Question about Fostex MR-8 Digital Multi Track Recorder with Built in FX
Card error 13, what is card error 13, and what's the fix.
I keep getting card error 13 and machine locks up preventing access to the menu & usb usage or anything else. HELP Thanks Jim Tudor
Camera keeps saying memory card error card locked
You did not say what camera nor what kind of memory card, so not exactly easy to give any specific answer. However, assuming it is an SD card (Secure Digital - normal or micro) there is a little slideable lock on one side and it is probable that it has been accidentally moved to prevent anything on the card being accessed.
Sep 02, 2014 | Office Equipment & Supplies
Memory card locked, already tried little switch on the side
It may have to be unlocked in the camera settings. My phone has a lock feature for photos, to prevent accidenta erasing.
Jul 17, 2010 | SanDisk 2GB microSD Memory Card
Not able to format or add anything to mmc
This is usually caused by the SD card adapter, and is nothing to do with the camera or the microSD card. On the SD card adaptor there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked. (In the above picture, we are talking the left adaptor, and the left hand side - just where the line splits the red from blue).
If it is a damaged / "cheap" adaptor card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to move the slider to locked, then back to unlocked. The replace in the MMC reader and see what you get.
Mar 02, 2010 | SanDisk 1GB microSD Memory Card
Can't access anything on Nokia 6300. It locked up and gives message of: (Message storage memory not ready) No Nokia place around to take it to. Please help!
The phone's memory is full, which causes the error message and lock ups. This error prevents you from freeing up memory by deleting messages.
Try the following (taken from the Nokia support forum): http://discussions.nokia.co.uk/discussions/board/message?board.id=hardware&thread.id=7775
1. Delete unused names/numbers from the address book to free up memory. (Perhaps write down the ones you want to keep for later re-entry)
2. Once a critical threshold is reached the msg inbox indicator will blink on
3. Enter inbox and DELETE as many messages as you can before phone freezes up again
4. If phone freezes or you get the error message again, restart and keep deleting from the phone book until it allows you hassle-free msg inbox access as per normal (but don't forget to continue deleting thos messages).
May 05, 2009 | Nokia 6300 Cellular Phone
Memory card error
Try using the "format" option in the setup menu. That should wipe any "bad" data off the card. Beware! It will erase anything you already have on the card, so make sure there isn't anything on you need to keep.
Apr 05, 2009 | Pentax Optio 50 Digital Camera
I keep getting error 13 when I use my sd card. Why wont it wo
try difernt card it may want hdcp card hi capsity 4 gb one
Feb 09, 2008 | Virtual Reality VRCD500-SDU CD Player
Memory card error
check to see if the little pin on the memory card is set to "lock", this prevents the camera from accessing any of the data on the card causing this problem
Jan 09, 2008 | Cameras
Vrcd400-sdu error code 13
does your usb device use batteries,some device require.
Aug 22, 2007 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Fostex MR-8 Digital Multi Track Recorder with Built in FX Logo
42 people viewed this question
Top Fostex Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fostex Audio Player and Recorder Expert? Answer questions, earn points and help others
