Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1998 5.7l z71 what all will cause my fuel pump to not come on
What all will cause my fuel pump to not come on
    Sergeant:
    Champion:
  • 225 Answers
Fuel pumps will just fail as does any other electronics. Check the fuse for it first. Also sometimes you can kick on the bottom of the tank and sometimes it will make the pump kick on again. That is a for sure sign that it will need to be replaced.
Posted on Mar 31, 2014
Why wont my 2004 Chevy Tahoe start after installing 2 fuel pumps I do not hear either one of them run what can be the cause
Check your fuses. I replace the fuel pump in a conversion van and it wasn't working until i checked the fuse. I replaced the fuse and away i went.
Apr 03, 2015 | 2004 Chevrolet Chevrolet Tahoe Z71
Where is the fuel reset button on a 1998 gmc sierra Z71??
Only Ford products have an inertia switch for the fuel pump.
If the pump has no power, have you checked the pump relay to see if it is working ?
Aug 31, 2014 | Cars & Trucks
Why does 2004 chevy tahoe z71 not start if sits over night with less than 1/4 tank gas?
The fuel pump may be borderline ready to fail.
For the record, it's best to never allow the fuel tank to get that low - the less fuel in the tank, the greater the risk of water condensing inside the fuel tank.
Jul 29, 2014 | 2004 Chevrolet Chevrolet Tahoe Z71
What should the fuel pressure read on a 1998 gmc z71 5.7 vortec
sounds like your fuel pump, should be 50-55psi fuel pressure, if you don't have a gage,you could check the schrader valve on the rail with screw driver,watch out if it's pressurized it could squirt in your eye's if it shoot's out really strong,chances are it's working, but if it just does little squirt or dribble, then check it out electrically, fuse,relay etc:before you drop the tank, or like some people do take box bolts out and lift box back and it's easier to change pump then.good luck and any other questions feel free to ask me
Dec 20, 2011 | 1998 GMC Sierra
I have a 2000 GMC Sierra extended cab Z71 and my fuel gauge fluctuates.It takes it a while to register it has fuel and then it will just drop to empty then bounce back up. I was wondering what could cause...
The fuel sender is built on to the fuel pump. This happens sometimes if you run the tank low alot Try keeping the truck above 1/2 tank see if this helps otherwise you might need a new fuel pump
Dec 27, 2009 | 2000 GMC New Sierra 1500
I just replaced my plugs/wires on my 2004 z71, still random miss.
I would lean toward a dirty throttle body first.REcheck and make sure one of the wires is not locked in well om plugs. Ususlly from what I found a coil is going to cause to skip most of the time if it is bad.I would attempt fuel treatment and cleaning throttle body real well.
Oct 12, 2009 | 2004 Chevrolet Tahoe
97 z71 vortec 5.7 replaced fuel pump.getting fuel but won't start
The # 5 cylinder is miss firing. not getting fuel. Could the injector just be stopped or the crankshaft sensor in gone.
Jun 26, 2009 | Chevrolet Silverado 1500 Cars & Trucks
97 1500 z71 random/multiple misfires, runs horrible
common causes for backfires is-- lean misfire due to low fuel pressure or resticted fuel injectors, breakdown of secondary including internal ignition coil arching, and a dead spot in tps sensor.
Apr 21, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
1998 Chevrolet Z71
The fuel pump will be located in the fuel tank if engine has fuel injection. If your engine has a carburetor the fuel pump will be located on the right hand (passenger) side of the engine block.
Jun 25, 2008 | 1998 Chevrolet Blazer
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
