Question about Saeco Talea Touch Plus Automatic Espresso Machine - With Touch Screen
Water is in the dreg tray is that ok?
There is a lot of water in the drip tray is that ok?
  • 8 Answers
SOURCE: significant leak into drip tray when brewing and using steam/hot water
If the blockage was in your boiler there wouldn't be water in your drip tray. However, it wouldn't hurt to descale after this many years. Vinegar is NOT a good idea as the scale will only flake off and may block other components including the solenoid. A good descaler will disolve the scale so it easily flushes and stores that sell coffee machines usually sell the descalers as well.
There are several regular checks you should do on your machine.
1. Remove and clean the brewing unit at least monthly paying extra attention to the filter that plunges onto the ground coffee and that the coffee passes through before passing into the dispenser. Dried coffee oils will block this filter if left unwashed and water will back flow into the drip tray and dregs drawer.
2. Check that there isn't any ground coffee in the cavity behind the brewing unit (below the nipple) and that the hole at the base of this cavity is clear.
3. Replace the brewing unit. While the door is still open you will be able to operate the machine if you trigger the lever that the door normally triggers. On your model there is a trigger at the top of the door frame. Run water/steam and check to see if there is water dripping from around the top joint of the steam arm when you do this. If no steam at all comes through the steam pipe, but it comes out around the pipe, then you should get it checked by a technician as the tap assembly may be fractured and need replacing.
Posted on Dec 09, 2007
  • 40 Answers
SOURCE: Hi, we have aa Saecco
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
mirran
  • 515 Answers
SOURCE: Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Posted on Jul 26, 2008
SOURCE: We have an Saeco Incanto
My SAECO coffee machine is a real disappiontment. We frothed the milk a few times and then the machine started to only warm the milk and provide a small amount of froth. Now the company is trying to tell me it's something I am doing! Not so. It is the expensive machine not working.
Posted on Jun 18, 2009
My Saeco Incanto Deluxe occasionally overflows with dregs and water under the machine prior to the "dreg drawer full" message being displayed. Is there a counter tray available for this machine?
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Apr 17, 2011 | Saeco Incanto Classic Espresso Machine
Red ! light comes on and will not work
If it is a steady light water tank is not properly in OR dregs counting and drip tray is full. Pull out the drip tray and wait for the red light changes in to flashing, then put back the drip tray.
Mar 18, 2010 | Saeco Odea Giro Plus Coffee Maker
The dregs drawer missing indicator on, unit won't work.
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
There is a micro switch whit an arm the hangs down in the slot on the side of the machine. Make sure that you have the arm for the micro switch.
Jan 11, 2010 | Saeco Magic De Luxe Espresso Machine
Water leaking and coffee dry
Sounds like the boiler is blocked, and machine needs to be descaled. Try this first remove the parnello if your machine has one on the steam wand then using a paperclip clear out the end of the wand, that might be blocked. If it isn't then run the descale to clear out the blockage in the boiler.
Oct 05, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Removing Saeco coffeemaker dregs container
The dregs container comes out with the drip tray. Lift up on the drip tray and slide it out. If this doesn't work then the brew group is out of position. Turn the machine off then on so that the machine goes through a self test. This will reposition the group allowing removal of the dregs container.
Apr 24, 2009 | Saeco Incanto Sirius Fully Automatic...
Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Jul 19, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Dregs light stays on (even when emptied!) - can't use machine
the various lights are controlled by either magnets that hit various sensors or microswitches.
the dreg light i'm pretty sure is a microswitch.
Its pretty common for them to go out, they're standard in almost all super automatic machines.
that particular switch is a pain in the **** to get to. You can order them direct from saeco, but if you can, it may be easier to send it out.
There should be a microswitch for the grind box, for the drip tray, for the water tank, and there should be one if i remember right for the grinder.
Its different for each model.
Hope this helps.
Apr 06, 2008 | Saeco Magic De Luxe Espresso Machine
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Talea Touch Plus Automatic Espresso Machine - With Touch Screen Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
