is open. the limit switch is right in the center of the furnace above the burner and roll out switches are probably somewhere around the opening of the burner. Follow the wires from the limit to find a roll out switch cause they are in line with each other and the rool out switch could have a button to reset it. However if the roll out is not tripped then you could need to change the limit. Only way to know is to check for continuity.
Posted on Dec 04, 2010
  • 230 Answers
SOURCE: I have a lennox GMP the fan runs but will not
The high limit switch is open. This could just be a faulty switch but more likely it is due to a lack of air flow across the heat exchanger. So change the filter and any other coils that may be in the air stream. Also check that the vents are all open. Good luck :)
Posted on Jan 02, 2011
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
Goodman GMP 100-5 Rev B Serial # 9902602550 The status light stays illuminated. It isn't blinking. I believe my igniter went bad. When I turn on my heat on the system, The exhaust fan kicks on,...
Hello, the first thing is check the igniter for any crack or white spots on it, also, if you have a multimeter check the resistance of the igniter, should be between 40-90 ohms. You can purchase a igniter at any Heating and Cooling supply store.
Mar 11, 2011 | Goodman GMS90703BXA Heater
My Goodman GMP 125-4 furnace has 4 blinking lights and we currently are unable to get it to come on. What might be wrong?
Dec 04, 2010 | Goodman GDS80904BNA Open Flame Heater
Goodman GMP Furnace problem. Original problem is
Good one! Is the flame getting to the flame sensor within the few seconds? Maybe a good cleaning of the burners or flame tray would help. 1.3 ma is enough for the flame rod to tell the board to stay on. Re-do all the ground connections both at the board and furnace cabinet to be safe. Check the polarity of the power going to the furnace. What are the chances the second board is bad?
Jan 15, 2010 | Goodman Heating & Cooling
Nov 06, 2009 | Goodman GDS80904BNA Open Flame Heater
Hello I have a GMP 150 installed last year. The furnace works fine, but after a day or so, it does not react to the thermostat. so the led light of the thermostat is solid red, but the GMP 150 does not...
This sounds Programmable Thernostat related. Do you have a new thermostat? And are you familiar with how to overide the progammed feature, such as set on manual or push the hold button. Thermostats are generic so you could have any make or model. If you feel confident you could install a different Thermostat. You just need to unplug and then mark the wires accordingly- there should be 4 wires. There are a couple other things that could be happening is your unit may not be lighting properly. If you go to the unit when its not working I believe your unit has a blinking light on the circuit board of the unit that will tell you what problem is occuring. The code is affixed to the furnace panel I believe. There are so many safetys on your unit, the best way to troubleshoot is that tattletale light. Good Luck
Jul 14, 2009 | Goodman GMS90703BXA Heater
Goodman GMP075-3 Has 1 single blink on the light
The blink codes are differant on every furnace. Read your code on the schematic found on the inside of the door. You most likey have a dirty flame sensor. Under the burners you should find a "single" wire going to a connector. This will be to the far left or right. Just opposite of a "two" white wires going to the hot surface igniter. Remove the 1/4 inch screw closet to the single wire under the burner. carefully pull out the flame sensor. Clean it with a small piece of sandpaper. Re install it. This should fix your furnace. KEEP IN MIND Goodman GMP models are noted for defective heatexchangers. Pull out the blower assembly and turn it over. If small rings about the size of a dime falls out.... this furnace is unsafe and should replaced!
Mar 08, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
