Question about Canon ES75 Camcorder
No power We charged the battery but the camera has no power
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
Looking for a ac power cord for this camera
You only can safely use an original Canon power cord when you want to charge the batteries in the camera. That can be expensive. Why not buy an normal battery charger, to charge the two batteries outside the camera.
I know it looks convenient charging in the camera, but I charge all my batteries in external chargers. Is also much safer for the camera.
Jan 26, 2014 | Canon Powershot A1000IS 10MP Digital...
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
Jan 10, 2011 | HP Photosmart M525 Digital Camera
Camera never used and won't turn on, battery fully charged.Ideas? Thanks, Deb
The fe-280 user manual notes hat it is possible to insert the battery "the wrong way round" in either the charger, or camera itself (whereupon its hard to extract).
An extract from the faq about it .....
The camera no longer powers on. What could be wrong?
The battery may be dead or underpowered.
If the battery is completely drained, the camera will not power on when the Power button is pressed. If the battery is nearly drained, the camera may briefly display a Battery Empty error message and then power off, or it may power on and then quickly power off without displaying the error. In either case, charge the battery using the LI-40C battery charger bundled with the camera.
Be sure to properly align the arrow on the bundled battery with the arrow on the bundled battery charger. It is possible to force the battery into the charger so that the arrows are not aligned. This is an improper orientation, and the battery will not be charged. For instructions on how to properly inset the battery into the charger, please see "How do I charge the lithium-ion battery?"
So in a nutshell, the first few steps to check are:
1) Are you sure the battery is charged correctly?
2) Have you inserted it into the camera body correctly?
3) Do you have a spare charged battery to check the camera with? (A photo store will do this for you sometimes, if you ask nicely).
Feb 25, 2010 | Olympus FE-280 Digital Camera
Camera will power-up only when connected to DC
This from Sony website:
To ensure the proper operation of the battery, please do as follows after charging the battery.
(1) When charging by connecting the AC adaptor directly to the camera Pleasedisconnect DC IN from the camera after charging is completed. Also, itis recommended to remove the battery from the camera when charging iscompleted as the battery is discharged slightly even if the camera isturned off.
(2) When charging with the supplied USB cradle Ifthe camera is installed in the USB cradle, please leave the power cordconnected to the outlet (when using the power strip, please leave itsswitch to on).If you want to unplug the power cord (or switch off thepower strip) after the battery has been charged using the USB cradle,please remove the camera from the USB cradle. Also, it is recommendedto remove the battery from the camera when charging is completed as thebattery is discharged slightly even if the camera is turned off.
NOTE: When you charge the battery by connecting the AC adaptor directly tothe camera or using the USB cradle, do not leave it with the power corddisconnected from the outlet.
Should it not work, continue with the manual reset procedure below:
  1. Turn off the camera.
  2. Ensure the camera is not connected to an AC power adapter.
  3. Remove the battery from the camera for 15 seconds.
  4. Reinsert the battery.
  5. Turn on the camera.
NOTE: If the issue is not resolved by performing a reset procedure, service may be required .
Oct 09, 2008 | Sony Cyber-Shot DSC-V3 Digital Camera
FUJI F20 Won't Power Up - Good and Charged Battery
Fuji FinePitteryx refuses to power up,even after new lith. batteries were installed
Mar 04, 2008 | Fuji FinePix F20 Digital Camera
No power at battery and camera can not start up,battery does not charge up in charger
yea ive got the same problem
mine powers up on dc but have brought 2 new batteries and it does not power up took into local shaop they charged the bateeries still wont power up on battery
Nov 27, 2007 | Cameras
Camera not powering on
Hello... 1)camera is not turning on . Is the battery inserted correctly? Check the direction of the battery. Is the battery sufficiently charged? Use a battery that has been sufficiently charged. 2)camera switches off after powered on * Is the battery charge insufficient to operate the camera? Use a battery that has been sufficiently charged. * If you leave the camera on, the battery will be exhausted. Turn the camera off frequently by using power save mode or economy mode etc.
Jul 20, 2007 | Pentax Optio S5z Digital Camera
Canon ES75 Camcorder Logo
13 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
