Question about Yamaha Full-Size Keyboard
How do I connect my Yamaha DGX-202 Keyboard with my Windows 7 PC through a Lexicon Lamda, via MIDI, so I can use them together? I am also using Reaper as a DAW. Thanks!
4 Suggested Answers
  • 4 Answers
SOURCE: Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Posted on Apr 27, 2009
  • 5603 Answers
SOURCE: I get random unwanted midi
Check that you don't have MIDI echo on in the DAW. If the MIDI data is echoed, it MAY be merging with the outgoing and when MIDI signals are merged in pieces instead of whole messages the data is corrupted. If you can look at the data stream with software, you should be able to spot the problem. Another problem might be excessive latency of the recording software. Make sure you do not have antivirus or antispyware programs running or network running. The Roland will spill data at much less rate and while the dd55 may overrun the DAW the Roland might not be able to. The key to the problem is to analyze the MIDI data stream that is being recorded.
Posted on Sep 06, 2011
  • 20 Answers
SOURCE: Which midi cable or USB midi cable should I use for Yamaha DGX 520 model.
It doesn't use a USB to MIDI adapter (such as the UX-16.) It has an onboard MIDI controller and uses a standard USB A-B cable. You just need to install the driver from the CD-ROM or here, and plug it in. You can get the manual from the same page or here. Setup is on page 99.
Posted on Oct 22, 2012
How do I download files from my yamaha portable grand DGX-230 to my computer
To download/transfer files to computer, you need 2 softwares from yamaha website. USB MIDI drivers and MUSICSOFT DOWNLOADER.
Install drivers first,and then Musicsoft Downloader.
Connect keyboard to PC/notebook by USB cable.
Run Musicsoft Downloader.
If you click "Electronic Musical Instrument" in the Musicsoft Downloader display.and then "System Drive", a file named "08PG76BUP" will appear in the lower right corner of the Musicsoft Downloader display. This is the backup file that will transfer to computer.
Usually yamaha came with CD-ROM that contain divers and softwares + user manual,so you don't need to download.
I hope this helps.
Regards.
Sep 01, 2015 | Yamaha Music
Casiotone ct630
I haven't been able to find documentation to be sure if the CT-630 has MIDI ports on it (my guess is no, but please check). If it does, you can get something like the Yamaha UX16 USB MIDI Interface cable to connect the keyboard to a PC.
If not, sorry, it seems the only thing you could do is record the audio output.
Aug 17, 2013 | Music
Oct 20, 2012 | Yamaha DGX520 Portable Keyboard - 88 Keys...
My yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
Where can i find windows 7 x 64 drivers please help mee !!!
Your Yamaha DGX 203 Portable Keyboard - USB-MIDI Driver Version 1.2.2 ie. for OS Win9x/ME.
Yahama site does not have the Win7(x64) Drivers ie. USB-MIDI for your Keyboard Model DGX-203
But you can try the USB-MIDI Driver Version 3.1.0 for Windows(R) 7/Vista/XP 64bit for Model DGX-520 @ http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/dgx_series/dgx-520/?mode=model
I can't assured you that it will works on your system. Since your Keyboard is no longer in production, I doubt Yahama will provide you with the official USB-MIDI drivers for your Keyboard even you requested for it.
I guess this is an option you can try and hope it works & good luck.
Regards.
Apr 13, 2011 | Yamaha Dgx203 76Key Portable Keyboard
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Mar 27, 2011 | Yamaha YPT320 61 Key Personal Keyboard
How can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Yamaha Full-Size Keyboard Logo
69 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
