Question about Hobart A200 Stand Mixer
How do i check the stator on my a200 hobart mixer, or in other words ohm check the stator wiring
Someone had wired 2 of the stator wires together and the other 2 went to the switch a single pole switch
  • 94 Answers
Usually 2 wires that AC current goes through. check with volt meter set to ohms test for resistance . if you know the value .of resistance ? but if the machine has power but does not run . you know there is a thermal fuse hidden .once blown it does not reset..so you can throw it away. please don't..just replace the fuse or get a resettable one Radio shack or local electronic store . it is a size of a ADVIL pill with 2 wires inline of power coming in to switch ... >^.^<
Posted on Apr 01, 2014
  • 81 Answers
SOURCE: NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I have a wiring diagram for the standard A-200. If you send me your e-mail to me I will send it to you. capt_rick1912@yahoo.com
Posted on May 31, 2008
bigg t
  • 640 Answers
SOURCE: 95 year old hobart mixer: two pole single throw switch
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Posted on Dec 18, 2008
bigg t
  • 640 Answers
SOURCE: A200 electronic start switch
Hi harry,the wires should be marked 1-2-3-4,if not i'll give you the diagram.Let me know.
Posted on Feb 12, 2009
  • 20 Answers
SOURCE: Hobart H600 Double Pole Breaker
listen to the buffalonyman he knows what he is talking about the most problems we have are electricans
Posted on Jun 11, 2009
tooltech75
  • 80 Answers
SOURCE: wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Posted on Oct 08, 2009
How to invert motor turning direction?
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
How do i test the stator, this one has 4 wires 2 going to the little stator strands the other 2 going to the larger stator strands, i get audible continuity when one lead is grounded and the other tou
Contact Hobart for a schematic and manual if you lack one. While on line, ask a technician why it gets hot as this is a sign of a bigger problem.
Mar 25, 2014 | Hobart A200 Stand Mixer
A200 wiring goes to ground from capacitor
How old is the mixer? Could it have a brush style motor?
Easy to tell. It will have a couple of removable panels on the motor rear cover. The brush mount plate may have moved out of position, which retimes the rotor and stator windings. With the power disconected and the rear main cover removed, look at the internal screws for prevoius marks where the position might have been.
Mar 21, 2014 | Hobart A200 Stand Mixer
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Have a A200 Mixer, when turned on, you have to spin it by hand then it runs fine. Whats wrong
The answer is clearly in the starting circuit which doesn't have too many parts, but depends on the type of starting circuit your mixer uses (electronic or mechanical start switch). I'm assuming your mixer isn't very old, as the old units used brushed motors which did not have starting circuits.
The parts of the starting circuit are the motor start winding, the start capacitor and the start switch (probably electronic in your case which is a small silver box with four wire terminals on it). The capacitor should be tested with a multimeter after verifying it's not holding a charge (check with multimeter set to DC Volts, mixer unplugged, should read zero volts).
Start winding should be tested with the meter to measure ohms. Locate the wires leading to the motor (hopefully only three wires) and you should get a reading for all three combinations of measurements (wire 1-to-wire 2, 2-to-3, 1-to-3) if meter indicates open on any of these, motor stator is bad(this is pretty rare and quite expensive).
Electronic start switches are not very simple to test, but if the capacitor and motor test out OK with the meter, and all the wiring is intact (look closely for loose wires, burned wires, poorly crimped terminals, etc.) then it must be the start switch.
May 19, 2010 | Hobart A200 Stand Mixer
Our Hobart A200 Mixer only turns on for a few seconds. It has a lot of saftey features that were not familiar with. How do i get to work properly.
It sounds like you get a degrading or bad start capacitor (locate right behind motor cover (see fig 22, page 12 of part catalog, cost $13). Here how you can check if your machine still work properly: 1- Rotate the agitator shaft manually to check for any binding. 2- remove two wires from the capacitor. 3- Use a small jumper, connect one end jumper to one wire and touch the other end jumper to second wire 4- As soon as motor start, remove the jumper. Good luck, If your ,machine have never have preventive mainternance it is a time to do so. (atva)
Apr 19, 2010 | Hobart A200 Stand Mixer
Can I cange 3x230v up to 400v
Are you stating you have an A200 mixer that is 3 phase 230 volt?
I was under the impression all A200's were single phase. The D300 floor model came 3 phase. In any regard, to change the input voltage to any maching, you would have to replace the rotor, stator, and control group, including wiring. It has to be kept to orgiinal specifications, and tech support would have to authorise the change. As you can imagine, it's not really an option. If you change from 50 to 60 Hz, you would have to change your worm gears also.
Oct 03, 2009 | Hobart A200 Stand Mixer
Feb 09, 2009 | Hobart A200 Stand Mixer
? Hobart A200 Mincer/Mixer wont work
does the motor have brushes? If so the mixer will have two removable covers on the back motor plate. If so take some light sandpaper to the part called the comutator that these carbon brushes ride on and make them shinny. If you have a newer style motor that doesnt have brushes. pull the motor cover and make sure the start switch is cleaned by sanding the contacts. If you check your wiring with a ohm/volt meter and it all checks good, well, the first question I should ask is does it hum? if not, the problems in the wiring or power switch. if it humes the problems in the comutator, start switch, capacitor or your motor is shot. unlikely for a mouse infestation. most likely wiring or switch problem.
Apr 06, 2008 | Hobart A200 Stand Mixer
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
104 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
