Question about Toshiba Televison & Video
My plasma has horizontal fuzzy lines at the lower and mid sections of the tv. They are about 4-5 inches wide. Now my tv doesn't produce sound, it's a toshiba regza plasma 60" it started and would go a
Is it worth fixing?
Plasma TV
Take it to the recycle center & get the latest tv like
a samsung
You look at best buy & buy from amazon
Posted on Mar 29, 2014
    Filmmaker:
    Uploaded 5 video answers.
  • 18 Answers
Hello there the question about worth is depends on how old is unit and technology@2014
any how i am uploading an image that might use full to solve the issue,generally PLASMA is high voltage and temperature machine so i found most of unit with cable/wire chemical unbound inside board connector or on component
My suggestion is that open the unit and have look on chemical damage on metal etc
My plasma has horizontal fuzzy lines at the lower  - c378c28b-e5e3-45a3-924c-1e71803ad51c.jpg
SOURCE: Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Posted on Mar 06, 2008
  • 3 Answers
SOURCE: philips plasma tv vertical black stripe
Check these videos for repair instructions for black lines.
Just requires some soldering.
Video 1 / Part 1
http://www.youtube.com/watch?v=9NPobj0_GSo
Video 1 / Part 2
http://www.youtube.com/watch?v=ITd6Ahdi4s0
Video 2
http://www.youtube.com/watch?v=qBpg77ZzFFk
Posted on Feb 09, 2009
SOURCE: I have a Phillips 42
I wanted to share my solution to this problem. Not only is it an easy fix (aside from taking the tv apart) but it also explains some of the strange methods I've read that have worked, such as taking out padding from behind the boards or putting a magazine under one side and even tapping on the tv for a temporary fix.
Granted its only been a few days of it working but I tell you this....It's not done the half black screen once! And trust me when I say it was doing it constantly.
Ok so first off the problem definitely lies in the upper/lower buffer boards. On the model mentioned by the OP (same model I have) it's located on the same side as the power button (right side when you are looking at the tv).
Ok so you've got the tv openned face down on a non static surface. Btw I was shocked at how many youtube videos I found of ppl working on their tvs while its laid flat on their sofas!
When you are looking into it you will see on one side there are two vertical boards hooked up to another board more towards the center. These two boards are your upper and lower boards that provide the upper and lower picture. The problem I was having was in the lower section of the tv going black so obviously that corresponded to the lower board. (They are labelled upper and lower if you look closely)
So here is what I did:
I noticed the lower board was not sitting flush so I unscrewed the one screw on the bottom and noticed how much of a gap was in the screw hole. The problem was it was screwed down in such a way that one of the connections going to the main board was not making it's proper connection. So I just gave it a little push towards the center, held it, and screwed it back down.
That's it! It's fixed now. No need for replacing anything. Just poorly drilled holes and a few things not lining up correctly!
So hopefully anyone else that's having this same problem might have some luck in using this fix. Good Luck!
Posted on Mar 15, 2009
  • 10 Answers
SOURCE: blue horizontal line on my lcd tv
change the channel up 7 times and go back to the station
Posted on Nov 15, 2009
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Posted on Feb 05, 2010
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Picture is fine for about an hour then goes fuzzy
Hello Townsend, It sounds like a problem called blooming, or you are having a problem with focus control which are signs of a problem in the horizontal and high voltage section of the tv in the case of plasma TV this would be the excitation circuit. I would suggest that you take the set to a TV repair shop to effect repairs.
Sep 12, 2007 | Dell W4201C 42 in. Plasma HDTV
There is a 4 inch wide line across our 51 inch plasma tv. is it fixable
Yes the board to repair is cheaper than tv. As well you can search youtube an get info on how to do it your self. I do my repairs.
Mar 24, 2014 | Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
Nov 28, 2012 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
Feb 07, 2009 | Proscan PS27123 TV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
