Question about Ematic EGS004 Genesis Prime 7" Touchscreen Android Tablet - Pink
Tablet will NOT go beyond 'coming on'-displays logo and 'ematic'
Tablet(I've had it for one month)has been very iffy from the start. NOW, it will not give me a screen at all.
3 Suggested Answers
ving911
  • 6 Answers
SOURCE: I brought a ematic 7" Quad-Core tablet with Android 4.2 Jelly Bean. When I turned the tablet on and it go thru it cycle it show on the screen unfortunately, rstech_teni has stopped.
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
Posted on Jan 26, 2015
jonsyrol
SOURCE: Bought a ematic 7" HD quad core tablet screen crack bought on 12-24-2015 is it still under warranty
These companies do not make returns for cheap tablets easy ,lessons learned .
Posted on Oct 07, 2015
NEED USHERS GUILD/MANUAL FOR A ANDROID ETH103 TABLET
Do you mean the Ematic 13.3" CinemaTab ETH103 tablet with Android 4.1? The manual is available on the Ematic product page: http://ematic.us/tablets/133-dual-core-processor-eth103 . Click on the support tab. The direct link to the user's guide is http://www.ematic.us/sites/default/files/CinemaTab_UM.pdf .
I hope this helps.
Sep 12, 2015 | Tablets & eReaders
When I turn on my tablet my screen is frozen all it does is go from ematic screen on start up to android is upgrading over starting apps. back and forth and thats all it does please help?
if you can try and save your photo's etc from it..then close it down. now hold the home button and the volume up button together and turn it on while holding them buttons. you will get a screen to restore it and other options
Apr 24, 2015 | Ematic 7" Tablet Computer
Why won't my Ematic tablet load?
This needs a factory servicing as the main borad has been compromised.
Jun 28, 2014 | Ematic EM63BL - 7-Inch 4GB HD Tablet...
My ematic 4gb EM63 7" is stuck in trying to complete turn on process, cannot get p.ast the logo and blinking lights. I simply cannot turn it on. I've only been using it since Jan 2014. Been trying to
So I guess nothing else to do but to get it to boot from a SD card with Android 4.1 on the SD Card, It appears your's is corrupted, there is a number of sites where you can download along with directions to make an Android boot card. Hope this gets you up and running.
Apr 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
Forgot password
So all you have to do is power it down.
Press and hold + volume button and start the tablet.
It will give you 3 option . Select errase all data and factory reset.
Jan 08, 2014 | Ematic Tablets & eReaders
Ematic connect to computer
are you using windows 7 or mac? If windows, you may not have loaded the proper driver for the device and the device manager sees it, but isn't loading it. If you can get the device manager, you can look for the yellow exclamation point and then tell the system to reload the driver for it. Check your cable and your cable connection. It is possible that the connector isn't seated properly.
Dec 30, 2013 | Ematic EGS004 Genesis Prime 7" Touchscreen...
Ematic tablet screen is frozen
Well I'm trying to fix a ematic tablet because it frozen
Dec 20, 2013 | Ematic 7" Tablet Computer
Where can i find drivers for my ematic tablet?
I assume you have the Ematic Pro Series tablet. The answer is that there is none. Since the Ematic Pro tablet runs a generic build of Android, Ematic cannot provide a driver. Sorry.
Nov 09, 2013 | Tablets & eReaders
Ematic EGS004 Genesis Prime 7" Touchscreen Android Tablet - Pink Logo
35 people viewed this question
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
