Question about LG LRSC26925 Side by Side Refrigerator
Broken Shelf Support
Left hand side freezer compartment shelf support is broken. It is oval in shape, and open on top to allow shelf removal. Not identified in parts diagram. The body of the white plastic support (grommet?) recesses into the wall of the freezer. Can't find a source for the replacement part.
4 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: LG LRSC21934 side by side. Noticed lots of water
Make sure your door fits good and flat. I run a piece of paper all around it to check the seal. Close the door on the piece of paper and try to slide it. Check all around.
Posted on Apr 25, 2009
  • 19 Answers
SOURCE: freezer shelf doors
Check with the manufacturer, sounds like you have a factory defective freezer. they should fix it for you.
Posted on Jul 26, 2009
MNTECH
  • 1543 Answers
SOURCE: I have a LG side-by-side Model LRFD25850ST - the
The insulation is all foamed in place. Doors can not be dissassembled, other than replacing gaskets.
Posted on Mar 06, 2011
Broken shelf
The small meat or deli drawer tracks show to be avail for replacement as a left and right part. Front and rear screws are shown for each track. Since these parts are shown by themselves, the parts should be replaceable alone. Part# 63001371 is the left track Part# 63001372 is the right. About $5.00 each. The full shelf is a Part# 67001532 @ about $31.00. Pleazer Appliance...
Apr 07, 2014 | Maytag MTB1891AR Top Freezer Refrigerator
Daewoo frs-U2OIC top shelf freezer not freezing
Could be the internal fan at the top of the compartment or its electrical feed is not working. With the door open, hold the light switch in (the fan usually doesn't work when the door is open) and see if it is spinning. If not, it and its connections should be checked
Feb 13, 2012 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
Freezer shelf doors
Jul 26, 2009 | LG LRTP1231W Top Freezer Refrigerator
Tenants have broken every door shelf rack
For the GE refridgerator, the model GTS22 is an incomplete model number. That is actually the series number. Your actual model should be followed by 5-7 more letters, as in GTS22FBPBRWW. The full model number denotes dates, dimension, color, etc. You can find the full model number in one of two places:
A) Upper front left corner of the food compartment
B) Left side of the crisper pan on the food liner (with storage drawer open).
Once you find the correct model number, it is important to decide exactly which parts you need. Each door shelf comes in 3 pieces. You have two end caps (left and right) and then the front piece. For the bottom shelf, the end caps are different than the caps for the top and middle shelf. Also, do you need the dairy door and the butter dish? A schematic drawing can be most helpful.
When you know which parts you need, you can go online to www.partstore.com or call toll-free 866-925-PART (7278).
Apr 07, 2009 | GE GTS22 21.8 Cu. Ft. Top-Freezer...
Refigirator is freezing my liquids on top shelf only
If its anything like a GE refrigerator, there is a flapper valve between the freezer and refrigerator that controls the temp of the refrigerator compartment. There should be a plastic shroud at the top refrigerator compartment against the freezer wall. Remove it and see if the flapper is broken. Usually you can epoxy the flapper or if not, buy a new part.
Keep in mind my experience is with a GE, but I think its pretty much the same machine.
Feb 28, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My frdge compartment is freezing
I really need more information. Like exact model number of said refrigerator. Here are some good tips. There may be a vent that leads to the freezer, if so close it. Second question is place a thermoeter on the top shelf in a glass of water for 4 hours, what is the temp. Do the same thing on the shelf that is freexing. If the tempatrues are equal turn up the tempature again. If not the circulation in the compartment is blocked. Make sure the the back of the carptmen has a gap to let air circulate vertically. Modern refriderators use air circulation to help reduce energy costs from compressors overworking.
Thanks PJ
Dec 01, 2008 | Refrigerators
Bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Dripping water
YOUR DRAIN FROM FREEZER TO DRAIN PAN IS CLOGGED,LOOK INSIDE TOP BACK OF REFRIG. SHOULD BE DRAIN HOPPER,REMOVE AND CLEAR OUT DRAIN,THANKS-MIKE
May 29, 2008 | Whirlpool ET1FTKXK Top Freezer...
Broken Shelf and side shelf
only thing i can tell you is to go to a appliance parts store with the model # and they will find it for you
Aug 01, 2007 | Frigidaire GLRT83TES Top Freezer...
LG LRSC26925 Side by Side Refrigerator Logo
20 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
