Question about Freezers
Traulsen m3cdb0531aa140 Could you please tell me what the TXV is in this model (freezer side) It is rusted out been sitting and when bulb is wrapped it hot towel there is no change in PSIG. it just keeps a constant 24 PSIG
  • Merlin Corder III Mar 29, 2014
    Even if I could just get the Hp of the freezer motor that will get me going in the direction I need to be going. Did I read it is 1/3 hp?.
roadbird383
  • 40 Answers
SOURCE: Traulsen 2 door freezer
No...this is not true.You may find that you will have to replace the compressor soon.If that's where the noise is coming from.
Posted on Dec 05, 2007
SOURCE: traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Posted on Nov 24, 2008
buddymcl777
  • 67 Answers
SOURCE: Frigidaire Deluxe Chest Freezer is constantly
Two things to check without knowing the model number.
It is possible the drain plug was left out or not inserted correctly after defrosting and it is leaking..
Also there is sometimes an evaporator pan with a heater element on the bottom. If the heater element failed the evaporator pan would overflow.
Posted on May 04, 2009
  • 173 Answers
SOURCE: frigidaire upright freezer MFU20F3GW7 (model)runs
Clean cooling coils....throughly. Check door seals.
Posted on Jul 08, 2009
SOURCE: during hot weather my traulsen URDT2-24DUT does
48 degrees is way too warm. When is the last time the condenser coil was cleaned? Its the fan coil on the exterior of the unit.
Posted on Sep 23, 2009
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Freezer Unit Isn't Functioning
Inside the refrigeration system alot is goning on. You have to check the pressures low/high to determine the problem. It is easy to say that your unit needs freon but that is not always the case.
here is a list of possible problems:
dirty condenser
dirty evapoator
fans not working
defrost not working
lost of freon
bad compressor
bad compressor valves
slugging
flooding
lack of oil
super heat off
txv is stuck open/close not sensing
incompatilbe unknown freon mix...
well these are just some of the problems you can encounter. this was meant to tell not fix because each problem needs attention but hope this was a little helpful anyways
Mar 29, 2010 | Traulsen 69.1 cu. ft. / 1957 liter...
How can I get the wiring schematic diagram for a two door stand up traulsen freezer model # GLT 2-32 NUT, Thanks Erick.
call traulsen at 1-800-825-8220. Get tech support and give them the model and serial numbers. They will send you a diagram. Nothing on their web site.
Oct 02, 2009 | Traulsen 46 cu. ft. / 1303 liter...
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Traulsen ur 48 dt freezer want go below 10 deg
Nov 23, 2008 | Freezers
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Traulsen Freezer Compressor Change Out Video
Dec 05, 2007 | Freezers
Freezers Logo
73 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
