Question about Kodak i1320
Kodak i1320 Scanner error - red light blinks
I have a Kodak i1320 scanner I purchased from UK less than a year ago. It suddenly developed a fault while scanning and a red light started blinking. Please I need to repair this urgently, but I don't know of any kodak centre in Nigeria and I can't afford to give just any road-side technician.
5 Suggested Answers
SOURCE: Kodak easy chare 5100 scanner
Same problem on new Dell Pentium Dual Core Vista machine. No fix found yet...
Posted on Sep 30, 2008
  • 823 Answers
SOURCE: Kodak ESP5 AiO
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
Posted on Sep 27, 2010
issken
  • 1472 Answers
SOURCE: My Kodak i1320 scanner displays an error message,
veronasmercu
If you have already gone through the troubleshooting in the manual and still have trouble it is possible that you need to clear the power state on the unit.
To do this unplug all connections from the scanner including the power cord. Next hold down the power button for about 2 minute.
After this reconnect the scanner and see if the error goes away. If it does not most likely the scanner has a hardware problem.
Let me know how things go
Issken
http://www.fixya.com/users/issken
Posted on Sep 20, 2011
  • 29 Answers
SOURCE: I need to find out how to add extra pages to a
It depends on what software package you are using to scan , the driver cant add extra pages ,you could use Kodak Capture Pro software (not the desktop version) or some other third party software
Posted on Dec 11, 2011
Tip
Kodak 2500 scanner tires
Several years ago, Kodak stuck it to the owners of Kodak scanners. A simple, inexpensive consumable, tires, were taken off the market as a cheap thing to buy and they made it part of a care kit which just sent the price sky high.
If you own a 2500 Kodak scanner you can replace the retard tires with #13 O rings. They can be purchased from any Home Deport, Lowes....You will need a total of 12 O rings and that will cost you less than a buck. They work!!! I have been using them without incident for 2 years.
on Feb 18, 2008 | Kodak Digital Science 2500D Path-Through...
Hello, My Kodak i1440 scanner is blinking a steady red light. The time I turn the scanner on, both green and red blinks once then the red light get steady. what possibly could be the reason? Thanks;
First you need to see if the scanner shows in the device manager , if it doesnt it is likely the CPU / Main board is faulty If you can see the scanner in the device manager it has connected and loaded its firmware in this case it could be many things but the image guides are the most common issue , check them for damage especially the white area on the underside
Sep 26, 2011 | Kodak i1440 Pass-Through Scanner
I have an E 6 error message on my Kodak i1320. It won't clear out. The cover is closed. I blew compressed air on the sensors. The manual says E 6 means the cover is open, the software says it's a...
The error is the ultrasonic sensor thinking it is blocked , there are 2 sensors one on each half of the transport small round grills approx 8 mm in diameter in the center just after the feed rollers if cleaning these doesnt help they are probably faulty and will need to be replaced , cleaning with compressed air can damage the sensors as they are quite fragile lightly blowing or carefully vacuuming is the best way
Sep 19, 2011 | Kodak i1320
I need to find out how to add extra pages to a document already scanned. I have a kodak i1320 plus scanner.
Dec 07, 2010 | Kodak i1320
Kodak i40 error e7
E6 means the scanner cover is open .
Please check for any open covers or any movable parts which is not closed.
Feb 26, 2010 | Kodak i40 Path-Through Scanner
Kodak I1220
Kodak i1210 the red led is flashing and no work
Jun 24, 2009 | Kodak i1220 Pass-Through Scanner
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
Kodak i1320 Logo
448 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
