Question about Aiwa Audio Players & Recorders
Standy mode system wil not turn on
Yesterday i plugged in some speakers to my aiwa cx-na555 system. the system went into standy mode and won't come out. I tried holding power and stop to reset and unplugging.
  • 4,234 Answers
When you connected the speakers, one of the following may have occurred: 1) Crossed the wires (smoked the outputs) 2) Presented too low an impedence load to the amp section (overheated and smoked) There are other possibilities as well, but those are the most common. In any case, try disconnecting hte speakers altogether and trying to turn on the system. If it turns on, then the problem is either the wiring or a bad speaker. If the system stil won't power up completely, then the output section needs to be checked. These units have discrete output transistors that can be checked by a service shop. These are not too expensive but are somewhat unique to Aiwa systems. Figure on $20-$40 for parts. Dan
Posted on Jun 15, 2009
Stand by problem
do have the the circuit book of aiwa nsx k880
Apr 08, 2014 | Aiwa Audio Players & Recorders
Aiwa cx-na555
Either the tray loading mechanism is out of alignment, or the flex-cable for the tray is bad.
Dec 17, 2013 | Audio Players & Recorders
WHEN i power on sony hcd-gn 888 power off and stand by indicator blenks
From the description you have provided, the audio output ic is loading the system down causing it to shutdown, the remedy! replace the audio output ic. But to check! power off, remove speaker wires from back and power on, if standy stays on, the above part must be replaced, but if standby stays off there is short in one of the wires and speaker.
Mar 08, 2012 | Teac Audio Players & Recorders
I have AIWA NSX-880 purchased in '99. During transportation it had got damaged. The CD part got damaged, the circuit got cracked. Recently gave it for repair, but I was told the CD tray cannot be repared....
This says Sony has taken it over, so Sony are unlikely to be interested.
AIWA Global Home
you might have more luck here
Aiwa Service Center in Hyderabad 040 24077328 Aiwa Repair Center in...
Or find someone like this
Aiwa CX NA555 Volume Repair
Basically you have an old and obsolete unit where no spares are available. This type of unit is deemed as a consumable unit, they break, you replace.
Nov 07, 2017 | Aiwa Audio Players & Recorders
MDS 503 STUCK IN STANDY MODE?
Is it an MDS-JE530? Do you have a minidisc in it? If yes, then unplug the unit. Slide the little switch from TIMER "OFF" to "PLAY", then plug the unit back in. After 10 seconds, it should turn on and start playing the minidisc. Let me know if that works or if we need to try something else, okay?
Dec 30, 2009 | Sony MDS-JE520 Mini Disc Player
Have Aiwa CX-NA555 with 3-CD turntable. CD's won't play because belt that connects motor to screw-drive on turntable is broken. Where can I get part number and/or replacement belt? Tx.
i have an aiwa cx-na555, the turn table want work the belt is good however when the table slides in it does not raise the turntablr motor into position because the yrllow does not unlock the turntable, its as though it is out of time, ineed help
Dec 07, 2009 | Aiwa Audio Players & Recorders
The standy light comes on put no power whats the problem please
Sounds like the power supply is shot. You can buy a new power supply, but that would require pro level re-wiring inside the stereo. I'd get a new one, aiwa doesn't make good stereo's anyways. Go with pioneer
Oct 11, 2009 | Aiwa NSX-DS55 CD Shelf System
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
437 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
