Question about Sport & Outdoor - Others
Will not start
Rapid clicking but no start. All lights work. Got jump start, left it two hours, turned it off, and it would not start up again.
  • Anita WHitney
    Anita WHitney Mar 29, 2014
    THis is a chevy s-10 truck, year 2000.
    Top Expert:
  • Sport & Outd... Master
  • 45,018 Answers
Could be a failing starter
Posted on Mar 29, 2014
Testimonial: "i GUESS ANY IDEAS COULD BE HELPFUL RIGHT NOW. iT IS SATURDAY NIGHT. i AM STUCK UNTIL MONDAY... thANKYOU"
Starter clicks will not turn engine over
next is jumper cable jump start to good running helper car battery.
that cuts cause in 1/2 , 15min works.
car starts, your battery is bad, or not charging, running, or is only discharged. (left head lights on)
wont crank. now?\\
hot wire the solenoid, for cutting possibles in 1/2 again.
what transmission? in car?
see tricks here. (and the hot wire trick)
http://www.fixkick.com/nocrank.html#tricks
Feb 15, 2014 | 2005 Honda Accord 2.0
Honda accord 2009 lx-p, 39600 miles on it. I Turned it on an hour ago, and I dusted off the engine cover, but I was careful not to damage or unplug anything. It was a simple paper towel sweep. An hour...
The battery is dead or not connected tight enough. Bring the battery to an auto parts store, and have it tested, it sounds like it's dead or VERY weak, that's what those signs and symptoms are telling me.
Mar 21, 2017 | Cars & Trucks
Car wont start or make a clicking sound when turning key.
check the battery conections, and then have it tested.
Apr 14, 2013 | Toyota Camry Cars & Trucks
My lumina will jump start and starts several times then goes dead with clicking noise
I would say if the car stays running after u jumped started it I would replace the battery
Jan 11, 2013 | 2001 Chevrolet Lumina
91 gt - had a dead battery so jump starting but just getting rapid clicking sound?
The rapid clicking sound is the starter solenoid. What it's telling you is, the battery voltage is still too low. Either you have a poor connection with the jumper cables or the cables are too light to carry enough current to start the car. Leave the jumpers hooked to the other car for about 10 minutes the try it again. Make sure you have good connections the other car should charge your battery enough to start it in 10 minutes or so. If that don't work your battery may be shot or you have a bad battery cable, loose or corroded connection on your car.
Dec 28, 2009 | 1986 Toyota MR2
Won't turn over - rapid clicks - panel lights flicker
Check the battery condition - it may be flat,
check battery terminal posts are clean and connection cables are not loose or corroded.
Aug 29, 2009 | 2001 Volkswagen Jetta TDI
Truck sometimes starts and sometimes wont. i hear a clicking soun
Unbolt and clean your battery terminals if dirty or corroded, preferably replace the bolts (good auto parts stores stock them, and they take some effort to remove and replace them but it's necessary to properly clean the terminals anyway) charge, jump or replace battery ... connect battery terminals and don't over tighten ... start the truck, check charging system gauges confirm charging voltage over 12V 13.8V-14.5V and lights should be bright as normal ... if so, you may be fixed ... if not you have charging system issues, that will be the next post if needed.
May 12, 2009 | 1997 GMC Sierra
2005 beetle
have you checked the earth points,if you are using jump leads and its starting sounds like its using there earth
Oct 17, 2008 | 2005 Volkswagen New Beetle
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
