Question about Watches
I have a buem watch 1579 and i need to know how to set it up so it works what do i have to do
How to set the time on a AMST 3003 watch?
Try Googling (AMST)(3003)(manual) without parens to get instructions.
Sep 10, 2015 | Watches
I need to know how to set my skmei watch
I need to change date and time for skmei 1065 pls help me ;)
May 07, 2012 | Watches
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Oct 17, 2010 | Seiko SKA192 Wrist Watch
I have Sportline S7 Heart Rate watch with no manual. This model is not listed as an option at www.sportline.com I need to know how to set the time. I also need to know if it has the capability to of sound...
In checking out information about my new S7 ECG Heart Rate Watch, I noticed your posting. There is a Sportline website that enables you to down the product manual.... although I'm not sure it pertains to the S7. If this doesn't work, I'm sure there is a manual included with the watch I just received, and I'd be happy to email to you. I'll check back to see if you've posted a response here to see if the below website worked for you first. Posted 7/11/2010 by Mary G.
download product manual - HEART RATE WATCH 7. HELPFUL HINTS IN MEASURING HEART RATE. 8. SETTING THE WATCH FUNCTIONS ... stylish LED Heart Rate Watch measures ECG accurate heart rate with the simple ..... HEART RATE WATCH. Sportline® is a trademark of SPORTLINE, a division ...
http://www.cbs.sportline.com/manuals/SP4421IS01SPO1.pdf
May 18, 2010 | Watches
User Manual Nixon Lodown Tide Watch
hello... my nixon dont work... the screen went completely black and does not work any buttons....
I can do??
sanks Daniel
Apr 13, 2009 | Nixon Lodown Tide watch
I have a roger black pulse work and i do not know how to work it as it didnt come with instructions. i cannot set the time and it is beeping like a timer but i cannot switch it off can you help?
good morning! to set your watch is you need to press the adjust button up to three second after blinking the digit on you watch press the mode button to select the digit that you want to change, to change the digit use the two button on the right side of your watch,after setting press the adjust button once and your watch is gona be normal,thank you ! god bless !.
Aug 27, 2008 | Watches
How to set this watch
I need to know what kind of watch you are talking about Just like every car has a muffler, they are all differant, same goes with watches. Usually by the buttons will be the words "adjust" or "mode"or "set" try pushing one of these and holding down the button for 4-5 seconds (no less) because somtimes it takes that long to start (blinking).Once you get it blinking just push buttons you'll find the ones that do what you need. If you find out that this dos't work, please let me know, there are differant ways to set watche , this is just the most likly way
Jul 08, 2008 | Watches
Can't seem to get AM & PM set properly
Had Pulsar analog watch. Couldn't set either day or date properly due to being unable to signify AM or PM. When days changed one or the other would be 12 hours off.
""googled" adjusting Pulsar watches" and found site which explained how. You set day of week and date to previous day and date and then move watch time ahead until day and date are correct. Then set watch time. Seems to work.
url: www.pulsarwatches.com.au/manuals_pdf/94_1.pdf
Apr 22, 2008 | Watches
Manual
My victorinox 24731 has gone silent. the alarm sounds if i lift the back flap and push a little black disc in the rhs bottom corner. but it does not work when i set it . it has been working perfectly for the past six months
Sep 18, 2007 | Casio G7301V8V Tough Solar G-Shock Gray...
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
