Question about Whirlpool GGW9250PL Gas Dryer
I broke the knob AND the STEM that the knob connects to. Do I have to buy an entire user interface to fix this?
  • Whirlpool Master
  • 932 Answers
Robert, I used the model number you gave and looked the machine up on Searsparts.com and from what it looks like you would have to purchase the entire interface. Sorry!
Posted on Apr 02, 2014
The Whirlpool Duet Sport MT3161911 Type DH2
You may have to replace the knob entirely
Sep 09, 2016 | Whirlpool Dryers
Door knob stem stuck
You may have to apply Liquid Wrench or equivalent to free up the spindle. Tap the end of the spindle gently with a hammer to break the rust or corrosion loose. You will then have to prevent the mechanism from turning as you work the old spindle free. Be careful to avoid damaging the lock mechanism in such a way that installation of the new spindle will be difficult
Jul 17, 2013 | Hardware & Accessories
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
I bought a 2004 Lancer Mitsubishi brand new. Soon after the purchase I had trouble moving the heater knob (climate control temperature control) and, broke it. It has not worked since I purchased it. I...
i bought a used 2004 mitsubishi lancer ls sportback with the same problem. a google search told me this was a known defect and was covered under a dealer recall--no cost to me. my local dealer did the job. it took at least a half day--the entire dash, they said, had to be removed. the fix isn't perfect, but it is light years above and beyond what it was b4. the new knobs aren't silky smooth, but the old ones needed tools to turn!
Feb 01, 2011 | 2003 Mitsubishi Lancer
Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P. 634052c.jpg
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place. 7c9f2a3.jpg
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob. 6be2e7e.jpg
just cut the brass down enough to match the notches in the stem of the knob. 0cdfdf7.jpg
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
Sep 15, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
We have a Maytag toploading washer (SAV4655AWW). The stem holding the knob for the water level broke off. I think I need to replace the entire switch. Is this something I can do myself?
Yes you can do it.
For now just turn it with a plier until you buy a new knob or get one from another washer machine go to the lockal repair shoppe or the salvage place to get a replacement.
Vitally
Sep 09, 2009 | Maytag SAV4655A Top Load Washer
Knob broke off my A/C with the peg inside!
Simple you either replace the knob assembly or use araldite and fix off the broken knob. It is only a temporary remedy and for a permanent solution please replace the knob assembly and get rid off this problem
Jul 14, 2009 | Heating & Cooling
Air conditioning systems
If you remove the rest of the switch knob the see if there is a metal stem behind the knob if there is the take a pair of pliers and try to turn that stem
Jun 13, 2009 | 2000 Hyundai Elantra
Volume control broken
You can purchase clear 2-part epoxy products at most home improvement stores. You will also need masking tape (or similar) a popsicle stick (or similar) a small piece of cardboard and a toothpick.
Mix the epoxy with the popsicle stick and apply a small amount to the exposed surface of the volume control's stem. Holding the knob in place, run a strip of tape from the top of the unit, across the knob and to the bottom.
These epoxies are very strong and fast setting. It's probably best to leave the tape for at least 8 hours but you should refer to the instructions for the epoxy you buy.
Good Luck,
BB
Jan 05, 2009 | Yamaha HTR-5830 Receiver
The knob stem that for the turn on knob broke
Hello keppoet,
Since you only provided a brand and not a model number, I cannot track down the exact control knob that you require but here is a link to a website that you can use to get that part yourself. If this fails to provide the right info, please include the model number with the GE Brand next time..
Hope this helps you.. Here is the link http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Regards,
Rick
Nov 24, 2008 | Dryers
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
