Question about Samsung Hl72a650 72-inch 1080p Slim Dlp Hdtv
Replace bulb in housing
Where does part 573D29 go
    Sergeant:
  • 418 Answers
No such part number. Samsung parts mostly start with BN or BP.
Posted on May 16, 2014
How to replace bulb only in NP07LP housing
you can only replace the bulb from the housing ,it is easy to do it
the original bulb is USD80,
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 18, 2014 | NEC NP07LP Projector Lamp
Philips Mitsubishi WD62525 Lamp with Housing 915P020010 Do I have to buy the housing? Do I need to replace the housoing when I replace the bulb?
The housing is part of the bulb cooling system so it has to be properly mounted to cool
I did a quick look for the bulb and yes you can find bulb only BUT they are $10 to $20 more than the bulb and housing !
So it looks like it is cheaper to replace the bulb and housing. As a guess I would say that these bulbs are what someone has found out to be a replacement but can't purchase then as cheap. So to save yourself some money buy the combo.
Sep 14, 2011 | Philips Mitsubishi WD62525 Lamp with...
Need to know how to change break light bulb
Open the truck & remove philips head screw that is located to the left of the tail light housing in the trunk lid weatherstripping housing area. Next unscrew the trunk lining screw to fold back the trunk lining to get at the two plastic wing nuts that hold the light housing.
Unscrew these two wing nuts and slide the housing out, then remove the bulbs and replace. Bulbs come out similarly to how you'd replace the front headlight bulbs (unplug, twist counter-clockwise to unlock and remove old bulb, replace with new bulb and turn clockwise to lock, plug back in).
Oct 16, 2010 | 2006 Chevrolet Malibu
Replace low beam on 2000 LHS
The headlight housing must be removed to access the bulbs on the back of the housing. HOWEVER!!! you must take loose the bumper on the side you are replacing. To do this you also have to take loose the inner finder and turn you wheel sharply in the opposite direction of the bulb to be replaced. There is a 10mm nut you will have to remove inside as well as multiple plastic fasteners along the inner finder and across the front under the hood. Bulb just twist out to remove once the housing is removed. Also, resist the urge to use a very large hammer. Use caution when pulling the plastic bumper out where the 10mm nut was removed, the stud can easily scratch the paint while working the housing out of its socket.
Jun 25, 2009 | 2000 Chrysler LHS
Bulb replacement
Ok, you can buy the bulb separately and it will save you money. I will have to warn that , installing this bare bulb will be tricky and you can not touch this bulb with your bare hands. it will damage it. Other than that, it is possible to purchase the bare bulb alone. i will post a link to your replacement bulb without the housing below.
CLICK HERE FOR YOUR BARE BULB WITHOUT HOUSING.
Please rate and have a great weekend:)
May 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bulb Replacement for Sony TV KDF-42WE655
no you should only replace a bulb with the one made for that brande t.v. you should put in a sony xl-2400 in your sony t.v. and yes you should get both housing and bulb in 1 i bought mine off ebay for about 116.00$ both lamp and housing very easy to replace good luck also if you have a sony kdf-42we655 or 50we655the lamp part # is xl-21oou or xl-2100
Jan 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replace the tail light bulbs in 2004 infiniti g 35 coup
tail light bulbs are replaced by removing the tail light housings. The housings are accessed by removing the nuts, the nuts are secured behind the inner trunk liner inside the trunk. Remove fasteners holding liner in place, remove 3 nuts for each housing(i believe it's 3 nuts if my memory serves me right), remove housing and replace bulbs
Jan 13, 2009 | 2004 Infiniti G35 Sport Coupe
Drivers Side brake light bulb is burned out.
Pull the panel back on the INSIDE of the car's hatchback or trunk. The bulbs twist in from the back.
Dec 03, 2008 | 1993 Ford Mustang
Signal bulb replacement
you may be able to access the bulb housing under the hood. open the hood and look behind the turn signal for the bulb housing. once located, grasp the housing and turn counterclockwise about a quarter and then pull. be sure to replace wtih the same type/part number bulb.
Sep 25, 2008 | 1996 Mercury Grand Marquis
Replacement of driving light bulb
open the hood, find the light housing, a round black can looking device, press the release tab and rotate the curved plastic arm upwards. this will release the housing and pull the whole housing forward out of the car. It will still be attached to the car with a wire. Open the back cover over the bulb, disconnect the wiring plug and undo the spring clip. Pull the bulb out and when replacing the bulb do not touch the bulb with your skin. It will burn out quickly with skin oil on it.
To install housing, place it so that all three rails or guides line up and gently slide in. You will have to jiggle and wiggle the housing and the locking lever. When nearly fully installed slide the locking lever down to lock headlight housing in place.
Jun 28, 2008 | 2000 Volkswagen Beetle
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
See all Samsung Hl72a650 72-inch 1080p Slim Dlp Hdtv Questions
Samsung Hl72a650 72-inch 1080p Slim Dlp Hdtv Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
